I have a Intel Xeon machine with NVIDIA GeForce1080 GTX configured and CentOS 7 as operating system. I have installed NVIDIA-driver 410.48 and cuda-toolkit 10.0. After compiling the cuda-samples, i tried to run ./deviceQuery.
But it throws like this
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1)
nvidia-smi
Tue Feb 12 11:06:22 2019
| NVIDIA-SMI 410.48 Driver Version: 410.48 |
| 0 GeForce GTX 1080 Off | 00000000:01:00.0 On | N/A |
| 0% 56C P0 46W / 240W | 201MiB / 8119MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 20963 G /usr/bin/X 96MiB |
| 0 21546 G /usr/bin/gnome-shell 103MiB |
nvcc --version
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:01_CDT_2018
Cuda compilation tools, release 10.0, V10.0.13
PATH & LD_LIBRARY_PATH
PATH =/usr/local/cuda-10.0/bin:/usr/local/cuda/bin:/usr/local/bin:/usr/local/sbin:
LD_LIBRARY_PATH = /usr/local/cuda-10.0/lib64:/usr/local/cuda/lib64:
lsmod | grep nvidia
nvidia_drm 39819 3
nvidia_modeset 1048491 6 nvidia_drm
nvidia 16805034 276 nvidia_modeset
drm_kms_helper 179394 1 nvidia_drm
drm 429744 6 drm_kms_helper,nvidia_drm
ipmi_msghandler 56032 2 ipmi_devintf,nvidia
lsmod | grep nvidia-uvm
no output
dmesg | grep NVRM
[ 8.237489] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 410.93 Thu Dec 20 17:01:16 CST 2018 (using threaded interrupts)
is this problem anything related to modprobe or nvidia-uvm?
Thanking in advance.
