Dear PGI team,
I’d like to report here on my recent endeavor of running (parts of) the gfortran test suite with various compilers, among them PGI 17.10. For details see this c.l.f. thread: https://groups.google.com/forum/?fromgroups=#topic/comp.lang.fortran/AIHRQ2kJv3c
The result for PGI was the following:
pgf95 17.10:
CMP: 78% tests passed, 336 tests failed out of 1554
EXE: 63% tests passed, 576 tests failed out of 1554
… which means that PGI was able to compile about 78% of the considered tests successfully, while it could successfully execute roughly 63%. One thing that is striking about the PGI results is that the gap between compile-time success and run-time success is relatively large, compared to other compilers.
Among the compile-time failures, I count about 77 internal compiler errors (which is more than for the other tested compilers, but to be fair, often multiple ICEs stem from a single test case, so the the number of tests which fail by ICE is a bit smaller). Here is the full list:
$ grep 'Internal compiler error' Testing/Temporary/LastTest.log
PGF90-S-0000-Internal compiler error. rewrite_block_forall: illegal statement in FORALL 46 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/aliasing_dummy_4.f90: 18)
PGF90-F-0000-Internal compiler error. rewrite_block_forall: someting is wrong 46 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/aliasing_dummy_4.f90: 18)
PGF90-F-0000-Internal compiler error. expected initialization assignment 432 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/alloc_comp_assign_2.f90: 45)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 8 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/alloc_comp_assign_7.f90: 33)
PGF90-F-0000-Internal compiler error. Errors in Lowering 1 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/alloc_comp_constructor_3.f90: 16)
PGF90-F-0000-Internal compiler error. Errors in Lowering 2 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/allocate_deferred_char_scalar_2.f03: 21)
PGF90-F-0000-Internal compiler error. Errors in Lowering 3 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/allocate_with_source_7.f08: 77)
PGF90-S-0000-Internal compiler error. bad dtype -1 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/array_constructor_type_14.f03: 19)
PGF90-S-0000-Internal compiler error. unexpected ast type in initialization expr 148 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/array_initializer_1.f90: 21)
PGF90-S-0000-Internal compiler error. mkexpr1: bad id 14 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/associate_25.f90: 21)
PGF90-S-0000-Internal compiler error. mkexpr1: 0 dtype 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/associate_25.f90: 22)
PGF90-F-0000-Internal compiler error. size_shape: stride is not 1 3 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/bound_4.f90: 11)
PGF90-F-0000-Internal compiler error. size_shape: stride is not 1 11 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/char_length_5.f90: 60)
PGF90-F-0000-Internal compiler error. mod_type/data type: bad data type: 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/char_result_14.f90: 52)
PGF90-F-0000-Internal compiler error. Errors in Lowering 1 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/char_result_13.f90: 14)
PGF90-F-0000-Internal compiler error. mod_type/data type: bad data type: 6 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/char_result_15.f90: 21)
PGF90-F-0000-Internal compiler error. rewrite_sub_args: can't find array 420 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/char_result_3.f90: 41)
PGF90-F-0000-Internal compiler error. Errors in Lowering 1 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/class_allocate_21.f90: 20)
PGF90-F-0000-Internal compiler error. unknown state file error 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/class_assign_1.f08: 30)
PGF90-S-0000-Internal compiler error. compute_size, AC_ACONST in AC_EXPR 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/class_to_type_1.f03: 21)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 8 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/class_to_type_1.f03: 21)
PGF90-F-0000-Internal compiler error. insert_sym: bad hash 675 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/class_result_6.f90: 19)
PGF90-F-0000-Internal compiler error. insert_sym: bad hash 626 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/class_result_5.f90: 14)
PGF90-F-0000-Internal compiler error. Errors in ILM file 2 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/dynamic_dispatch_10.f03: 53)
PGF90-F-0000-Internal compiler error. rewrite_subroutine: unknown stmt found 95 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/dynamic_dispatch_5.f03: 156)
PGF90-S-0000-Internal compiler error. select_rtemp: bad ili 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/finalize_15.f90: 187)
PGF90-S-0000-Internal compiler error. exp_call: ili ret type not cased 136 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/finalize_15.f90: 187)
PGF90-S-0000-Internal compiler error. get_const_from_ast: can't get const value 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/ieee/ieee_7.f90: 10)
PGF90-F-0000-Internal compiler error. Subscript for array is out-of-bounds 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/ieee/ieee_7.f90: 10)
PGF90-S-0000-Internal compiler error. bad dtype 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/inline_sum_1.f90: 21)
PGF90-S-0000-Internal compiler error. size_of: bad dtype 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/inline_sum_1.f90: 21)
PGF90-S-0000-Internal compiler error. alignment: bad dtype 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/inline_sum_1.f90: 21)
PGF90-S-0000-Internal compiler error. lower_sptr: bad sptr 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/mapping_1.f90: 69)
PGF90-F-0000-Internal compiler error. Errors in Lowering 4 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/pr39865.f90: 26)
PGF90-S-0000-Internal compiler error. get_const_from_ast: can't get const value 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/pr67140.f90: 7)
PGF90-F-0000-Internal compiler error. Subscript for array is out-of-bounds 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/pr67140.f90: 7)
PGF90-S-0000-Internal compiler error. size_of: attempt to get size of assumed size character 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/pr83874.f90: 14)
PGF90-F-0000-Internal compiler error. Errors in Lowering 5 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/proc_decl_17.f90: 50)
PGF90-F-0000-Internal compiler error. Errors in ILM file 12 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/proc_ptr_comp_17.f90: 21)
PGF90-F-0000-Internal compiler error. Errors in ILM file 4 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/proc_ptr_comp_16.f90: 27)
PGF90-F-0000-Internal compiler error. insert_sym: bad hash 652 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/proc_ptr_result_1.f90: 85)
PGF90-S-0000-Internal compiler error. get_const_from_ast: can't get const value 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/quad_3.f90: 10)
PGF90-F-0000-Internal compiler error. Subscript for array is out-of-bounds 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/quad_3.f90: 10)
PGF90-S-0000-Internal compiler error. get_const_from_ast: can't get const value 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/quad_2.f90: 14)
PGF90-F-0000-Internal compiler error. Subscript for array is out-of-bounds 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/quad_2.f90: 14)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 8 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/realloc_on_assign_17.f90: 40)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 9 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/realloc_on_assign_17.f90: 40)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 8 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/realloc_on_assign_17.f90: 43)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 9 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/realloc_on_assign_17.f90: 43)
PGF90-F-0000-Internal compiler error. Errors in Lowering 2 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/reshape_transpose_1.f90: 18)
PGF90-F-0000-Internal compiler error. Subscript for array is out-of-bounds 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/round_4.f90: 30)
PGF90-F-0000-Internal compiler error. insert_sym: bad hash 822 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/select_type_37.f03: 76)
PGF90-F-0000-Internal compiler error. unknown state file error 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/submodule_11.f08: 19)
PGF90-F-0000-Internal compiler error. unknown state file error 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/submodule_30.f08: 19)
PGF90-S-0000-Internal compiler error. compute_size, AC_ACONST in AC_EXPR 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/type_to_class_1.f03: 17)
PGF90-W-0000-Internal compiler error. sub_i in constructf90 is not back 8 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/type_to_class_1.f03: 17)
PGF90-S-0000-Internal compiler error. sym_of_ast: unexpected ast 5 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/typebound_call_10.f03: 36)
PGF90-S-0000-Internal compiler error. memsym_of_ast:unexp.ast 5 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/typebound_call_10.f03: 36)
PGF90-F-0000-Internal compiler error. Errors in Lowering 1 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/typebound_call_20.f03: 40)
PGF90-F-0000-Internal compiler error. insert_sym: bad hash 860 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/typebound_operator_9.f03: 158)
PGF90-F-0000-Internal compiler error. Subscript for array is out-of-bounds 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/unlimited_polymorphic_13.f90: 14)
PGF90-S-0000-Internal compiler error. select_rtemp: bad ili 0 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/unlimited_polymorphic_14.f90: 13)
PGF90-S-0000-Internal compiler error. exp_call: ili ret type not cased 79 (/home/jweil/gcc/trunk/gcc/testsuite/gfortran.dg/unlimited_polymorphic_14.f90: 13)
I hope the PGI team will be able to look into some of these problems. If you see any issues with my methodology (or ways in which my testing procedure could be improved), please let me know.
Cheers,
Janus
