Hi , i have these two problems.
Amd and Intel drivers have fix for that Cs:GO lockdown.
I’m using Nvidia Prime , not Bumblebee.
Nvidia Bug Report output is attached.
ASUS FX553VD - i7 7700 HQ - GTX 1050 4 gig
Also Talos Principle is somehow crashes but it is not freezing the system.
My system info is that:
inxi -Fxz
System: Host: asus-FX553VD Kernel: 4.14.5-041405-generic x86_64 (64 bit gcc: 7.2.0)
Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3)
Distro: Linux Mint 18.3 Sylvia
Machine: System: ASUSTeK (portable) product: GL553VD v: 1.0
Mobo: ASUSTeK model: GL553VD v: 1.0
Bios: American Megatrends v: GL553VD.304 date: 09/07/2017
CPU: Quad core Intel Core i7-7700HQ (-HT-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 22464
clock speeds: max: 3800 MHz 1: 2800 MHz 2: 2800 MHz 3: 2800 MHz
4: 2800 MHz 5: 2800 MHz 6: 2800 MHz 7: 2800 MHz 8: 2800 MHz
Graphics: Card-1: Intel Device 591b bus-ID: 00:02.0
Card-2: NVIDIA Device 1c8d bus-ID: 01:00.0
Display Server: X.Org 1.19.3 driver: nvidia
Resolution: 1920x1080@60.01hz
GLX Renderer: GeForce GTX 1050/PCIe/SSE2
GLX Version: 4.5.0 NVIDIA 384.98 Direct Rendering: Yes
Audio: Card Intel Device a171 driver: snd_hda_intel bus-ID: 00:1f.3
Sound: Advanced Linux Sound Architecture v: k4.14.5-041405-generic
Network: Card-1: Intel Wireless 7265 driver: iwlwifi bus-ID: 02:00.0
IF: wlp2s0 state: up mac: <filter>
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 1128.2GB (58.6% used)
ID-1: /dev/sda model: SanDisk_SD8SN8U1 size: 128.0GB
ID-2: /dev/sdb model: HGST_HTS541010A9 size: 1000.2GB
Partition: ID-1: / size: 118G used: 14G (13%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 917G used: 603G (70%) fs: ext4 dev: /dev/sdb1
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 57.5C mobo: N/A gpu: 0.0:45C
Fan Speeds (in rpm): cpu: 0
Info: Processes: 254 Uptime: 42 min Memory: 1834.2/7864.3MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481) inxi: 2.2.35
nvidia-bug-report.log.gz (96.7 KB)
nvidia-bug-report 387.log.gz (89.7 KB)
It locked again , this time with 387.34 driver.
It got even worse with 387.34 driver. It completely freeze my system every time.
You won’t fix it do you?
With 384 driver i’m experiencing this issue from time to time but with 387 driver it happens every time.
