Hey
I’m new to cuda and I’m trying to use a 3D texture to manipulate data but I can’t seem to get it to work.
I can compile the code but all the outputs just turn out to be 0.
I tried this on a 2D case and it worked.
I believe it’s something wrong with copying the data.
#include <cuda.h>
#include <cutil.h>
#include <iostream>
#define max_H 3
#define max_W 3
#define max_D 3
using namespace std;
texture<float, 3, cudaReadModeElementType> tex;
__global__ void texTest(float* matrix_p)
int index_x = blockIdx.x*blockDim.x+threadIdx.x;
int index_y = blockIdx.y*blockDim.y+threadIdx.y;
int index_z = blockIdx.z*blockDim.z+threadIdx.z;
matrix_p[index_z*max_W*max_H+index_y*max_W+index_x]=2*tex3D(tex,index_x,index_y,index_z);
int main (void)
float matrix [max_H][max_W][max_D];
float *matrix_ptr;
float matrix2 [max_H][max_W][max_D];
for (int i=0; i < max_H ; i++)
for (int j=0; j<max_W ; j++)
for(int k=0; k<max_D;k++)
matrix[i][j][k]=i*max_W*max_H+j*max_H + k;
cout<<matrix[i][j][k]<<" ";
cout<<"\n"<<endl;
cout << endl;
cout <<"\n\n\n"<< endl;
//array init
cudaArray* cu_array=NULL;
cudaChannelFormatDesc description = cudaCreateChannelDesc<float>();
const cudaExtent extent = make_cudaExtent(max_W, max_H, max_D);
cudaMalloc3DArray(&cu_array, &description,extent);
//copy data
cudaPitchedPtr pitch_ptr;
cudaMalloc3D(&pitch_ptr, extent);
cudaMemset3D(pitch_ptr, 0, extent);
cudaMemcpy3DParms copyParams = {0};
copyParams.srcPtr = pitch_ptr;
copyParams.dstArray = cu_array;
copyParams.extent = extent;
copyParams.kind = cudaMemcpyDeviceToDevice;
CUDA_SAFE_CALL(cudaMemcpy3D(©Params));
//texture parameters
tex.addressMode[0] = cudaAddressModeClamp;
tex.addressMode[1] = cudaAddressModeClamp;
tex.addressMode[2] = cudaAddressModeClamp;
tex.filterMode = cudaFilterModePoint;
tex.normalized = false; // do not normalize coordinates
//Binding texture to data
cudaBindTextureToArray(tex, cu_array,description);
//Kernal call to manipulate data
cudaMalloc((void**)&matrix_ptr,max_H*max_D*max_W*sizeof(float));
dim3 block(max_W,max_H,max_D);
texTest<<<1,block>>>(matrix_ptr);
//Copying data from device back to host
cudaMemcpy(matrix2,matrix_ptr,max_D*max_W*max_H*sizeof(float),cudaMemcpyDeviceToHost);
CUDA_SAFE_CALL( cudaUnbindTexture(tex) );
CUDA_SAFE_CALL( cudaFreeArray(cu_array) );
for (int k=0; k<max_D ; k++)
cout<<matrix2[i][j][k]<<" ";
cout << endl;
cout << endl;
return 0;
