I attempted to run the NanoOWL ViT model in containerized form on a Jetson AGX Orin 64GB Developer Kit. I am using a e-CON systems STURDeCAM31 in this setup. The camera appears to work fine on its own.
When running the containerized application (tree_demo.py), I get the following error:
[ WARN:0@41.217] global cap_gstreamer.cpp:1777 open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
======== Running on http://0.0.0.0:7860 ========
(Press CTRL+C to quit)
(python3:639): GStreamer-CRITICAL **: 18:28:08.913: gst_sample_get_caps: assertion ‘GST_IS_SAMPLE (sample)’ failed
[ERROR:1@106.219] global cap_gstreamer.cpp:934 retrieveVideoFrame GStreamer: gst_sample_get_caps() returns NULL
I appear to be running into issues with the GStreamer pipeline. Would you have any suggestions to get around this issue, please?
Thank you very much.
