Running DNN models on DLA cores concurrently
I am trying to run a ResNet-50 model concurrently on both the DLA cores but I get strange results:
The total throughput across both the DLA core should ideally be double than that when run on a single DLA core.
Can anyone explain the reason?
Hi @kunal.sahoo2003 ,
Can you please try using Nsight Systems to see if both DLAs are executing concurrently or not?
Ensure that inference is explicitly bound to DLA_0 and DLA_1.
import torch
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit  # DO NOT REMOVE
import time
import os
import csv
import warnings
import argparse
import sys
warnings.filterwarnings('ignore')
class DualLogger:
    def __init__(self, log_path):
        self.terminal = sys.stdout
        self.log_file = open(log_path, "a")
    def write(self, message):
        if message.strip():  # Avoid writing empty lines
            self.terminal.write(message)
            self.log_file.write(f"[KUNAL] {message}")
            self.log_file.flush()
    def flush(self):
        self.terminal.flush()
def build_engine(onnx_file_path, batch_size, dla_core=0, dtype='fp16', logger=None):
    builder = trt.Builder(logger)
    network = builder.create_network(1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH))
    parser = trt.OnnxParser(network, logger)
    with open(onnx_file_path, 'rb') as model:
        if not parser.parse(model.read()):
            print('ERROR: Failed to parse the ONNX file.')
            for error in range(parser.num_errors):
                print(parser.get_error(error))
            return None
    profile = builder.create_optimization_profile()
    input_name = network.get_input(0).name
    profile.set_shape(
        input_name,
        (batch_size, 3, 300, 300),   # min
        (batch_size, 3, 300, 300),   # opt
        (batch_size, 3, 300, 300)    # max
    trt_dtype = {'fp16': trt.BuilderFlag.FP16, 'int8': trt.BuilderFlag.INT8}
    config = builder.create_builder_config()
    config.add_optimization_profile(profile)
    config.set_flag(trt.BuilderFlag.GPU_FALLBACK)
    config.default_device_type = trt.DeviceType.DLA
    config.set_flag(trt_dtype[dtype])
    config.DLA_core = dla_core
    serialized_engine = builder.build_serialized_network(network, config)
    if serialized_engine is None:
        print('Failed to build serialized engine')
        return None
    runtime = trt.Runtime(logger)
    engine = runtime.deserialize_cuda_engine(serialized_engine)
    return engine
def allocate_buffers(engine):
    inputs, outputs, stream = [], [], cuda.Stream()
    for binding in engine:
        size = trt.volume(engine.get_tensor_shape(binding))
        dtype = trt.nptype(engine.get_tensor_dtype(binding))
        host_mem = cuda.pagelocked_empty(size, dtype)
        device_mem = cuda.mem_alloc(host_mem.nbytes)
        tensor_info = {'name': binding, 'host': host_mem, 'device': device_mem}
        if engine.get_tensor_mode(binding) == trt.TensorIOMode.INPUT:
            inputs.append(tensor_info)
        elif engine.get_tensor_mode(binding) == trt.TensorIOMode.OUTPUT:
            outputs.append(tensor_info)
    return inputs, outputs, stream
def infer(context, inputs, outputs, stream):
    for inp in inputs:
        cuda.memcpy_htod_async(inp['device'], inp['host'], stream)
        context.set_tensor_address(inp['name'], inp['device'])
    for out in outputs:
        context.set_tensor_address(out['name'], out['device'])
    context.execute_async_v3(stream.handle)
    for out in outputs:
        cuda.memcpy_dtoh_async(out['host'], out['device'], stream)
    stream.synchronize()
def barrier_sync(sync_dir, batch_size):
    os.makedirs(sync_dir, exist_ok=True)
    sync_file = os.path.join(sync_dir, f'sync_{batch_size}_{os.getpid()}')
    with open(sync_file, 'w') as f:
        f.write('ready')
    while True:
        ready_files = [f for f in os.listdir(sync_dir) if f.startswith(f'sync_{batch_size}_')]
        if len(ready_files) >= 2:
            break
        time.sleep(0.1)
    time.sleep(0.05)
    try:
        os.remove(sync_file)
    except FileNotFoundError:
        pass
def main():
    parser = argparse.ArgumentParser()
    parser.add_argument('--onnx', required=True, help='Path to .onnx file')
    parser.add_argument('--log', required=True, help='CSV output log file')
    parser.add_argument('--dla_core', required=False, default=0, type=int, choices=[0, 1])
    parser.add_argument('--iterations', required=False, default=100, type=int)
    parser.add_argument('--dtype', required=False, default='fp16', choices=['fp16', 'int8'])
    parser.add_argument('--sync_dir', required=True, help='Directory for sync files')
    parser.add_argument('--trt_log_file', required=True, help='Path to save the TensorRT verbose log')
    args = parser.parse_args()
    # Configure DualLogger for both stdout and file
    sys.stdout = DualLogger(args.trt_log_file)
    # Set up TensorRT logger with VERBOSE mode
    trt_logger = trt.Logger(trt.Logger.VERBOSE)
    batch_sizes = [128, 192, 256, 384, 512]
    file = open(args.log, 'w', newline='')
    writer = csv.writer(file)
    writer.writerow(['Batch Size', 'Average Throughput (images/s)', 'Average Latency (ms)'])
    for batch_size in batch_sizes:
        print(f"[DLA Core {args.dla_core}] Preparing engine for batch size {batch_size}...")
        engine = build_engine(args.onnx, batch_size, args.dla_core, args.dtype, logger=trt_logger)
        if engine is None:
            return
        inputs, outputs, stream = allocate_buffers(engine)
        context = engine.create_execution_context()
        infer(context, inputs, outputs, stream)  # Warm-up
        barrier_sync(args.sync_dir, batch_size)
        total_time = 0
        for _ in range(args.iterations):
            start = time.time()
            end = time.time()
            latency = (end - start)
            total_time += latency
            writer.writerow([batch_size, batch_size / latency, latency * 1000])
        avg_time = total_time / args.iterations
        throughput = batch_size / avg_time
        print(f'[DLA Core {args.dla_core}] Batch {batch_size}: Avg Latency = {avg_time*1000:.2f} ms | Throughput = {throughput:.2f} images/s')
    file.close()
if __name__ == '__main__':
    main()
Could you share a command for that?
Whenever I am trying to use NSYS on my custom script, then I do not SEE any DLA traces being logged. Whereas when I run the trtexec command mentioned in the GitHub repository of NVIDIA, that traces.
Can you help me what went wrong.
Command I am running:
sudo nsys profile --trace=cuda,nvtx,cublas,cudla,cusparse,cudnn,nvmedia --output=ssd_mobnet2.nsys-rep /media/ssd/kunal/.venv/bin/python DLA_throughput_beta.py --onnx onnx/ssd_mobilenet_v1_coco_2018_01_28_prepared.onnx --log_prefix ssd_mob --iterations 10 --dtype fp16
