RX Out-of-Buffer Issues on Mellanox NIC with High-Rate Packet Generator Traffic
I’m experiencing an issue with RX packet drops on our Mellanox ConnectX-5 NICs under high traffic load generated by DPDK-based packet generators (Pktgen/TrafficGen).
Environment:
  • NIC: Mellanox ConnectX-5 25G
  • Driver: MLNX_OFED_LINUX-5.8-4.1.5.0 (Ubuntu 22.04, Kernel 5.15)
  • DPDK version: 25.11.0-rc0
  • Traffic: High PPS TCP SYN floods using Pktgen / TrafficGen
  • Observed PPS: Up to 37 million packets per second on the NIC
Problem (in the target machine):
  • When generating traffic with hping3, rx_out_of_buffer counter remains stable.
  • When using DPDK-based Pktgen or TrafficGen at high rates, rx_out_of_buffer counter increases rapidly ~%90 of all the packets.
  • CPU usage does not reach 100%, and NIC queues themselves do not report missed packets (imissed remains 0).
  • Interrupt coalescence is disabled, flow control is off, and PCI Max Read Request is set to 4096.
Questions:
  1. Why does rx_out_of_buffer increase under high DPDK traffic, even though the receive rings are not full and CPU is not saturated?
  2. Are there specific NIC tuning parameters for high-PPS DPDK traffic to prevent this counter from increasing?
  3. Could this be related to DPDK driver configuration or kernel interaction with Mellanox NICs?
  4. If I am truly hitting the NIC limit, is there a way to overcome the rx_out_of_buffer issue? If I can, I will try to pass the incoming packets to iptables and measure its performance
Any guidance or recommendations would be greatly appreciated.
Note: i also tried theese methods:
sudo sysctl -w net.core.netdev_max_backlog=300000
sudo sysctl -w net.core.rmem_max=4194304
sudo sysctl -w net.core.rmem_default=4194304
sudo sysctl -w net.core.netdev_budget=5000
sudo sysctl -w net.core.netdev_budget_usecs=1000
sudo sysctl -w net.core.wmem_max=4194304
sudo sysctl -w net.core.wmem_default=4194304
sudo ethtool -L {interface_name} combined 63
sudo ethtool -X {interface_name} equal 63
sudo ethtool -C {interface_name} rx-usecs 64 rx-frames 128
sudo ethtool -C {interface_name} adaptive-rx on
sudo ethtool -G {interface_name} rx 4096 tx 4096
sudo ethtool -C {interface_name} adaptive-rx off rx-usecs 0 rx-frames 0
sudo ethtool -A {interface_name} rx off tx off
Thanks in advance
Hi @Yigit.Kotuz ,
“rx_out_of_buffer” means “Number of times receive queue had no software buffers allocated for the adapter's incoming traffic”.
According to your description, I don’t think you hit the NIC limit.
It looks like an environment or configuration issue.
Could you please:
  • Try debug tool perf to find the bottleneck?
or
  • Find another env/os to test again?
Or
  • Reinstall the OS and test again with a “clean” system?
Best regards!
Hello, I’m having a similar issue but with a BlueField®-2 dual-port 100 Gbps that has a ConnectX-6 Dx. When using Pktgen to replay some pcaps, I notice that rx_out_of_buffer is increasing, even under moderate speeds (20 Gbps, 30 Gbps).
I also did a similar tuning as the one described on the question.
@Yigit.Kotuz did you happen to solve your problem?
Hi Hbrum499, i could not solve the problem actually, but i use trafgen in the attacker machine like this with multithread:
for i in {1..30}; do sudo timeout 30s trafgen --cpp --dev <<interface_name>>–conf trafgenconfig --cpu “$i” --verbose & done
With this configuration, I experienced almost no packet loss or no rx_out_of_buffer problem. However, I’m still having problems with pktgen-dpdk.
