Hi all,
Not sure where to report this issue to, however…
Using a Jetson TK1 here, and when I attempt to use a Crucial MX100 256GB SSD, the SATA driver in 3.10 does not like it at all, and claims that there isn’t enough power - even when plugging the SSD in via an external power brick.
I’ve tested the mainline u-boot and kernel with the SATA patches from Mikko Perttunen applied, and that kernel (linux-next base) works with the MX100, so it definitely seems something in the 3.10 SATA implementation is at fault.
The 3.10 kernel shows:
ubuntu@tegra-ubuntu:~$ dmesg | grep ata
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] .data : 0xc0b30000 - 0xc0c6f57c (1278 kB)
[ 0.525974] libata version 3.00 loaded.
[ 1.268793] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 3.711285] tegra-sata tegra-sata.0: version 1.0
[ 3.711981] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 3.711994] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pio slum part sadm sds apst
[ 3.713211] scsi0 : tegra-sata
[ 3.713600] scsi1 : tegra-sata
[ 3.713817] ata1: SATA max UDMA/133 irq 55
[ 3.713821] ata2: DUMMY
[ 3.811258] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 3.843239] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 4.020262] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.020619] ata1.00: supports DRM functions and may not be fully accessible
[ 4.020678] ata1.00: ATA-9: Crucial_CT256MX100SSD1, MU01, max UDMA/133
[ 4.020685] ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 4.025350] ata1.00: supports DRM functions and may not be fully accessible
[ 4.029733] ata1.00: configured for UDMA/133
[ 4.795099] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 34.745267] ata1.00: exception Emask 0x0 SAct 0x1 SErr 0x1990000 action 0x6 frozen
[ 34.766101] ata1: SError: { PHYRdyChg 10B8B Dispar LinkSeq TrStaTrns }
[ 34.784994] ata1.00: failed command: READ FPDMA QUEUED
[ 34.802643] ata1.00: cmd 60/08:00:00:00:00/00:00:00:00:00/40 tag 0 ncq 4096 in
[ 34.842949] ata1.00: status: { DRDY }
[ 34.859590] ata1: hard resetting link
[ 35.181242] ata1: SATA link down (SStatus 0 SControl 300)
[ 40.199495] ata1: hard resetting link
[ 40.521240] ata1: SATA link down (SStatus 0 SControl 300)
[ 40.540165] ata1: limiting SATA link speed to 1.5 Gbps
[ 45.539505] ata1: hard resetting link
[ 45.861241] ata1: SATA link down (SStatus 0 SControl 310)
[ 45.880545] ata1.00: disabled
[ 45.897312] ata1.00: device reported invalid CHS sector 0
[ 45.987661] Descriptor sense data with sense descriptors (in hex):
[ 46.174824] ata1: EH complete
[ 46.192262] ata1.00: detaching (SCSI 0:0:0:0)
[ 46.385087] sd 0:0:0:0: [sda] Truncating mode parameter data from 8309 to 512 bytes
[ 46.528710] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 66.180807] ata1.00: qc timeout (cmd 0xef)
[ 66.180862] ata1.00: failed to disable DEVSLP
[ 66.180932] ata1: hard resetting link
[ 66.485406] ata1: SATA link down (SStatus 0 SControl 310)
[ 66.496304] ata1: EH complete
And the 3.16/3.17 kernel shows:
[ 3.873398] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 5.514259] ata1.00: supports DRM functions and may not be fully accessible
[ 5.521349] ata1.00: ATA-9: Crucial_CT256MX100SSD1, MU01, max UDMA/133
[ 5.528000] ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 5.539774] ata1.00: supports DRM functions and may not be fully accessible
[ 5.555588] ata1.00: configured for UDMA/133
[ 5.564725] scsi 0:0:0:0: Direct-Access ATA Crucial_CT256MX1 MU01 PQ: 0 ANSI: 5
[ 5.579236] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 5.591411] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 5.601628] sd 0:0:0:0: [sda] Write Protect is off
[ 5.610952] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.611099] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.626860] sda:
[ 5.634638] sd 0:0:0:0: [sda] Attached SCSI disk
If someone could pass this up to wherever it needs to go, or knows where a bug report like this goes against the 3.10 kernel, that would be great.
