nvidia-bug-report.log.gz (637.0 KB)
there’s something i notice on these three direct x games that it will freeze after few min of playing that even ctrl+alt+f3 won’t help and even and no matter how heavy or lightweight the game
the games i have tested: A hat in time+overwatch2+astroneer ( all of them are directX games)
OS:archlinux
nvidia driver version:550.54.14
DE: kde plasma 6 and still useing x11
Please post the output of
sudo cat /sys/module/nvidia_drm/parameters/modeset
Do you use offloading to start those games on the nvidia gpu? i.e. by prepending
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia
Furthermore, your intel igpu doesn’t seem to have vulkan support installed.
i got this insted and nothing changes
and the output of /sys/module/nvidia_drm/parameters/modeset is just the letter N
Please set kernel parameter nvidia-drm.modeset=1
After reboot, the output of the command should change to Y instead of N.
Pre-pending, not appending, e.g. running in a terminal
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia <yourgamebinary>
or install and use prime-run to start your game.
Thanks for your help. Unfortunately, that’s not the end of the problem, but at least I got more details about it.
There’s a new log after I enabled nvidia-drm.modeset and tried using prime-run.
Here are some things I noticed:
- Updating or reinstalling the game makes it work fine, but only on the first launch. It never works again until I reinstall it or install another update.
- The freeze appears on the loading screen or when the game loads some assets.
- All the games I tested that have this problem are Unreal Engine games.
- Adding
nvidia-drm.modeset didn’t change the freezing issue, but it did fix Wayland tearing, so it was useful anyway.
nvidia-bug-report.log (5.7 MB)
5-forgot to say but if i run only useing intel graphics it will work well even that it’s weaker
also there’s proton log
steam-253230.log (223.3 KB)
Since you run it from steam, don’t start steam using offloading but add
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia %command% to game startup options within steam instead. Shouldn’t have an influence on the crash, though. Does disabling vulkan shader precaching help with that?
it didn’t sadly but i notice something while uninstalling nvidia drivers
==> ERROR: module not found: ‘nvidia’
==> ERROR: module not found: ‘nvidia_modeset’
==> ERROR: module not found: ‘nvidia_uvm’
==> ERROR: module not found: ‘nvidia_drm’
==> Generating module dependencies
i dunno it could be useful
why did i uninstall the drivers? i just switched to NVK…it wotks but slower then nvidia
