Hello, I have a new web-camera with this parameters
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Index : 1
Pixel Format: 'YUYV'
Based on this discussion
I was able to show video in full-hd with this code bellow.
cap = cv2.VideoCapture(‘v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=(int)1920, height=(int)1080, framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink’, cv2.CAP_GSTREAMER)
I tried also this one (without convertion)
cap = cv2.VideoCapture(‘v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=(int)1920, height=(int)1080 ! nvjpegdec ! video/x-raw ! videoconvert ! video/x-raw,format=BGR ! appsink’, cv2.CAP_GSTREAMER)
but with this one it was black and white.
So I’m trying to use this code
cap = cv2.VideoCapture ('v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=(int)1920, height=(int)1080, framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink', cv2.CAP_GSTREAMER)
fourcc = cv2.VideoWriter_fourcc(*'MPEG')
width = cap.get(cv2.CAP_PROP_FRAME_WIDTH)
height = cap.get(cv2.CAP_PROP_FRAME_HEIGHT)
fps = cap.get(cv2.CAP_PROP_FPS)
print("fourcc:{} fps:{}@width:{}@height:{}".format(fourcc, fps, width, height))
file_name = "abc.avi"
out = cv2.VideoWriter(file_name, fourcc, 30, (1920, 1088))
counter = 0
while True:
if counter > 200:
break
counter +=1
_, frame = cap.read()
if(frame is None):
continue
# cv2.imshow('frame', frame)
out.write(frame)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
cap.release()
cv2.destroyAllWindows()
I’m getting this output
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 277
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 277
[ WARN:0] global /home/suomi/opencv/modules/videoio/src/cap_gstreamer.cpp (961) open OpenCV | GStreamer warning: Cannot query video position: status=1, value=6, duration=-1
fourcc:1195724877 fps:30.0@width:1920.0@height:1088.0
but the final video is strange… it shows 1920x1080 30fps in video properties but the video is like lagging or so. Just 4 frames in the whole video
Btw. I don’t know why, but in cv2.CAP_PROP_FRAME_HEIGHT parameter I’m becoming 1088.
Could someone please explain me how to set the VideoWritter right?
Update: I was also able to run camera with
$ export DISPLAY=:0 (or DISPLAY=:1)
$ gst-launch-1.0 v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=(int)1920, height=(int)1080 ! nvjpegdec ! video/x-raw ! xvimagesink
from the code in hyperlink above. But I’m not able to set this in opencv
cap = cv2.VideoCapture ('v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=1920, height=1080 ! nvjpegdec ! video/x-raw ! xvimagesink', cv2.CAP_GSTREAMER)
shows empty pipeline
[ WARN:0] global /home/suomi/opencv/modules/videoio/src/cap_gstreamer.cpp (824) open OpenCV | GStreamer warning: cannot find appsink in manual pipeline
[ WARN:0] global /home/suomi/opencv/modules/videoio/src/cap_gstreamer.cpp (501) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
fourcc:1195724877 fps:0.0@width:0.0@height:0.0
I’m also able to run this pipeline in terminal
'v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=(int)1920, height=(int)1080 ! nvjpegdec ! video/x-raw ! videoconvert ! video/x-raw,format=BGR ! appsink', cv2.CAP_GSTREAMER
but in opencv it runs but frames are black and nothing more
