I have just downloaded and installed the latest driver, toolkit, and sdk:
cudadriver_2.3_linux_64_190.16.run
cudatoolkit_2.3_linux_64_ubuntu9.04.run
cudasdk_2.3_linux.run
and after installing the libraries, setting path, etc., I can build the sdk.
However running applications in the sdk produces the error:
particles: error while loading shared libraries: libcudart.so.2: wrong ELF class: ELFCLASS32
so it looks like I am cross compiling. I do not want to compile for 32 bits, but for the native 64 bit machine.
I looked in the Release Notes, but didn’t see any way to force the 64 bits.
I did not have this problem on the machine I built a week ago using Cuda 2.2 and retrograde compiler, etc.
Is /usr/local/cuda/lib64 in /etc/ld.so.conf ?
No, and it isn’t in /etc/ld.so.conf.d/* either.
Also: no appearances of cuda in /etc/ld.so.conf or /etc/ld.so.conf.d/* on the machine that does not have the problem.
EDIT: adding a file /etc/ld.so.conf.d/cuda2.3.conf containing /usr/local/cuda/lib64 appears to make no difference.
/usr/local/cuda/lib64 is there, and appears to have sensible shared objects in it.
EDIT2: I just forced the issue by setting LD_LIBRARY_PATH to /usr/local/cuda/lib64. Unless someone explains what’s wrong with that, I’ll just use that.
Nico
July 24, 2009, 4:28pm
4
Did you run ldconfig after adding the /etc/ld.so.conf.d/cuda2.3.conf file, otherwise the library path is not up to date.
N.
Good catch - I left that out. I took the forced LD_LIBRARY_PATH out of the .profile and went back to the cuda2.3.conf file, and, having run ldconfig, it works.
I did everything you said and I could not run the SDK examples.
If I set LD_LIBRARY_PATH as /usr/local/cuda/lib, I get:
and if I set LD_LIBRARY_PATH as /usr/local/cuda/lib64, I get:
Segmentation fault
I have configured /etc/ld.conf.d/cuda-2.3.conf and ran ldconfig, but it still not working.
im getting this error:
“error while loading shared libraries: libcudart.so.2: wrong ELF class: ELFCLASS32”
my paths are in .profile
~/.profile: executed by the command interpreter for login shells.
This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
exists.
see /usr/share/doc/bash/examples/startup-files for examples.
the files are located in the bash-doc package.
the default umask is set in /etc/profile; for setting the umask
for ssh logins, install and configure the libpam-umask package.
#umask 022
if running bash
if [ -n “$BASH_VERSION” ]; then
# include .bashrc if it exists
if [ -f “$HOME/.bashrc” ]; then
. “$HOME/.bashrc”
fi
fi
set PATH so it includes user’s private bin if it exists
if [ -d “$HOME/bin” ] ; then
PATH=“$HOME/bin:$PATH”
fi
#/usr/local/cuda
CUDA_INSTALL_PATH=/usr/local/cuda
SDK_INSTALL_PATH=~/NVIDIA_GPU_Computing_SDK
PATH=$PATH:/usr/local/cuda/bin
LD_LIBRARY_PATH=/usr/local/cuda/lib64
export CUDA_INSTALL_PATH
export SDK_INSTALL_PATH
export PATH
export LD_LIBRARY_PATH
i dont know if that is ok. i assume its not because im getting an error xD.
i didnt quite understand what you all wrote up there.
