How to run GUI app inside docker who require opengl in jetson nano 2gb developper kit ?
You should type “xhost +” outside the docker. Than, you should pass “-e DISPLAY=:0 -v /tmp/.X11-unix:/tmp/.X11-unix” parameters like:
sudo docker run -it -rm --gpus all -e DISPLAY=:0 -v /tmp/.X11-unix:/tmp/.X11-unix --runtime nvidia --network host nvcr.io/nvidia/l4t-ml:r32.5.0-py
Just for referencing, you can take a look at our blogpost.
Hello ozguryildiz
Thanks for the reply but this doesn’t work for me. I have this message in the picture
Can you try this command?
xhost +local:docker
I just encounter the subject similiar with your problem here:
Hello I’ve tried this but I have the same issue.
Rqt_graph app is running but not rviz
We have demo samples in
/usr/src/nvidia/graphics_demos
Yo may check if you can run the samples as reference. To clarify whether the issue is specific to certain application.
