Sample code for linear memory -> 3d texture
Does anyone have some sample code for
  1. allocating a device linear memory space
  2. writing it with a kernel
  3. converting/copying that space to a 3d texture
  4. using that texture in another kernel
I seem to have answered my own question, so ill post it here in case it can help someone else.
float  *d_density;
CUDA_SAFE_CALL( cudaMalloc((void **)&d_density,sizeof(float)*num_xyz) );
convert_ct_density<<<dimGrid,dimBlock,0>>>(d_ct,d_density); //write to d_density
cudaArray *density_arr;
	cudaChannelFormatDesc floatTex = cudaCreateChannelDesc<float>();;
	const cudaExtent volumeSize = make_cudaExtent(map->x_dim, map->y_dim, map->z_dim);
	CUDA_SAFE_CALL( cudaMalloc3DArray(&density_arr, &floatTex, volumeSize) );
prepareCudaTexture(d_density,density_arr,floatTex,volumeSize);
static void prepareCudaTexture(float* d_source, cudaArray *a_Data,cudaChannelFormatDesc floatTex, const cudaExtent volumeSize)
	cudaMemcpy3DParms copyParams = {0};
	copyParams.srcPtr   = make_cudaPitchedPtr((void*)d_source, volumeSize.width*sizeof(float), volumeSize.width, volumeSize.height);
	copyParams.dstArray = a_Data;
    copyParams.extent   = volumeSize;
    copyParams.kind     = cudaMemcpyDeviceToDevice;
    CUDA_SAFE_CALL( cudaMemcpy3D(&copyParams) );
	densityData.normalized = false;
    densityData.filterMode = cudaFilterModePoint;
    densityData.addressMode[0] = cudaAddressModeWrap;   // wrap texture coordinates
    densityData.addressMode[1] = cudaAddressModeWrap;
    densityData.addressMode[2] = cudaAddressModeWrap;
   // bind array to 3D texture
    CUDA_SAFE_CALL(cudaBindTextureToArray(densityData, a_Data, floatTex));
Use at your own risk for now, this code is 1h old!
