How to build Jetson Nano os in docker in without jetson nano kit? Is it possible?
I want to run the object detection model in locally or other system without jetson nano
why i am asking this question?
-In Some cases jetson-nano will have some issues with big data so i want to run my model in local and verify the results are good or not in industries.
Does cross-compiling work for you?
If you want to use docker, an ARM simulator will require.
I want to run jetson-nano jetpack-4.6.1 os in docker container in other system like windows OS!!!
IS IT POSSIBLE? @AastaLLL
No, this is not supported.
Ok, Thanks
