I am not sure but i believe that the GPU can’t run over 5 seconds.
Are there solutions which make the GPU work over 5 seconds ?
The windows watchdog timeout for GDI operations is 5 seconds, if you use the graphicscard you’re doing CUDA on as your primary graphics adapter.
A solution could be if you install a second graphicscard (a cheap one or onboard) as your primary graphics adapter.
Thanks for your reply. :)
Are there other methods ?
You can run in the linux console without X.
Split your task in smaller chunks :)
