RuntimeError: CUDA error: device kernel image is invalid
I am trying to get a repository working (PAPO) but I keep running into
RuntimeError: CUDA error: device kernel image is invalid.
I have looked at the other threads, but the solutions did not help.
  1. My torch is the correct version: 2.6.0+cu124. I used pip install torch==2.6.0 torchvision==0.21.0 torchaudio==2.6.0 --index-url https://download.pytorch.org/whl/cu124 to install it. In addition, I have tested that it works properly.
  2. my cuda toolkit and runtime are the same:
    nvcc --version, I get:
    nvcc warning : incompatible redefinition for option 'compiler-bindir', the last value of this option was used
    Copyright (c) 2005-2024 NVIDIA Corporation
    Built on Thu_Mar_28_02:18:24_PDT_2024
    Cuda compilation tools, release 12.4, V12.4.131
    Build cuda_12.4.r12.4/compiler.34097967_0
    and when I do conda list | grep -E "cudatoolkit|cuda-toolkit", I get:
    cuda-toolkit 12.4.1 hb982923_0
  3. I can not run sudo because I am on a campus cluster and do not have sudo permission.
So, how can I fix my issue? Forcing conda to use cuda-toolkit=12.4 and cuda-runtime=12.4 when creating the conda enviroment (conda create -n env cuda-toolkit=12.4 cuda-runtime=12.4 python=3.10) did not work.
The issue is happening when I call trainer.init_workers() in
the script:
import json
import ray
from omegaconf import OmegaConf
from ..single_controller.ray import RayWorkerGroup
from ..utils.tokenizer import get_processor, get_tokenizer
from ..workers.fsdp_workers import FSDPWorker
from ..workers.reward import BatchFunctionRewardManager, SequentialFunctionRewardManager
from .config import PPOConfig
from .data_loader import create_dataloader
from .ray_trainer import RayPPOTrainer, ResourcePoolManager, Role
@ray.remote(num_cpus=1)
class Runner:
    """A runner for RL training."""
    def run(self, config: PPOConfig):
        # print config
        print(json.dumps(config.to_dict(), indent=2))
        # instantiate tokenizer
        tokenizer = get_tokenizer(
            config.worker.actor.model.model_path,
            override_chat_template=config.data.override_chat_template,
            trust_remote_code=config.worker.actor.model.trust_remote_code,
            use_fast=True,
        processor = get_processor(
            use_fast=True,
        ray_worker_group_cls = RayWorkerGroup
        role_worker_mapping = {
            Role.ActorRollout: ray.remote(FSDPWorker),
            Role.Critic: ray.remote(FSDPWorker),
            Role.RefPolicy: ray.remote(FSDPWorker),
        global_pool_id = "global_pool"
        resource_pool_spec = {
            global_pool_id: [config.trainer.n_gpus_per_node] * config.trainer.nnodes,
        mapping = {
            Role.ActorRollout: global_pool_id,
            Role.Critic: global_pool_id,
            Role.RefPolicy: global_pool_id,
        resource_pool_manager = ResourcePoolManager(resource_pool_spec=resource_pool_spec, mapping=mapping)
        if config.worker.reward.reward_type == "sequential":
            RewardManager = SequentialFunctionRewardManager
        elif config.worker.reward.reward_type == "batch":
            RewardManager = BatchFunctionRewardManager
        else:
            raise NotImplementedError(f"Unknown reward type {config.worker.reward.reward_type}.")
        RemoteRewardManager = ray.remote(RewardManager).options(num_cpus=config.worker.reward.num_cpus)
        reward_fn = RemoteRewardManager.remote(config.worker.reward, tokenizer)
        val_reward_fn = RemoteRewardManager.remote(config.worker.reward, tokenizer)
        train_dataloader, val_dataloader = create_dataloader(config.data, tokenizer, processor)
        trainer = RayPPOTrainer(
            config=config,
            tokenizer=tokenizer,
            processor=processor,
            train_dataloader=train_dataloader,
            val_dataloader=val_dataloader,
            role_worker_mapping=role_worker_mapping,
            resource_pool_manager=resource_pool_manager,
            ray_worker_group_cls=ray_worker_group_cls,
            reward_fn=reward_fn,
            val_reward_fn=val_reward_fn,
        trainer.fit()
import os
def main():
    cli_args = OmegaConf.from_cli()
    default_config = OmegaConf.structured(PPOConfig())
    if hasattr(cli_args, "config"):
        config_path = cli_args.pop("config", None)
        file_config = OmegaConf.load(config_path)
        default_config = OmegaConf.merge(default_config, file_config)
    ppo_config = OmegaConf.merge(default_config, cli_args)
    ppo_config: PPOConfig = OmegaConf.to_object(ppo_config)
    ppo_config.deep_post_init()
    if not ray.is_initialized():
        runtime_env = {
            "env_vars": {
                "TOKENIZERS_PARALLELISM": "true",
                "NCCL_DEBUG": "WARN",
                "VLLM_LOGGING_LEVEL": "WARN",
                "TORCH_NCCL_AVOID_RECORD_STREAMS": "1",
                "PYTORCH_CUDA_ALLOC_CONF": "expandable_segments:False",
                "PYTHONUNBUFFERED": "1",
        ray.init(
            local_mode = os.getenv("RAY_LOCAL_MODE", "false").lower() == "true",
            runtime_env=runtime_env
    runner = Runner.remote()
    ray.get(runner.run.remote(ppo_config))
if __name__ == "__main__":
    main()
Fixed the nvcc warning : incompatible redefinition for option compiler-bindir, the last value of this option was used by doing conda install cuda -c nvidia/label/cuda-12.4.0
Turned out that the issue was incompatible vlm, pytorch, and flash-attn combination. After downloading the correct version of flash-attn (I was using 2.8.1 but it seems that I needed to use flash_attn-2.7.4.post1), I no longer got the error. I found the correct flash-attn by asking for the environment people who got the repo working had.
Hope this can help someone else out too.
