I am experiencing a freeze of my entire system when playing CS:GO (usually after max. 10 minutes or less of playing). It completely hangs until I hard-reboot.
I have had this issue when I upgraded my system from Linux Mint 20.3 to 21 and thought it might be related to the upgrade that broke some package or anything. But now I am on a clean installation and it is still happening. No issues on 20.3.
System information: https://termbin.com/vkce
I run the game on my Nvidia GPU via Prime (by using the launch options below)
Launch options in steam: __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia %command% +fps_max 80 -novid -nojoy
However, when I tested it a few minutes in Nvidia performance mode (not on-demand) I had no issues.
What still works after the freeze:
Music (keeps playing in the background)
Network
SSH? (Not sure about it, but it worked when I tried a few months ago)
What doesn’t work after the freeze:
Interacting with the game or my system in general
Closing the game
Getting to my desktop (neither Super+D nor Alt+Tab)
Switching to a console (Ctrl+Alt+F1)
What I tried so far (didn’t help):
Clean installing the system, steam and CS:GO
Switching NVidia driver version to 515, 520 or 525
Updating BIOS
Setting intel’s max_cstate to 1
Launching the game in Vulkan mode (-vulkan launch option) (runs as OpenGL application otherwise)
Disabling CPU undervolting
Disabling Swap
Checking my RAM and VRAM (no errors)
Launching steam (not only CS:GO) with Nvidia GPU
I would really appreciate any help as I can’t find a fix for it.
@VulkanGuy Well that looks interesting. Even though the issue report is outdated, there might be a regression (again). I asked if someone can reproduce this.
[ 21266.188] (WW) modeset(0): Present-flip: queue async flip during flip on CRTC 0 failed: Invalid argument
Async flip was enabled in kernel 5.11 and later and doesn’t work properly on some older hardware, leading to the display output to freeze. So when you upgraded from Mint 20.3 (kernel 5.4) to 21 (kernel 5.15) you ran into this.
You mght want to use the liquorix ppa to get the latest kernel to check if this has been fixed meanwhile.
Another workaround would be downgrading the mint kernel to GA, if possible, which should be still 5.4 and stick to that. https://wiki.ubuntu.com/Kernel/LTSEnablementStack
IIRC, another workaround is disabling PRIME sync https://forums.developer.nvidia.com/t/ubuntu-18-04-3-blank-screen-at-startup-with-430-drivers-and-gtx-960/107501/2?u=generix
but this will result in tearing and disabling external outputs on the nvidia gpu.
Furthermore, you should check with the i915 issue tracker if there’s some work done.
Fwiw, i’ve created that Muffin issue back in the day; same system with same kernel and everything just worked when i switched to KDE as it was also noted in the issue thread. No system wide hangs/freezes etc.
Likewise trying the packages that Muffin dev asked me to use also worked.
