Since I’ve installed the latest NVIDIA-driver update, my system will regularly freeze for about 10-20 seconds when using the NVIDIA-driver. "prime-select intel"resolves the situation, as well as just uninstalling the NVIDIA driver.
This issue is present with the 5.13 or the 5.11 kernel active on Linux Mint 20.3. Even when preforming a clean install with just installing the 5.11/5.13 kernel and the NVIDIA 470 or 510 driver will cause this behavior.
I generated the bug report below after the freeze occurred. This time all I did is boot up Linux Mint 20.3, and resizing the terminal window. nvidia-bug-report.log.gz (265.3 KB)
[ 8.712] (EE) AMDGPU(G0): drmmode_do_crtc_dpms cannot get last vblank counter
Driver 470 added some features regarding prime with amdgpu so this might have triggered it.
A workaround might be switching to on-demand mode, otherwise you could try upgrading the kernel to see if this was fixed meanwhile.
Thank you! I don’t get when I’m on prime-select nvidia, the amdgpu driver causes an error… Thanks anyway, I’ll try your suggestions and let you know if it works!
Update: When I’m not using my internal display, the system doesn’t freeze or crash! Thanks for pointing me to this! I will mainly use my external display until this issue is resolved!
