I restore the board to previous state. pull-none UART1_TX,UART0_RTS,UART7_TX,UART3_TX,UART3_RTS. But system log no diffenent.
DC OR NODE connected to /host1x/sor1
[ 0.588710] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.588737] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.588868] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.589150] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=1875000, max_bw=1875000
[ 0.589212] max_iso_bw is relaxed to 1875000KB from 0KB
[ 0.589409] ------------[ cut here ]------------
[ 0.589456] WARNING: at ffffffc000851ebc [verbose debug info unavailable]
[ 0.589484] Modules linked in:
[ 0.589527]
[ 0.589568] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.4.38 #149
[ 0.589600] Hardware name: quill (DT)
[ 0.589655] task: ffffffc1ece70000 ti: ffffffc1ece78000 task.ti: ffffffc1ece78000
[ 0.589712] PC is at __tegra_isomgr_register+0x310/0x4d8
[ 0.589738] LR is at __tegra_isomgr_register+0x310/0x4d8
[ 0.589802] pc : [] lr : [] pstate: 60000045
[ 0.589836] sp : ffffffc1ece7bb10
[ 0.589859] x29: ffffffc1ece7bb10 x28: 0000000000000380
[ 0.589900] x27: ffffffc00141c000 x26: ffffffc00135d000
[ 0.589939] x25: ffffffc000c05000 x24: 0000000000000000
[ 0.589978] x23: 0000000000000000 x22: 0000000000000008
[ 0.590017] x21: 00000000001c9c38 x20: ffffffc00141c7a0
[ 0.590056] x19: ffffffc00141cb80 x18: ffffffc000b14a60
[ 0.590129] x17: ffffffc000b14a60 x16: ffffffc000b14a60
[ 0.590168] x15: 00000000f5257d14 x14: 73696765725f7267
[ 0.590206] x13: 6d6f73695f617265 x12: 6d61635f61726765
[ 0.590243] x11: ffffffc0011f42a8 x10: ffffffc0013b5e88
[ 0.590282] x9 : 000000000000014b x8 : 0000000000000002
[ 0.590320] x7 : ffffffc00121c978 x6 : 000000000000003a
[ 0.590359] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.590398] x3 : 0000000000000000 x2 : 0000000000000000
[ 0.590436] x1 : 0000000000000000 x0 : 000000000000002b
[ 0.590474]
[ 0.590523] —[ end trace c63d3c37df6061e3 ]—
[ 0.590550] Call trace:
[ 0.590577] [] __tegra_isomgr_register+0x310/0x4d8
[ 0.590606] [] tegra_isomgr_register+0x1c/0x2c
[ 0.590656] [] tegra_camera_probe+0x2a4/0x4c4
[ 0.590705] [] platform_drv_probe+0x50/0xbc
[ 0.590754] [] driver_probe_device+0xcc/0x414
[ 0.590780] [] __driver_attach+0x9c/0xa0
[ 0.590816] [] bus_for_each_dev+0x58/0x98
[ 0.590842] [] driver_attach+0x20/0x28
[ 0.590871] [] bus_add_driver+0x1f0/0x294
[ 0.590898] [] driver_register+0x68/0x108
[ 0.590927] [] __platform_driver_register+0x54/0x5c
[ 0.590964] [] tegra_camera_init+0x18/0x20
[ 0.591002] [] do_one_initcall+0xc8/0x1c4
[ 0.591041] [] kernel_init_freeable+0x1d8/0x27c
[ 0.591080] [] kernel_init+0x10/0xdc
[ 0.591112] [] ret_from_fork+0x10/0x40
[ 0.591194] __tegra_isomgr_register(): ISO BW usage:
[ 0.591222] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 0.591276] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 0.591302] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 0.591328] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 0.591355] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=1875000KB
[ 0.591388] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 0.591417] __tegra_isomgr_register(): client=eqos, iso dedi bw=0KB
[ 0.591441] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 0.604754] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.604790] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.605397] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.608153] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.609590] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.609648] PD DISP0 index2 UP
[ 0.611173] PD DISP1 index3 UP
[ 0.611650] PD DISP2 index4 UP
[ 0.612845] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.613473] kfuse 3830000.kfuse: initialized
[ 0.615693] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.616557] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.621416] console [ttyS0] disabled
[ 0.621710] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.610405] tegra-i2c 3190000.i2c: pio xfer timed out addr: 0x50
[ 2.610408] tegra-i2c 3190000.i2c: — register dump for debugging ----
[ 2.610413] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 2.610417] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 2.610421] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 2.610425] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 2.610428] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 2.610433] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 2.610439] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 2.611577] PD DISP2 index4 DOWN
[ 2.611902] PD DISP1 index3 DOWN
[ 2.612186] PD DISP0 index2 DOWN
[ 2.615158] tegradc 15210000.nvdisplay: probed
[ 2.963158] console [ttyS0] enabled
[ 2.965300] Console: switching to colour frame buffer device 80x30
[ 2.967237] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.969026] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.969308] serial-tegra 3130000.serial: RX in PIO mode
[ 2.970782] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.999032] brd: module loaded
[ 3.004762] loop: module loaded
[ 3.005504] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.005536] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 3.005541] nct1008_nct72 7-004c: starting parse dt
[ 3.005692] nct1008_nct72 7-004c: success parsing dt
[ 3.006041] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.009807] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 3.043115] tmp451: Enabled overheat logging at 104.00C
[ 3.043316] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.043387] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.046317] THERMAL EST: found 3 subdevs
[ 3.046324] THERMAL EST num_resources: 0
[ 3.046331] [THERMAL EST subdev 0]
[ 3.046338] [THERMAL EST subdev 1]
[ 3.046381] [THERMAL EST subdev 2]
[ 3.046807] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 3.046810] THERMAL EST: thz register success.
[ 3.047124] THERMAL EST: end of probe, return err: 0
[ 3.047375] tegra_profiler: Branch: Dev
[ 3.047377] tegra_profiler: Version: 1.109
[ 3.047381] tegra_profiler: Samples version: 37
[ 3.047383] tegra_profiler: IO version: 21
[ 3.047436] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.047441] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.047445] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.047452] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 3.047455] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.047458] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 3.047462] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.047465] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.047469] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.047473] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.047477] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.047480] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.047848] tegra_profiler: auth: init
[ 3.053538] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.053552] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.055085] scsi host0: tegra_ahci
[ 3.055697] scsi host1: tegra_ahci
[ 3.055939] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 3.055944] ata2: DUMMY
[ 3.057649] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.058292] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.058898] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.060010] tun: Universal TUN/TAP device driver, 1.6
[ 3.060013] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.060282] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.060286] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.060334] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 3.060338] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.061952] PPP generic driver version 2.4.2
[ 3.062217] PPP BSD Compression module registered
[ 3.062227] PPP Deflate Compression module registered
[ 3.062268] PPP MPPE Compression module registered
[ 3.062283] NET: Registered protocol family 24
[ 3.062387] usbcore: registered new interface driver r8152
[ 3.062430] usbcore: registered new interface driver asix
[ 3.062468] usbcore: registered new interface driver ax88179_178a
[ 3.062497] usbcore: registered new interface driver cdc_ether
[ 3.062539] usbcore: registered new interface driver smsc95xx
[ 3.062569] usbcore: registered new interface driver net1080
[ 3.062598] usbcore: registered new interface driver cdc_subset
[ 3.062633] usbcore: registered new interface driver zaurus
[ 3.062686] usbcore: registered new interface driver cdc_ncm
[ 3.063101] Wake76 for irq=199
[ 3.063104] Wake77 for irq=199
[ 3.063107] Wake78 for irq=199
[ 3.063108] Wake79 for irq=199
[ 3.063111] Wake80 for irq=199
[ 3.063112] Wake81 for irq=199
[ 3.063115] Wake82 for irq=199
[ 3.063208] tegra-xotg xotg: usb2 phy is not available yet
[ 3.063788] usbcore: registered new interface driver usb-storage
[ 3.063875] usbcore: registered new interface driver usbserial
[ 3.063904] usbcore: registered new interface driver ftdi_sio
[ 3.063931] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.063957] usbcore: registered new interface driver option
[ 3.063978] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.064002] usbcore: registered new interface driver pl2303
[ 3.064025] usbserial: USB Serial support registered for pl2303
[ 3.064316] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.068230] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c 9b da
[ 3.069255] libphy: dwc_phy: probed
[ 3.070235] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.131447] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 3.131622] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.132599] max_iso_bw is relaxed to 1956920KB from 1875000KB
[ 3.132600] ------------[ cut here ]------------
[ 3.132602] WARNING: at ffffffc000851ebc [verbose debug info unavailable]
[ 3.132608] Modules linked in:
[ 3.132608]
[ 3.132620] CPU: 0 PID: 149 Comm: kworker/u12:3 Tainted: G W 4.4.38 #149
[ 3.132621] Hardware name: quill (DT)
[ 3.132652] Workqueue: events_unbound async_run_entry_fn
[ 3.132654] task: ffffffc1eaf8a580 ti: ffffffc1eab38000 task.ti: ffffffc1eab38000
[ 3.132672] PC is at __tegra_isomgr_register+0x310/0x4d8
[ 3.132675] LR is at __tegra_isomgr_register+0x310/0x4d8
[ 3.132678] pc : [] lr : [] pstate: 80000045
[ 3.132680] sp : ffffffc1eab3ba70
[ 3.132684] x29: ffffffc1eab3ba70 x28: 0000000000000460
[ 3.132687] x27: ffffffc00141c000 x26: ffffffc00135d000
[ 3.132690] x25: ffffffc000c05000 x24: 0000000000000000
[ 3.132693] x23: 0000000000000000 x22: 000000000000000a
[ 3.132695] x21: 0000000000014000 x20: ffffffc00141c7a0
[ 3.132698] x19: ffffffc00141cc60 x18: ffffffc000b84f38
[ 3.132701] x17: 000000000000000e x16: ffffffc000b14a60
[ 3.132704] x15: ffffffc000b14a60 x14: 0000000000000000
[ 3.132707] x13: 0000000000000000 x12: 00000000000024b6
[ 3.132709] x11: 00000000000e9145 x10: ffffffc0013b5e88
[ 3.132712] x9 : ffffffc1eab3b910 x8 : 206d6f726620424b
[ 3.132714] x7 : 3032393635393120 x6 : ffffffc0013b6838
[ 3.132717] x5 : 0000000005d11ef2 x4 : 0000000000000000
[ 3.132719] x3 : 0000000000000000 x2 : 0000000000000000
[ 3.132721] x1 : 0000000000000000 x0 : 0000000000000031
[ 3.132722]
[ 3.132724] —[ end trace c63d3c37df6061e4 ]—
[ 3.132728] Call trace:
[ 3.132732] [] __tegra_isomgr_register+0x310/0x4d8
[ 3.132738] [] tegra_isomgr_register+0x1c/0x2c
[ 3.132757] [] eqos_probe+0xac8/0x11bc
[ 3.132768] [] platform_drv_probe+0x50/0xbc
[ 3.132776] [] driver_probe_device+0xcc/0x414
[ 3.132779] [] __driver_attach+0x9c/0xa0
[ 3.132788] [] bus_for_each_dev+0x58/0x98
[ 3.132790] [] driver_attach+0x20/0x28
[ 3.132794] [] driver_attach_async+0x14/0x54
[ 3.132797] [] async_run_entry_fn+0x44/0x180
[ 3.132807] [] process_one_work+0x158/0x434
[ 3.132810] [] worker_thread+0x134/0x40c
[ 3.132816] [] kthread+0xe0/0xf4
[ 3.132824] [] ret_from_fork+0x10/0x40
[ 3.132826] __tegra_isomgr_register(): ISO BW usage:
[ 3.132830] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 3.132833] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 3.132836] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 3.132839] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 3.132842] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=1875000KB
[ 3.132844] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 3.132846] __tegra_isomgr_register(): client=eqos, iso dedi bw=81920KB
[ 3.132847] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 3.195569] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.198245] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.198283] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.169154] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.195344] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.217715] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.239493] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.261744] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.287614] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.309463] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.333428] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.358101] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.380560] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.402648] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.423067] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 3 invalid size:w=0,h=0,out_w=0,out_h=0
