Running TensorRT Inference Server without Docker Command
Hi all,
I am currently trying to run tensorrt inference server and I followed instructions listed here: [url]Documentation – Pre-release :: NVIDIA Deep Learning Triton Inference Server Documentation
I have successfully built the server from source with correcting a few C++ codes. However, there is literally no instruction about running the server without Docker command. Documentation – Pre-release :: NVIDIA Deep Learning Triton Inference Server Documentation
It doesn’t make sense if you put some instructions about building a software while not giving any info when it comes to run it.
Hi doruk898,
I reached out to the TRTIS team about updating the docs for this case (running TRT server on host after building from source), and they created a task to do so.
In the meantime, I believe you can navigate into the trtis/install directory created during the build process as mentioned here: https://docs.nvidia.com/deeplearning/sdk/tensorrt-inference-server-guide/docs/build.html#build-inference-server
And then you can run the executable in there:
# Inside trtis/install directory after building...
./trtserver --model-store=<path_to_models>
This is essentially the same way that you would run it if executing in a docker container:
nvidia-docker run <container_config_flags> ... trtserver --model-store=<path_to_models>
Thanks,
NVIDIA Enterprise Support
