Hello!
I am using TX2 with custom carrier board. Jetpack 4.4.1 installed on TX2. I can’t flash this TX2 with older versions of Jetpack 4.4.1. We were using Jetpack 3.1 and it had no problem with SD card.
I am testing with Sandisk Ultra microSD XC 256GB. Randomly, on some boot SD Card doesn’t show up with right size. “lsblk” shows it as:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 1G 0 loop /var/log
loop1 7:1 0 16M 1 loop
mmcblk2 179:0 0 30,6M 0 disk
mmcblk0 179:32 0 29,1G 0 disk
├─mmcblk0p1 179:33 0 28G 0 part /
├─mmcblk0p2 179:34 0 4M 0 part
├─mmcblk0p3 179:35 0 4M 0 part
├─mmcblk0p4 179:36 0 512K 0 part
├─mmcblk0p5 179:37 0 512K 0 part
├─mmcblk0p6 179:38 0 512K 0 part
├─mmcblk0p7 179:39 0 512K 0 part
├─mmcblk0p8 179:40 0 3M 0 part
├─mmcblk0p9 179:41 0 3M 0 part
├─mmcblk0p10 179:42 0 2M 0 part
├─mmcblk0p11 179:43 0 4M 0 part
├─mmcblk0p12 179:44 0 4M 0 part
├─mmcblk0p13 179:45 0 604K 0 part
├─mmcblk0p14 179:46 0 604K 0 part
├─mmcblk0p15 179:47 0 1M 0 part
├─mmcblk0p16 179:48 0 1M 0 part
├─mmcblk0p17 179:49 0 2M 0 part
├─mmcblk0p18 179:50 0 2M 0 part
├─mmcblk0p19 179:51 0 6M 0 part
├─mmcblk0p20 179:52 0 6M 0 part
├─mmcblk0p21 179:53 0 2M 0 part
├─mmcblk0p22 179:54 0 128M 0 part
├─mmcblk0p23 179:55 0 128M 0 part
├─mmcblk0p24 179:56 0 63M 0 part
├─mmcblk0p25 179:57 0 512K 0 part
├─mmcblk0p26 179:58 0 256K 0 part
├─mmcblk0p27 179:59 0 256K 0 part
├─mmcblk0p28 179:60 0 80M 0 part
├─mmcblk0p29 179:61 0 80M 0 part
├─mmcblk0p30 179:62 0 512K 0 part
├─mmcblk0p31 179:63 0 512K 0 part
├─mmcblk0p32 259:0 0 300M 0 part
└─mmcblk0p33 259:1 0 321,8M 0 part
mmcblk0boot0 179:64 0 8M 1 disk
mmcblk0boot1 179:96 0 8M 1 disk
mmcblk0rpmb 179:128 0 4M 0 disk
This is the dmesg log when error happens:
[ 1.427352] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.427417] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.485626] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.489294] mmc2: new SD card at address d555
[ 1.489759] mmcblk2: mmc2:d555 SD032 30.6 MiB
[ 1.497366] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.513986] mmc0: periodic cache flush enabled
[ 1.514002] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.514501] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 1.514777] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 1.514981] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 1.515192] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 1.516209] OPE platform probe
[ 1.516279] OPE platform probe successful
[ 1.520280] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.535268] usb 1-2: new high-speed USB device number 2 using tegra-xusb
If I plug it out and plug back in, size becomes right.
mmcblk2 179:128 0 238,3G 0 disk
└─mmcblk2p1 179:129 0 238,3G 0 part
I tried changing partition table type to gpt and mbr. Also tried ext4 and exfat fstypes. Doesn’t make a difference.
I tried 10 piece of brand new SD cards. All have same behaviour. These SD cards works on laptop without this problem.
How can we track down this issue? Any help appreciated.
