• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) R32 Revision: 5.0 GCID: 25531747 Board: t186ref
• TensorRT Version 7.1.3 + CUDA 10.2
• Issue Type( questions, new requirements, bugs) Question about saving the inferred output file (from RTSP stream_ every 1 hr
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) please see below
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) please see below
Hi Deepstream team,
Following this code and other answers on the forum, I was able to get the app to save file.
Basically, this is what I did. I would create Gst elements as shown below…
if (output_mp4): queue_sink = Gst.ElementFactory.make("queue", "queue_sink") nvvidconv_sink = Gst.ElementFactory.make( "nvvideoconvert", "nvvidconv_sink") caps_filter = Gst.ElementFactory.make("capsfilter", "caps-filter") caps_filter_sink = Gst.ElementFactory.make( "video/x-raw(memory:NVMM), format=I420") caps_filter.set_property('caps', caps_filter_sink) encoder = Gst.ElementFactory.make("nvv4l2h264enc", "h264-encoder") encoder.set_property('bitrate', 2000000) h264parse = Gst.ElementFactory.make("h264parse", "h264-parse") muxer = Gst.ElementFactory.make("matroskamux", "muxer") sink = Gst.ElementFactory.make("filesink", "nvvideo-renderer") sink.set_property('location', "/home/z5-lpr/Downloads/output.h264") else: if not monitor: print("Creating FakeSink \n") sink = Gst.ElementFactory.make("fakesink", "fakesink") if not sink: sys.stderr.write(" Unable to create fakesink \n") sink.set_property("qos", 0) if is_aarch64(): print("Creating transform \n ") transform = Gst.ElementFactory.make( "queue", "nvegl-transform") if not transform: sys.stderr.write(" Unable to create transform \n") else: # Finally render the osd output print("Creating EGLSink \n") sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer") if not sink: sys.stderr.write(" Unable to create egl sink \n") sink.set_property("qos", 0) if is_aarch64(): print("Creating transform \n ") transform = Gst.ElementFactory.make( "nvegltransform", "nvegl-transform") if not transform: sys.stderr.write(" Unable to create transform \n")
then, i would link/add them up
if output_mp4: nvosd.link(queue9) queue9.link(queue_sink) queue_sink.link(queue10) queue10.link(nvvidconv_sink) nvvidconv_sink.link(queue11) queue11.link(caps_filter) caps_filter.link(queue12) queue12.link(encoder) encoder.link(queue13) queue13.link(h264parse) h264parse.link(queue14) queue14.link(muxer) muxer.link(queue15) queue15.link(sink) else: if is_aarch64(): nvosd.link(queue9) queue9.link(transform) transform.link(sink)
After that I am just doing the following to get the app going -
# create an event loop and feed gstreamer bus mesages to it loop = GObject.MainLoop() bus = pipeline.get_bus() bus.add_signal_watch() bus.connect("message", bus_call, loop) # # Lets add probe to get informed of the meta data generated, we add probe to # # the sink pad of the osd element, since by that time, the buffer would have # # had got all the metadata. osdsinkpad = nvosd.get_static_pad("sink") if not osdsinkpad: sys.stderr.write(" Unable to get sink pad of nvosd \n") osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0) osdsinkpad = nvdsanalytics.get_static_pad("src") if not osdsinkpad: sys.stderr.write(" Unable to get src pad of nvdsanalytics \n") osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, nvdsanalytics_src_pad_buffer_probe, 0) # List the sources print("Now playing...") for i, source in enumerate(args): if (i != 0): print(i, ": ", source) print("Starting pipeline \n") # start play back and listed to events pipeline.set_state(Gst.State.PLAYING) try: loop.run() except: pass # cleanup print("Exiting app\n") pipeline.set_state(Gst.State.NULL)
Since I want to save the output video every 1 hr, I was trying to figure out how I could possible do that. As I am learning Gstreamer in general, I wasn’t entirely sure how I could “break” and save. Would the team have a pointer on where to insert the time based saving? That way i would get a file like… output_032221_01_00.h264, output_032221_02_00.h264, etc.
Would appreciate your pointer.
