Hi, I’m trying to save 4 different rtsp stream to one video file. I want to concatenate the 4 stream resolution of 1280x720 to one video of 2560x1440.
I succeed to concatenate the 4 stream to one video file but the video file generated is not compressed. It makes 200Mo for 10secondes. It is too big.
When I checked the codec of the video file created it says ‘Uncompressed packed YUV’
Here is my command :
gst-launch-1.0 -ev \ videomixer name=mix \ sink_1::xpos=0 sink_1::ypos=0 \ sink_2::xpos=1280 sink_2::ypos=0 \ sink_3::xpos=0 sink_3::ypos=720 \ sink_4::xpos=1280 sink_4::ypos=720 \ ! qtmux ! filesink location=mosaic.mp4 \ rtspsrc location='rtsp://192.168.1.19:554/1/h264major' \ ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv \ ! video/x-raw,width=1280,height=720 \ ! mix.sink_1 \ rtspsrc location='rtsp://192.168.1.19:554/1/h264major' \ ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv \ ! video/x-raw,width=1280,height=720 \ ! mix.sink_2 \ rtspsrc location='rtsp://192.168.1.20:554/1/h264major' \ ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv \ ! video/x-raw,width=1280,height=720 \ ! mix.sink_3 \ rtspsrc location='rtsp://192.168.1.20:554/1/h264major' \ ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv \ ! video/x-raw,width=1280,height=720 \ ! mix.sink_4 \
PID=$!
sleep 61
kill -INT $PID`
If you have any advice which can help me to reduce the size, to make the file compressed, Thanks!
You may try using nvcompositor instead of videomixer.
You may also need to use RTSP2.0 for EOS management.
gst-launch-1.0 -e nvcompositor name=mix background-w=2560 background-h=1440 \
sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1280 sink_0::height=720 \
sink_1::xpos=1280 sink_1::ypos=0 sink_1::width=1280 sink_1::height=720 \
sink_2::xpos=0 sink_2::ypos=720 sink_2::width=1280 sink_2::height=720 \
sink_3::xpos=1280 sink_3::ypos=720 sink_3::width=1280 sink_3::height=720 \
! 'video/x-raw(memory:NVMM),format=RGBA' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! nvv4l2h264enc insert-vui=1 ! h264parse ! matroskamux ! filesink location=test.mkv sync=false \
rtspsrc location=rtsp://127.0.0.1:8554/test default-rtsp-version=32 ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_0 \
rtspsrc location=rtsp://127.0.0.1:8554/test default-rtsp-version=32 ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_1 \
rtspsrc location=rtsp://127.0.0.1:8554/test default-rtsp-version=32 ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_2 \
rtspsrc location=rtsp://127.0.0.1:8554/test default-rtsp-version=32 ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_3
I tried to use your command but it says this :
How can I use rtsp2.0 ?
Maybe the rtsp server in your camera doesn’t support this, but it may not be mandatory.
RTSP1.0 seems working for me for this case:
! 'video/x-raw(memory:NVMM),format=RGBA' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvv4l2h264enc insert-vui=1 profile=2 ! h264parse ! matroskamux ! filesink location=test.mkv sync=false \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_0 \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_1 \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_2 \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! 'video/x-raw(memory:NVMM),format=NV12' ! queue ! mix.sink_3
Thanks a lot !! It works as I wish
Hi, the code you give me works but does not work every time. It gives me this error.
ERROR: from element /GstPipeline:pipeline0/GstMatroskaMux:matroskamux0: Could not multiplex stream.
Additional debug info:
matroska-mux.c(986): gst_matroska_mux_video_pad_setcaps (): /GstPipeline:pipeline0/GstMatroskaMux:matroskamux0:
Caps changes are not supported by Matroska
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
Do you have an idea why sometimes it crashes ?
The error message says that caps changed and matroskamux doesn’t support this.
You may try to scale each decoded source to 720p, set fixed caps and add -v flag, so that you’ll get some details about what caps changed before the error:
gst-launch-1.0 -ev nvcompositor name=mix \
! 'video/x-raw(memory:NVMM),format=RGBA,width=2560,height=1440,framerate=30/1' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvv4l2h264enc insert-vui=1 profile=2 \
! h264parse ! video/x-h264,width=2560,height=1440,framerate=30/1 ! matroskamux ! filesink location=test.mkv sync=false \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_0 \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_1 \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_2 \
rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp,media=video,encoding-name=H264 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_3
Thanks !
It sends no error, but when I want to stop the programm with Ctrl+C it sends this error :
ERROR: from element /GstPipeline:pipeline0/GstQueue:queue1: Internal data stream error.
gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:queue1:
streaming stopped, reason not-negotiated (-4)
An error happened while waiting for EOS
Execution ended after 0:00:21.379088927
Setting pipeline to PAUSED …
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Is there a way to stop properly exit a gstreamer pipeline ?
I’m using this :
nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1’ ! queue ! mix.sink_3
PID=$!
sleep 21
kill -INT $PID
You may try removing -e or sending signal twice.
Thanks it working !
Now when I play the video file created it doesn’t show the total duration like this :
The information of the file is that :
Do you have an idea why my video file is “corrupted” ?
By using the command in your post of the april 29 :
The file has a duration set.
Do you have any idea why one is working and the other one no?
Thanks in advance
