Tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
I tried to achieve dual HDMI, and modified the device tree file of tegra194-p3509-disp.dtsi, but the added HDMI could not display normally, just flash and there was no signal. I will upload the modified device tree file and the full console print. Hope you can get the solution idea, thank you.
Note that I used this method in jetpack4.4 to successfully display both HDMS.
Only plug in the newly added HDMI interface console print.txt (36.0 KB)
tegra194-p3509-disp.dtsi (2.5 KB)
Only plug in the original HDMI interface console to print.txt (36.1 KB)
Below I upload jetpack4.4 success story console all print.
jetpack4.4 console printing.txt (34.8 KB)
tegradc 15210000 is still running for DP driver. You better checking your final dtb file to see if it is really as your expectation…
Ok,I’ll check it out.
I disassembled the file and it looks like it has indeed changed to two HDMS.
new.dtsi (387.5 KB)
Can you tell me how to turn off the dp driver? I have read similar posts on forums before, and I know that the basic direction is to close DP and add an HDMI node, but now it seems that it is not enough for me to modify only in tegra194-p3509-disp.dtsi. Indeed, there are still activities related to DP running, but I do not know where to close them, I hope to get your help. This problem has been bothering me for a week.
One question here… Are you sure the dtb running on the device now is really the dts file which you disabled the DP?
I did not find a.dtb file for tegra194-p3509-disp.dtsi, but my predecessors told me that it appeared that all the device tree files were compiled to tegra194-p3668-all-p3509-0000.dtb. The reason for this is not clear to me, but I will continue to find the problem according to your suggestion.
After I annotate the FDT in the boot/extlinux$extlinux.conf file, dual HDMI takes effect and everything works fine. What’s strange is that I didn’t modify this file when I added the TF card device tree before. The TF card still works fine.
I found a new problem. When the power is off, only the HDMI I added is plugged in, the system can work, but neither of the two HDMI will show anything, they work abnormally, and the following is its console information.
When the power is not on, only plug in the new HDMI.txt (36.0 KB)
However, if I do not power on before, only plug in NVIDIA default HDMI or two HDMI do not plug in, the system will start normally, after the start of the two HDMI work everything is normal, plug and unplug at will, this is why?
Here’s what the console looks like in working order.
NVIDIA-HDMI and without HDMI.txt (35.4 KB)
I don’t understand why this is, how to solve it?
Oh, I’ve been too involved in solving the problem to say thank you. Thank you for your reply and your thoughts. It helped me a lot. I wish you a happy life.
Sorry that could you clarify what “power is off/ power is on” you are talking about here?
I am not sure what power is that… Also, what does that mean NVIDIA default HDMI…??
I’m sorry that my description has caused you trouble.
If you plug in HDNI2 before powering on, your system’s HDMI will crash. No HDMI display.
NVIDIA HDMI is the HDMI of the original system. I said that the new HDMI was added by myself. Let’s call the original HDMI of the system HDMI1 and the new HDMI I added HDMI2, OK?
I am uploading the HDMI I added by myself, namely HDMI2, to you again. Please plug it in and then connect the power to the console to print information. This seems to be a clearer problem.
HDMI2.txt (36.6 KB)
I FOUND a similar scenario in the forum, but I didn’t find a perfect solution, probably because of the driver initialization (this is just my guess), maybe because there are two HDMI at the same time and the driver initialization error will happen. Unfortunately, I can’t add HDMI switch to the hardware like this brother. Any other suggestions? thank you.
  1. 不需要參考2年前tx2的topic. Kernel版本完全不一樣.
  2. 那請問你的HDMI2 如果是開機之後才熱插拔會打中這個問題嗎?
  3. 如果 HDMI1插著開機的狀況下, HDMI2的問題還會存在嗎
  1. There is no need to refer to tx2 posts. The kernel version is totally different.
  2. If your HDMI2 is hotplugged after boot up, will you still have this issue?
  3. If HDMI1 is present since the boot, is the issue on HDMI2 still there?
@WayneWWW
  1. If HDMI2 is not properly hot-swapped after the system starts.
  2. If HDMI1 is plugged in to boot the system, HDMI2 is also normal.
  3. However, it is abnormal to boot the system when HDMI2 is inserted alone or HDMI1 and HDMI2 are inserted simultaneously.
  4. I am using the NX series 35.1 system.
  5. Do you want me to upload the new console information?
@WayneWWW
Plug in HDMI1 and power on.txt (106.1 KB)
Plug in HDNI2 and power on.txt (111.5 KB)
This sounds a bug and we need to check. Will update later.
@WayneWWW
OK, thank you very much for your reply.
Another question here. When you used jetpack4.x, is the 2nd HDMI working fine when it is connected alone?
@WayneWWW
1.HDMI1 and HDMI2 don’t have this problem when I use jetpack4.4, I haven’t tried the other Jetpack 4.x versions. However, the steps in 5.2 and 4.4 are almost exactly the same.
2.Would you like me to upload a complete log for you?
