(continued)
I tried to use the model supplied (added it as the pretrained_model_file param).
Prepared the images to 1224 width, 384 height, 3 channels (made sure no b&W). Got this when tried to train:
File “/usr/local/bin/tlt-train-g1”, line 10, in
sys.exit(main())
File “./common/magnet_train.py”, line 24, in main
File “</usr/local/lib/python2.7/dist-packages/decorator.pyc:decorator-gen-106>”, line 2, in main
File “./drivenet/common/timer.py”, line 46, in wrapped_fn
File “./dashnet/scripts/train.py”, line 627, in main
File “./dashnet/scripts/train.py”, line 552, in run_experiment
File “./dashnet/scripts/train.py”, line 457, in train_dashnet
File “./dashnet/scripts/train.py”, line 315, in build_training_graph
File “./dashnet/model/gridbox_model.py”, line 443, in build_training_graph
File “./dashnet/model/gridbox_model.py”, line 210, in predictions_to_dict
File “./drivenet/objectives/base_objective.py”, line 95, in reshape_output
File “/usr/local/lib/python2.7/dist-packages/keras/engine/topology.py”, line 617, in call
output = self.call(inputs, **kwargs)
File “/usr/local/lib/python2.7/dist-packages/keras/layers/core.py”, line 405, in call
return K.reshape(inputs, (K.shape(inputs)[0],) + self.target_shape)
File “/usr/local/lib/python2.7/dist-packages/keras/backend/tensorflow_backend.py”, line 1891, in reshape
return tf.reshape(x, shape)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/gen_array_ops.py”, line 6113, in reshape
“Reshape”, tensor=tensor, shape=shape, name=name)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py”, line 787, in _apply_op_helper
op_def=op_def)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py”, line 3392, in create_op
op_def=op_def)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py”, line 1734, in init
control_input_ops)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py”, line 1570, in _create_c_op
raise ValueError(str(e))
ValueError: Cannot reshape a tensor with 709632 elements to shape [32,4,4,24,78] (958464 elements) for ‘reshape_1/Reshape’ (op: ‘Reshape’) with input shapes: [32,12,24,77], [5] and with input tensors computed as partial shapes: input[1] = [32,4,4,24,78].
Any ideas ?
