I’ve got a new precision laptop from dell and as soon as I installed nvidia-driver on it I started to have booting troubles.
After two days of investigation, I see that when I do “prime-select intel” it boots, if instead I do “prime-select nvidia” it doesn’t boot anymore freezing somewhere before X starts.
I tried with several nvidia drivers ranging from 450 to 495,
on ubuntu 20.04 and 21.04 it is also the same issue.
I basically need the drivers to get CUDA running and be able to use the GPU for computation. I don’t care if intel gpu is completely disabled, but unfortunately the dell bios does not allow me to do that.
I am joining the log report (that is made with prime-select intel, otherwise I can’t even boot.
nvidia-bug-report.log (1.3 MB)
I have seen quite a few post with the same type of issue,
but couldn’t fine a working solution in any of those.
Your help is really appreciated.
Loic
