I have a custom board for tx2i.Using L4t 28.2.1.
The card is only getting detected at bootup if VDD of SD card is provided with 3.3v directly instead of Connecting it to SD Card Enable Pin of jetson. Connections are made as per dev kit on custom board.
If it works well on dev kit, then prove module has no problem on this. Please compare your design with dev kit carrier board to find out the root cause or you can share your design here for check.
There seems to be some problem with L4t28.2.1.
I upgraded my board to Jetpack 4.2.2 and now sd card is working fine. But i am not able to display the 2nd HDMI. extracted.dts.txt (436 KB)
Please read below error. tegradc 15200000 is trying to use a dsi panel. Does this exist on your board?
If not, what is the one you want to enable here? HDMI?
Do you also use tegradc 15200000 for HDMI on rel-28.2.1?
[ 1.088679] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/dsi
[ 1.088689] tegradc 15200000.nvdisplay: tegra_dc_parse_panel_ops: could not find panel for /host1x/dsi
hi
what problem does your sd card module . My sd card cannot detect on my custom board too with tx2I. Could you please give some suggestion? thank you.
