I download CUDA 7.0 and build sample project (Samples_vs2013.sln).
While I am building the project, the Error messeages are showed as below.
Error 2 error MSB3721: ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\bin\nvcc.exe” -dlink -o x64/Debug/cdpSimpleQuicksort.device-link.obj -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MTd " -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\lib\x64” cudadevrt.lib cudart_static.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib -gencode=arch=compute_35,code=sm_35 -gencode=arch=compute_37,code=sm_37 -gencode=arch=compute_50,code=sm_50 -gencode=arch=compute_52,code=sm_52 -G --machine 64 x64/Debug/cdpSimpleQuicksort.cu.obj” 명령이 종료되었습니다(코드: 1). C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 7.0.targets 669 9 cdpSimpleQuicksort
오류 3 error MSB3721: ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\bin\nvcc.exe” -dlink -o x64/Debug/cdpSimplePrint.device-link.obj -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MTd " -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\lib\x64” cudadevrt.lib cudart_static.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib -gencode=arch=compute_35,code=sm_35 -gencode=arch=compute_37,code=sm_37 -gencode=arch=compute_50,code=sm_50 -gencode=arch=compute_52,code=sm_52 -G --machine 64 x64/Debug/cdpSimplePrint.cu.obj” 명령이 종료되었습니다(코드: 1). C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 7.0.targets 669 9 cdpSimplePrint
오류 4 error MSB3721: ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\bin\nvcc.exe” -dlink -o x64/Debug/cdpBezierTessellation.device-link.obj -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MTd " -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\lib\x64” cudadevrt.lib cudart_static.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib -gencode=arch=compute_35,code=sm_35 -gencode=arch=compute_37,code=sm_37 -gencode=arch=compute_50,code=sm_50 -gencode=arch=compute_52,code=sm_52 -G --machine 64 x64/Debug/BezierLineCDP.cu.obj” 명령이 종료되었습니다(코드: 1). C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 7.0.targets 669 9 cdpBezierTessellation
There are 20 errors as similar as those errors.
So I have no idea how I break through those troubles.
Please give me some guides.
I stuck this moment since 3days… :(
Thank you.
