DGX Station A100
• DeepStream Version
6.0
DeepStream for video encoding from docker
I’m trying to use nvv4l2h264enc to encode a stream as a part of my pipeline.
I get
root@docker:/home/nvidia/dgx-test/python-deepstream-testsDS5/scripts# python3 dgx-test.py
pygst initialized..
creating pipeline..
Creating source
Creating H264Parser
Creating Decoder
creating H264 Encoder
Creating H264 rtppay
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
** try gst-launch-1.0 rtspsrc location=rtsp://192.168.0.11:8554/ds-test latency=0 buffer-mode=auto ! queue ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! videoscale ! video/x-raw,width=640,height=480 ! autovideosink**
Starting to run pipeline
0:00:00.361111163 110440 0x2141210 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:02.038644256 110440 0x2141210 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.038720910 110440 0x2141210 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.040099407 110440 0x2141210 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Error: gst-resource-error-quark: Could not get/set settings from/on resource. (13): gstv4l2object.c(3501): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/nvv4l2h264enc:encoder:
when looking into that I suspect that this may be something due to nvv4l2h264enc which probably relies on some hardware encoding resource not available for docker like something in /dev/
Can you help me finding the correct recipe for this please.
Cheers,
Ganindu.
