Pedr
#1
Following this topic https://forums.developer.nvidia.com/t/how-do-i-screen-record-on-the-jetson-tx2/178956/4 I tried to record my screen on my Jetson AGX Xavier. However, the video only displays one or two frames when opening with the default Ubuntu video application and crashes VLC if I try to run it with that.
Is there a standard way to record my screen on the Jetson AGX Xavier?
DaneLLL
#3
For this use-case we only have experience of using ximagesrc in gstreamer. For other solution, would need other users to share experience.
We try the gstreamer command on Xavier/r32.6.1 and it works fine. The a.mkv can be played well. You may try again.
system
closed
#5
