- LT32.2
I connected these signals to according signals of HDMI.
- I enable sor and nvidisplay only according to mannual. [xxx-p3489-xxxx-base.dtsi]
And what others should be modified please ?
- dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (chiv@chiv-vpc) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.0
8) ) #5 SMP PREEMPT Wed Jul 14 17:14:41 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 145600000
[ 0.000000] OF: fdt: - 235e00000 , 200000
[ 0.000000] OF: fdt: - 236600000 , 200000
[ 0.000000] OF: fdt: - 237000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607e000
[ 0.000000] Found lut_mem2: 00002008@9607b000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x000000000000
0000, size 0 MiB
0000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x000000000000
0000, size 0 MiB
0000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1790973
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521725 pages, LIFO batch:31
[ 0.000000] Normal zone: 19912 pages used for memmap
[ 0.000000] Normal zone: 1269248 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1b701c000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1762869
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 nosplash fbcon=map
:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 nosplash fbcon=map:0 net.ifnames=0 v
ideo=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2372e0000 gpt tegra_
fbmem2=0x800000@0x9607e000 lut_mem2=0x2008@0x9607b000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6
boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x235840000 sdhci_tegra.en_boot_part
_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29488(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6935460K/7163892K available (14910K kernel code, 2836K rwdata, 6536K rodata, 8448K ini
t, 607K bss, 162896K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f10000 ( 14912 KB)
[ 0.000000] .rodata : 0xffffff8008f10000 - 0xffffff8009580000 ( 6592 KB)
[ 0.000000] .init : 0xffffff8009580000 - 0xffffff8009dc0000 ( 8448 KB)
[ 0.000000] .data : 0xffffff8009dc0000 - 0xffffff800a085008 ( 2837 KB)
[ 0.000000] .bss : 0xffffff800a085008 - 0xffffff800a11cdbc ( 608 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf06dc8000 ( 109 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1b7200000 ( 7026 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 88
1590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009399] Console: colour dummy device 80x25
[ 0.014039] kmemleak: Kernel memory leak detector disabled
[ 0.019754] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj
=125000)
[ 0.030530] pid_max: default: 32768 minimum: 301
[ 0.035636] Security Framework initialized
[ 0.040054] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.047208] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.055417] ftrace: allocating 46455 entries in 182 pages
[ 0.184154] sched-energy: Sched-energy-costs installed from DT
[ 0.190251] ASID allocator initialised with 65536 entries
[ 0.230142] tegra-id: chipid=21817.
[ 0.233783] tegra-id: opt_subrevision=1.
[ 0.237876] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.244848] DTS File Name: /home/chiv/work/jetson-tx2/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../
../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
[ 0.264205] DTB Build time: <unknown>
[ 0.313876] CPU1: Booted secondary processor [4e0f0030]
[ 0.345498] CPU2: Booted secondary processor [4e0f0030]
[ 0.377341] CPU3: Booted secondary processor [411fd073]
[ 0.409331] CPU4: Booted secondary processor [411fd073]
[ 0.441332] CPU5: Booted secondary processor [411fd073]
[ 0.441391] Brought up 6 CPUs
[ 0.471613] SMP: Total of 6 processors activated.
[ 0.476502] CPU features: detected feature: 32-bit EL0 Support
[ 0.483333] CPU: All CPU(s) started at EL2
[ 0.487649] alternatives: patching kernel code
[ 0.501220] devtmpfs: initialized
[ 0.532165] Initilizing CustomIPI irq domain
[ 0.536844] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 n
s
[ 0.546975] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.554313] pinctrl core: initialized pinctrl subsystem
[ 0.559979] OS set in device tree is not L4T.
[ 0.564682] regulator-dummy: no parameters
[ 0.569546] Initializing plugin-manager
[ 0.573794] Plugin module not found
[ 0.577562] Plugin-manager status disabled
[ 0.585290] NET: Registered protocol family 16
[ 0.592345] pstore: using zlib compression
[ 0.597861] console [pstore-1] enabled
[ 0.601819] pstore: Registered ramoops as persistent store backend
[ 0.608296] ramoops: attached 0x200000@0x235880000, ecc: 0/0
[ 0.625543] cpuidle: using governor menu
[ 0.631938] bpmp: waiting for handshake
[ 0.633337] random: fast init done
[ 0.639541] bpmp: handshake completed
[ 0.643403] bpmp: synchronizing channels
[ 0.647523] bpmp: channels synchronized
[ 0.651572] bpmp: mail init ok
[ 0.658010] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.664840] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.669785] arm-smmu 12000000.iommu: stage 1 translation
[ 0.675435] arm-smmu 12000000.iommu: stage 2 translation
[ 0.681092] arm-smmu 12000000.iommu: nested translation
[ 0.686662] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.695390] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0
x1000000)!
[ 0.706371] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.713309] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.720114] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.731079] vdso: 2 pages (1 code @ ffffff8008f17000, 1 data @ ffffff8009dc4000)
[ 0.738836] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.748014] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.758342] Registering BPMP clocks...
[ 0.762378] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.768577] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.775989] tegra_powergate_init: DONE
[ 0.779949] DTS File Name: /home/chiv/work/jetson-tx2/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../
[ 0.799390] DTB Build time: <unknown>
[ 0.805953] Tegra reboot handler registered.
[ 0.812494] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.819763] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.826048] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.832411] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.838720] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.844254] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.851795] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.858528] iommu: Adding device 3460000.sdhci to group 0
[ 0.864787] iommu: Adding device 3440000.sdhci to group 1
[ 0.871050] iommu: Adding device 3400000.sdhci to group 2
[ 0.878673] iommu: Adding device 3507000.ahci-sata to group 3
[ 0.884750] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.891447] iommu: Adding device 3160000.i2c to group 4
[ 0.897581] iommu: Adding device c240000.i2c to group 5
[ 0.903489] iommu: Adding device 3180000.i2c to group 6
[ 0.909417] iommu: Adding device 3190000.i2c to group 7
[ 0.915495] iommu: Adding device 31b0000.i2c to group 8
[ 0.921542] iommu: Adding device 31c0000.i2c to group 9
[ 0.927446] iommu: Adding device c250000.i2c to group 10
[ 0.933593] iommu: Adding device 31e0000.i2c to group 11
[ 0.941596] iommu: Adding device 3210000.spi to group 12
[ 0.947589] iommu: Adding device c260000.spi to group 13
[ 0.953598] iommu: Adding device 3240000.spi to group 14
[ 0.960165] iommu: Adding device 3100000.serial to group 15
[ 0.966476] iommu: Adding device 3110000.serial to group 16
[ 0.972800] iommu: Adding device c280000.serial to group 17
[ 0.979053] iommu: Adding device 3130000.serial to group 18
[ 0.986648] iommu: Adding device 2490000.ether_qos to group 19
[ 0.992817] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.999785] iommu: Adding device b000000.rtcpu to group 20
[ 1.007961] iommu: Adding device 13e10000.host1x to group 21
[ 1.014364] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 1.021263] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 1.028061] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 1.035483] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 1.042309] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 1.049114] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 1.055900] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 1.062684] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 1.069675] iommu: Adding device 150c0000.nvcsi to group 30
[ 1.076300] iommu: Adding device 15700000.vi to group 31
[ 1.082341] iommu: Adding device 15600000.isp to group 32
[ 1.088636] iommu: Adding device 15210000.nvdisplay to group 33
[ 1.094968] platform 15210000.nvdisplay: OF IOVA linear map 0x9607e000 size (0x800000)
[ 1.103346] platform 15210000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x2008)
[ 1.112061] iommu: Adding device 15220000.nvdisplay to group 34
[ 1.118382] platform 15220000.nvdisplay: OF IOVA linear map 0x9607e000 size (0x800000)
[ 1.126672] arm__alloc_iova_at():136: iova alloc don't match, dh=0x000000009607e000, da=0x000000009587b000
[ 1.136748] platform 15220000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x2008)
[ 1.144825] arm__alloc_iova_at():136: iova alloc don't match, dh=0x000000009607b000, da=0x0000000096078000
[ 1.155526] iommu: Adding device 15340000.vic to group 35
[ 1.161484] iommu: Adding device 154c0000.nvenc to group 36
[ 1.167603] iommu: Adding device 15480000.nvdec to group 37
[ 1.173901] iommu: Adding device 15380000.nvjpg to group 38
[ 1.180067] iommu: Adding device 15500000.tsec to group 39
[ 1.186120] iommu: Adding device 15100000.tsecb to group 40
[ 1.192957] iommu: Adding device 15810000.se to group 41
[ 1.198814] iommu: Adding device 15820000.se to group 42
[ 1.204704] iommu: Adding device 15830000.se to group 43
[ 1.210562] iommu: Adding device 15840000.se to group 44
[ 1.217343] iommu: Adding device smmu_test to group 45
[ 1.223561] mc: mapped MMIO address: 0xffffff800a610000 -> 0x2c10000
[ 1.230216] mc: mapped MMIO address: 0xffffff800a630000 -> 0x2c20000
[ 1.236872] mc: mapped MMIO address: 0xffffff800a650000 -> 0x2c30000
[ 1.243530] mc: mapped MMIO address: 0xffffff800a670000 -> 0x2c40000
[ 1.250188] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c50000
[ 1.256833] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 1.262115] mc-err: mcerr ops are set to t18x
[ 1.266899] dram-ecc: DRAM ECC enabled-MC_ECC_CONTROL:0x0000000d
[ 1.273219] dram-ecc: SCE-R5 is booted with Camera FW
[ 1.278511] dram-ecc: DRAM ECC interrupts handled in Camera FW
[ 1.286174] iommu: Adding device 3530000.xhci to group 46
[ 1.291820] arm-smmu: forcing sodev map for 3530000.xhci
[ 1.297992] iommu: Adding device 3550000.xudc to group 47
[ 1.303636] arm-smmu: forcing sodev map for 3550000.xudc
[ 1.310265] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.316449] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.324505] iommu: Adding device 17000000.gp10b to group 48
[ 1.331805] tegra-reset 5000000.clock: registered 193 resets.
[ 1.340672] iommu: Adding device d000000.bpmp to group 49
[ 1.346845] bpmp: ping status is 0
[ 1.350574] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 1.361791] bpmp d000000.bpmp: probe ok
[ 1.369526] iommu: Adding device 2600000.dma to group 50
[ 1.376464] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 1.383159] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 1.390389] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 1.397587] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 1.404796] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 1.412006] GPIO line 414 (camera-control-output-low) hogged as output/low
[ 1.419484] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.433928] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 1.445364] iommu: Adding device 10003000.pcie-controller to group 51
[ 1.452101] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 1.459179] iommu: Adding device sound to group 52
[ 1.464605] iommu: Adding device 3510000.hda to group 53
[ 1.480247] iommu: Adding device c1a0000.aon to group 54
[ 1.486443] vdd-ac-bat: 5000 mV
[ 1.492065] vdd-1v8-ap: 1800 mV
[ 1.522760] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.534548] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.541441] SCSI subsystem initialized
[ 1.545626] libata version 3.00 loaded.
[ 1.545962] usbcore: registered new interface driver usbfs
[ 1.551743] usbcore: registered new interface driver hub
[ 1.557436] usbcore: registered new device driver usb
[ 1.566117] GPIO line 241 (touch-rails) hogged as output/high
[ 1.572377] GPIO line 242 (touch-rails) hogged as output/high
[ 1.578709] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 1.588446] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 1.595014] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 1.615640] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 1.626060] vddio-ddr: at 1125 mV
[ 1.633547] avdd_dsi_csi: 1200 mV
[ 1.641523] vdd-1v8: 1800 mV
[ 1.649523] vdd-3v3-sys: 3300 mV
[ 1.653681] max77620-sd4: at 600 mV
[ 1.658495] spmic-ldo0: at 1800 mV
[ 1.662956] spmic-ldo1: at 800 mV
[ 1.669528] vddio-3v3: 3300 mV
[ 1.673537] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 1.681544] vdd-rtc: at 800 mV
[ 1.685716] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 1.693528] spmic-ldo6: at 1500 mV
[ 1.701527] vdd-pex-1v00: 1000 mV
[ 1.705936] dvdd-pex: 1000 mV
[ 1.709802] GPIO line 221 (spmic_gpio_input) hogged as input
[ 1.715931] GPIO line 222 (spmic_gpio_input) hogged as input
[ 1.722168] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 1.733846] max77620 4-003c: max77620 probe successful
[ 1.739659] media: Linux media interface: v0.10
[ 1.744430] Linux video capture interface: v2.00
[ 1.752336] pps_core: LinuxPPS API ver. 1 registered
[ 1.757531] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.767077] PTP clock support registered
[ 1.771781] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.779251] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.788654] tegra_fiq_debugger_init: found FIQ source (IRQ 387)
[ 1.799141] Advanced Linux Sound Architecture Driver Initialized.
[ 1.806069] Bluetooth: Core ver 2.22
[ 1.809906] NET: Registered protocol family 31
[ 1.814582] Bluetooth: HCI device and connection manager initialized
[ 1.821265] Bluetooth: HCI socket layer initialized
[ 1.826393] Bluetooth: L2CAP socket layer initialized
[ 1.831724] Bluetooth: SCO socket layer initialized
[ 1.837868] en-vdd-sd: 3300 mV
[ 1.841916] en-vdd-cam: 1800 mV
[ 1.849525] vdd-hdmi: 5000 mV
[ 1.853049] vdd-usb0-5v: 5000 mV
[ 1.856857] vdd-usb1-5v: 5000 mV
[ 1.865899] en-vdd-ts-1v8: 1800 mV
[ 1.873902] en-vdd-ts-hv-3v3: 3300 mV
[ 1.878557] en-vdd-disp-3v3: 3300 mV
[ 1.882997] en-mdm-pwr-3v7: 3700 mV
[ 1.887463] en-vdd-disp-1v8: 1800 mV
[ 1.891954] en-vdd-cam-hv-2v8: 2800 mV
[ 1.896656] en-vdd-cam-1v2: 1200 mV
[ 1.900980] vdd-fan: 5000 mV
[ 1.904436] vdd-3v3: 3300 mV
[ 1.908295] dis-vdd-1v2: 1200 mV
[ 1.912113] en-vdd-vcm-2v8: 2800 mV
[ 1.916574] vdd-usb2-5v: 5000 mV
[ 1.920409] vdd-sys-bl: 3300 mV
[ 1.924418] en-vdd-sys: 1200 mV
[ 1.930651] camchar: rtcpu character device driver loaded
[ 1.936981] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 1.944040] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 1.953181] clocksource: Switched to clocksource arch_sys_counter
[ 1.999895] VFS: Disk quotas dquot_6.6.0
[ 2.004266] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.012120] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.019873] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 2.023461] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 2.033965] nvmap_page_pool_init: Total RAM pages: 1750249
[ 2.034222] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 2.034407] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 2.034825] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.034891] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.034989] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 2.035081] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 2.035217] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 2.035401] la/ptsa driver initialized.
[ 2.035411] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 2.035414] pre_t19x_iso_plat_init(): max_iso_bw=7680000KB
[ 2.036548] NET: Registered protocol family 2
[ 2.038555] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.039246] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 2.040023] TCP: Hash tables configured (established 65536 bind 65536)
[ 2.040073] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 2.040204] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 2.041070] NET: Registered protocol family 1
[ 2.046132] RPC: Registered named UNIX socket transport module.
[ 2.046135] RPC: Registered udp transport module.
[ 2.046138] RPC: Registered tcp transport module.
[ 2.046140] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.046149] PCI: CLS 0 bytes, default 64
[ 2.046390] Trying to unpack rootfs image as initramfs...
[ 2.064981] host1x 13e10000.host1x: initialized
[ 2.067496] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.071010] audit: initializing netlink subsys (disabled)
[ 2.071045] audit: type=2000 audit(1.896:1): initialized
[ 2.071595] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.086616] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.089162] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.090674] 9p: Installing v9fs 9p2000 file system support
[ 2.095722] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.095845] io scheduler noop registered
[ 2.096445] io scheduler cfq registered (default)
[ 2.101618] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 2.165268] iommu: Adding device aconnect@2a41000:adsp_audio to group 55
[ 2.204663] iommu: Adding device 2993000.adsp to group 56
[ 2.205790] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 2.209163] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 2.214037] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.215702] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 2.217117] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.218537] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 2.221331] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 2.222507] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 2.222943] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 2.223895] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 2.224090] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 2.224096] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 2.224102] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=3750000, max_bw=3
916800
[ 2.226063] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 2.227488] tsec 15500000.tsec: initialized
[ 2.229004] tsec 15100000.tsecb: initialized
[ 2.232193] nvdec 15480000.nvdec: initialized
[ 2.237555] falcon 15340000.vic: initialized
[ 2.239154] falcon 154c0000.nvenc: initialized
[ 2.240628] falcon 15380000.nvjpg: initialized
[ 2.244585] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 2.248033] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 2.251693] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 2.255388] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 2.259805] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 2.262997] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 2.265255] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 2.266843] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 2.270224] tegradccommon 15200000.dc_common: host1x channel mapped
[ 2.270231] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 2.270262] tegradccommon 15200000.dc_common: dma mapping done
[ 2.271147] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 2.271218] generic_infoframe_type: 0x87
[ 2.271356] tegradc 15210000.nvdisplay: DT parsed successfully
[ 2.271391] tegradc 15210000.nvdisplay: Display dc.ffffff800b3a0000 registered with id=0
[ 2.280826] pre_t19x_iso_plat_register(): iso bandwidth 5924200KB is not available, client disp_0
[ 2.280931] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 3136300 KB/s
[ 2.280933] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 102000000 Hz
[ 2.280935] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 169820000 Hz
[ 2.281119] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 2.281123] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 2.282313] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm
) pclk=148350937
[ 2.282540] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 2.283825] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.284477] kfuse 3830000.kfuse: initialized
[ 2.284895] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 2.284898] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 2.286519] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 2.287788] tegradc 15210000.nvdisplay: probed
[ 2.290690] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.294000] console [ttyS0] disabled
[ 2.636812] nvmap_page_pool_init: nvmap page pool size: 218781 pages (854 MB)
[ 2.636913] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.651852] Console: switching to colour frame buffer device 240x67
[ 2.658650] tegradc 15210000.nvdisplay: fb registered
[ 2.658661] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 2.673075] console [ttyS0] enabled
[ 2.673375] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 2.673991] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 2.674064] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 2.674136] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 2.680243] Parent Clock set for DC plld2
[ 2.681133] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.742520] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 2.743029] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 2.743038] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 2.743606] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 2.743609] Extcon AUX1(HDMI) enable
[ 2.744252] tegradc 15220000.nvdisplay: disp1 connected to head2->/host1x/sor
[ 2.744284] tegradc 15220000.nvdisplay: tegra_dc_parse_panel_ops: panel: /host1x/sor/dp-display is not act
ive
[ 2.744290] tegradc 15220000.nvdisplay: err:-19 parsing panel_ops
[ 2.868052] bootconsole [uart8250] disabled
[ 2.868132] tegradc 15210000.nvdisplay: blank - powerdown
[ 2.909489] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 2.909492] Extcon AUX1(HDMI) disable
[ 2.933849] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 2.934024] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 2.935623] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 2.951763] tegradc 15210000.nvdisplay: unblank
[ 2.953832] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 2.954001] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 2.954161] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 2.958732] Parent Clock set for DC plld2
[ 2.962426] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 2.963786] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 2.963797] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 2.967603] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 2.967606] Extcon AUX1(HDMI) enable
[ 3.086067] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 3.492222] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 3.494252] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 3.898523] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 4.304714] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 4.710871] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 4.712897] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 4.712907] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 4.713207] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 5.302448] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 5.304373] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 5.305560] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 5.305800] serial-tegra 3130000.serial: RX in PIO mode
[ 5.306785] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 5.307860] [drm] Initialized
[ 5.321235] brd: module loaded
[ 5.326222] loop: module loaded
[ 5.326345] tegra_profiler: version: 1.132, samples/io: 46/26
[ 5.326472] tegra_profiler: auth: init
[ 5.326908] nct1008_nct72 7-004c: starting parse dt
[ 5.326987] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 5.326992] nct1008_nct72 7-004c: success parsing dt
[ 5.327099] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 5.327540] THERMAL EST: found 3 subdevs
[ 5.327544] THERMAL EST num_resources: 0
[ 5.327548] [THERMAL EST subdev 0]
[ 5.327552] [THERMAL EST subdev 1]
[ 5.327555] [THERMAL EST subdev 2]
[ 5.328563] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 5.328566] THERMAL EST: thz register success.
[ 5.328728] THERMAL EST: end of probe, return err: 0
[ 5.330440] hisi_sas: driver version v1.6
[ 5.334749] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 5.334758] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 5.335988] scsi host0: tegra_ahci
[ 5.336969] scsi host1: tegra_ahci
[ 5.337278] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 5.337281] ata2: DUMMY
[ 5.344784] libphy: Fixed MDIO Bus: probed
[ 5.347353] tun: Universal TUN/TAP device driver, 1.6
[ 5.347355] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 5.348117] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 5.348120] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 5.348157] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 5.348159] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 5.348190] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 5.348192] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 5.348222] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 5.348224] Copyright(c) 1999 - 2017 Intel Corporation.
[ 5.349632] eqos 2490000.ether_qos: no PHY interrupt found
[ 5.349812] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 5.353423] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c7 9a af
[ 5.353562] libphy: dwc_phy: probed
[ 5.353988] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 5.356226] PPP generic driver version 2.4.2
[ 5.356435] PPP BSD Compression module registered
[ 5.356439] PPP Deflate Compression module registered
[ 5.356458] PPP MPPE Compression module registered
[ 5.356462] NET: Registered protocol family 24
[ 5.356516] usbcore: registered new interface driver r8152
[ 5.356545] usbcore: registered new interface driver asix
[ 5.356570] usbcore: registered new interface driver ax88179_178a
[ 5.356592] usbcore: registered new interface driver cdc_ether
[ 5.356618] usbcore: registered new interface driver net1080
[ 5.356640] usbcore: registered new interface driver cdc_subset
[ 5.356662] usbcore: registered new interface driver zaurus
[ 5.356694] usbcore: registered new interface driver cdc_ncm
[ 5.356986] VFIO - User Level meta-driver version: 0.3
[ 5.358661] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.358675] ehci-pci: EHCI PCI platform driver
[ 5.358701] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 5.358708] ohci-pci: OHCI PCI platform driver
[ 5.358736] ohci-platform: OHCI generic platform driver
[ 5.359429] nct1008_nct72 7-004c: LOC shutdown limit 110
[ 5.359908] nct1008_nct72 7-004c: EXT shutdown limit 110
[ 5.364150] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 5.366042] tegra-xusb 3530000.xhci: extcon 0: ffffffc1abc75000 id
[ 5.366175] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 5.366180] tegra-xusb 3530000.xhci: Falling back to user helper
[ 5.366570] usbcore: registered new interface driver uas
[ 5.366625] usbcore: registered new interface driver usb-storage
[ 5.366702] usbcore: registered new interface driver usbserial
[ 5.370262] tegra-xudc-new 3550000.xudc: device count: 1
[ 5.371406] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 5.371432] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.372365] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.372712] mousedev: PS/2 mouse device common for all mice
[ 5.372768] usbcore: registered new interface driver xpad
[ 5.392610] nct1008_nct72 7-004c: initial LOC temp: 42000
[ 5.392902] nct1008_nct72 7-004c: initial EXT temp: 54250
[ 5.393556] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 5.393839] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 5.394018] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 5.502805] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 5.504054] Wake73 for irq=42
[ 5.505332] rtc rtc1: alarm rtc device
[ 5.505346] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 5.505370] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 5.505579] i2c /dev entries driver
[ 5.507043] [chiv]: daxc02_probe, no addr needed, [0x17]
[ 5.507173] [chiv] pixel_t : yuv_uyvy8
[ 5.507196] [chiv] pixel_t : yuv_uyvy8
[ 5.507219] [chiv] pixel_t : yuv_uyvy8
[ 5.507240] [chiv] pixel_t : yuv_uyvy8
[ 5.507802] [chiv] pixel_t : yuv_uyvy8
[ 5.507826] daxc02 2-0017: tegracam sensor driver:daxc02_v2.0.6
[ 5.507853] [chiv]: daxc02_probe completed
[ 5.508012] [chiv]: daxc02_probe, no addr needed, [0x20]
[ 5.508096] [chiv] pixel_t : yuv_uyvy8
[ 5.508117] [chiv] pixel_t : yuv_uyvy8
[ 5.508138] [chiv] pixel_t : yuv_uyvy8
[ 5.508161] [chiv] pixel_t : yuv_uyvy8
[ 5.508182] [chiv] pixel_t : yuv_uyvy8
[ 5.508211] daxc02 2-0020: tegracam sensor driver:daxc02_v2.0.6
[ 5.508227] [chiv]: daxc02_probe completed
[ 5.508275] [chiv]: daxc02_probe, no addr needed, [0x30]
[ 5.508372] [chiv] pixel_t : yuv_uyvy8
[ 5.508393] [chiv] pixel_t : yuv_uyvy8
[ 5.508414] [chiv] pixel_t : yuv_uyvy8
[ 5.508436] [chiv] pixel_t : yuv_uyvy8
[ 5.508457] [chiv] pixel_t : yuv_uyvy8
[ 5.508484] daxc02 2-0030: tegracam sensor driver:daxc02_v2.0.6
[ 5.508501] [chiv]: daxc02_probe completed
[ 5.508595] [chiv]: daxc02_probe, no addr needed, [0x40]
[ 5.508720] [chiv] pixel_t : yuv_uyvy8
[ 5.508742] [chiv] pixel_t : yuv_uyvy8
[ 5.508764] [chiv] pixel_t : yuv_uyvy8
[ 5.508785] [chiv] pixel_t : yuv_uyvy8
[ 5.508807] [chiv] pixel_t : yuv_uyvy8
[ 5.508823] daxc02 2-0040: tegracam sensor driver:daxc02_v2.0.6
[ 5.508838] [chiv]: daxc02_probe completed
[ 5.508900] [chiv]: daxc02_probe, no addr needed, [0x50]
[ 5.508980] [chiv] pixel_t : yuv_uyvy8
[ 5.509002] [chiv] pixel_t : yuv_uyvy8
[ 5.509023] [chiv] pixel_t : yuv_uyvy8
[ 5.509044] [chiv] pixel_t : yuv_uyvy8
[ 5.509066] [chiv] pixel_t : yuv_uyvy8
[ 5.509081] daxc02 2-0050: tegracam sensor driver:daxc02_v2.0.6
[ 5.509096] [chiv]: daxc02_probe completed
[ 5.509138] [chiv]: daxc02_probe, no addr needed, [0x60]
[ 5.509245] [chiv] pixel_t : yuv_uyvy8
[ 5.509265] [chiv] pixel_t : yuv_uyvy8
[ 5.509286] [chiv] pixel_t : yuv_uyvy8
[ 5.509307] [chiv] pixel_t : yuv_uyvy8
[ 5.509329] [chiv] pixel_t : yuv_uyvy8
[ 5.509357] daxc02 2-0060: tegracam sensor driver:daxc02_v2.0.6
[ 5.509372] [chiv]: daxc02_probe completed
[ 5.509826] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 5.514160] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 5.514771] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 5.516178] parse_throttle_dt_data: Num cap clks = 4
[ 5.516182] parse_throttle_dt_data: clk=mcpu type=1
[ 5.516185] parse_throttle_dt_data: clk=bcpu type=2
[ 5.516192] parse_throttle_dt_data: clk=gpu type=4
[ 5.516195] parse_throttle_dt_data: clk=emc type=3
[ 5.517380] tegra_throttle_probe: probe successful. #cdevs=4
[ 5.517959] FAN dev name: pwm-fan
[ 5.518016] FAN:gpio request success.
[ 5.518024] FAN: can't find tach_gpio
[ 5.518049] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 5.518351] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 5.518356] pwm_fan_driver pwm-fan: tach period: 1000
[ 5.518724] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 5.518729] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 5.518733] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 5.518736] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 5.518740] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 5.518744] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 5.518748] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 5.518751] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.518755] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.518759] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.520645] device-mapper: uevent: version 1.0.3
[ 5.522016] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.536744] cpufreq: platform driver Initialization: pass
[ 5.543277] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 5.543398] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 5.547585] sdhci: Secure Digital Host Controller Interface driver
[ 5.547587] sdhci: Copyright(c) Pierre Ossman
[ 5.547589] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.549124] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.551107] CMDQ: cmdq_platfm_init successful
[ 5.552241] CQE: CMD_TIMING bit set for R1B DCMD
[ 5.554775] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 5.559476] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.559517] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 5.560134] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 5.561924] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 258
[ 5.565624] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 5.566496] tegra-se-nvhost 15810000.se: initialized
[ 5.567659] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.568255] tegra-se-nvhost 15820000.se: initialized
[ 5.569304] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.569867] tegra-se-nvhost 15830000.se: initialized
[ 5.570716] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.571255] tegra-se-nvhost 15840000.se: initialized
[ 5.572221] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.572465] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.573444] usbcore: registered new interface driver usbhid
[ 5.573445] usbhid: USB HID core driver
[ 5.580362] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.582559] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 5.582813] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480
-0x1900
[ 5.582933] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80
-0x2200
[ 5.583150] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[6
4x128]=0x4280-0x6300
[ 5.583889] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c
0-0x6480
[ 5.583989] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900
TX[16x320]=0x7900-0x8d80
[ 5.584040] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 T
X[16x64]=0x9200-0x9680
[ 5.584089] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x988
0-0x9a80
[ 5.584232] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xb
b00-0xdb80
[ 5.584562] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 5.584564] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.585562] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f23
8c025334776c9a96
[ 5.587279] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 5.587741] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 5.587909] register_ari_mca_banks: Registered MCA ROC:IOB
[ 5.587981] register_ari_mca_banks: Registered MCA ROC:CCE
[ 5.588298] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588300] tegra18-bridge 2390000.axi2apb: enabled timeout = 16684000
[ 5.588301] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 5.588350] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588352] tegra18-bridge 23a0000.axi2apb: enabled timeout = 16684000
[ 5.588353] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 5.588399] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588401] tegra18-bridge 23b0000.axi2apb: enabled timeout = 16684000
[ 5.588402] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 5.588452] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588454] tegra18-bridge 23c0000.axi2apb: enabled timeout = 16684000
[ 5.588455] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 5.588500] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588501] tegra18-bridge 23d0000.axi2apb: enabled timeout = 16684000
[ 5.588503] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 5.588547] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588550] tegra18-bridge 2100000.axip2p: enabled timeout = 16684000
[ 5.588552] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 5.588596] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588599] tegra18-bridge 2110000.axip2p: enabled timeout = 16684000
[ 5.588601] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 5.588646] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588649] tegra18-bridge 2120000.axip2p: enabled timeout = 16684000
[ 5.588650] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 5.588705] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588709] tegra18-bridge 2130000.axip2p: enabled timeout = 16684000
[ 5.588710] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 5.588757] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588759] tegra18-bridge 2140000.axip2p: enabled timeout = 16684000
[ 5.588760] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 5.588805] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588809] tegra18-bridge 2150000.axip2p: enabled timeout = 16684000
[ 5.588810] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 5.588861] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588864] tegra18-bridge 2160000.axip2p: enabled timeout = 16684000
[ 5.588866] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 5.588911] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588915] tegra18-bridge 2170000.axip2p: enabled timeout = 16684000
[ 5.588916] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 5.588960] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.588964] tegra18-bridge 2180000.axip2p: enabled timeout = 16684000
[ 5.588965] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 5.589010] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 5.589013] tegra18-bridge 2190000.axip2p: enabled timeout = 16684000
[ 5.589015] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 5.589066] **** A57 ECC: Enabled
[ 5.589067] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 5.589130] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 5.589660] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 5.593024] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 5.593148] denver_knobs_init:MTS_VERSION:43068234
[ 5.600421] nvpmodel: initialized successfully
[ 5.601476] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.602071] usbcore: registered new interface driver snd-usb-audio
[ 5.605657] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.613329] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 5.613384] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.616168] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 5.616302] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 5.655551] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.670747] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 5.681161] OPE platform probe
[ 5.681245] OPE platform probe successful
[ 5.683256] tegra-asoc: sound: This is a dummy codec
[ 5.685316] mmc0: periodic cache flush enabled
[ 5.685330] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.685929] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 5.686158] mmcblk0boot0: mmc0:0001 032G34 partition 1 8.00 MiB
[ 5.686342] mmcblk0boot1: mmc0:0001 032G34 partition 2 8.00 MiB
[ 5.686516] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 5.689196] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p
24 p25 p26 p27 p28 p29 p30 p31
[ 5.728565] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.728646] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.728715] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.728785] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.728856] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.728931] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.729002] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.729073] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.729146] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.729238] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.729311] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 5.729380] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 5.729452] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 5.729523] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 5.729592] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 5.729664] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 5.729733] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 5.729805] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 5.729875] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 5.729953] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 5.757185] random: crng init done
[ 5.758797] u32 classifier
[ 5.758799] Actions configured
[ 5.758881] Initializing XFRM netlink socket
[ 5.760855] NET: Registered protocol family 10
[ 5.762300] NET: Registered protocol family 17
[ 5.762312] NET: Registered protocol family 15
[ 5.762532] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts
to load br_netfilter if you need this.
[ 5.762608] Bluetooth: RFCOMM socket layer initialized
[ 5.762621] Bluetooth: RFCOMM ver 1.11
[ 5.762627] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.762631] Bluetooth: HIDP socket layer initialized
[ 5.762673] 9pnet: Installing 9P2000 support
[ 5.762726] Key type dns_resolver registered
[ 5.768354] Registered cp15_barrier emulation handler
[ 5.768372] Registered setend emulation handler
[ 5.769898] registered taskstats version 1
[ 5.773550] isp 15600000.isp: initialized
[ 5.778136] nvcsi 150c0000.nvcsi: initialized
[ 5.785447] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 5.785515] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 5.785573] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 5.785736] input: gpio-keys as /devices/gpio-keys/input/input2
[ 5.786999] tegra-vi4 15700000.vi: initialized
[ 5.787881] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--6 bound
[ 5.787894] tegra-vi4 15700000.vi: subdev daxc02 2-0017 bound
[ 5.788494] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--5 bound
[ 5.788498] tegra-vi4 15700000.vi: subdev daxc02 2-0020 bound
[ 5.788976] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--4 bound
[ 5.788980] tegra-vi4 15700000.vi: subdev daxc02 2-0030 bound
[ 5.789457] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--3 bound
[ 5.789460] tegra-vi4 15700000.vi: subdev daxc02 2-0040 bound
[ 5.789938] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[ 5.789942] tegra-vi4 15700000.vi: subdev daxc02 2-0050 bound
[ 5.790442] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 5.790446] tegra-vi4 15700000.vi: subdev daxc02 2-0060 bound
[ 5.819477] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:18:58 UTC (946689538)
[ 5.820824] mmcblk mmc0:0001: Card claimed for testing.
[ 5.851840] bpmp: mounted debugfs mirror
[ 5.853482] bwmgr: missing cdev-type property
[ 5.859213] spmic-ldo0: disabling
[ 5.859416] spmic-ldo1: disabling
[ 5.859576] en-vdd-sd: disabling
[ 5.859578] en-vdd-cam: disabling
[ 5.859580] vdd-usb0-5v: disabling
[ 5.859582] vdd-usb1-5v: disabling
[ 5.859584] en-vdd-disp-3v3: disabling
[ 5.859586] en-mdm-pwr-3v7: disabling
[ 5.859587] en-vdd-disp-1v8: disabling
[ 5.859613] en-vdd-cam-hv-2v8: disabling
[ 5.859615] en-vdd-cam-1v2: disabling
[ 5.859617] vdd-fan: disabling
[ 5.859618] vdd-3v3: disabling
[ 5.859621] en-vdd-vcm-2v8: disabling
[ 5.859623] vdd-usb2-5v: disabling
[ 5.859624] vdd-sys-bl: disabling
[ 5.859626] en-vdd-sys: disabling
[ 5.859628] ALSA device list:
[ 5.859639] #0: tegra-hda at 0x3518000 irq 384
[ 5.859641] #1: tegra-snd-t186ref-mobile-rt565x
[ 7.345729] Extcon HDMI: HPD enabled
[ 7.345778] tegradc 15210000.nvdisplay: hdmi: plugged
[ 7.689967] EXT4-fs (mmcblk0p1): 4 orphan inodes deleted
[ 7.695307] EXT4-fs (mmcblk0p1): recovery complete
[ 7.709153] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.717293] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.725107] devtmpfs: mounted
[ 7.730883] Freeing unused kernel memory: 8448K
[ 7.836914] systemd[1]: System time before build time, advancing clock.
[ 7.879398] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.928723] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.949567] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +S
YSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2
default-hierarchy=hybrid)
[ 7.974301] systemd[1]: Detected architecture arm64.
[ 8.103690] systemd[1]: Set hostname to <nvidia-desktop>.
[ 8.189993] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IP
AddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.207084] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the firs
t loaded unit using IP firewalling.)
[ 8.329094] systemd[1]: /lib/systemd/system/sysdump.service:6: Executable path is not absolute: sysctl -w
kernel.core_pattern="|/usr/local/bin/sysdump --pid %%p --exe %%E"
[ 8.424038] systemd[1]: sysdump.service: Cannot add dependency job, ignoring: Unit sysdump.service is not
loaded properly: Exec format error.
[ 8.443780] systemd[1]: Created slice User and Session Slice.
[ 8.463106] systemd[1]: Created slice System Slice.
[ 8.483122] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 8.667620] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.096197] systemd-journald[2295]: Received request to flush runtime journal from PID 1
[ 9.843026] tegra-xusb 3530000.xhci: cannot find firmware....retry after 1 second
[ 10.063136] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[ 10.070983] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[ 10.076886] bmi160 1-0069: bmi_init _id_i2c ERR
[ 10.088056] bmi160 1-0069: bmi_remove
[ 10.088059] bmi160 1-0069: bmi_probe done
[ 10.527777] using random self ethernet address
[ 10.534352] using random host ethernet address
[ 10.570389] Mass Storage Function, version: 2009/09/11
[ 10.570397] LUN: removable file: (no medium)
[ 10.579673] using random self ethernet address
[ 10.589215] using random host ethernet address
[ 10.598017] rndis0: HOST MAC e6:20:47:5d:4a:14
[ 10.598273] rndis0: MAC e6:20:47:5d:4a:15
[ 10.600357] usb0: HOST MAC e6:20:47:5d:4a:16
[ 10.600442] usb0: MAC e6:20:47:5d:4a:17
[ 10.600464] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 10.602504] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 10.602522] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 10.602553] tegra-xudc-new 3550000.xudc: entering ELPG
[ 10.603427] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 10.603446] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 10.604973] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 10.604993] tegra-xudc-new 3550000.xudc: entering ELPG
[ 10.606201] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 10.709675] l4tbr0: port 1(rndis0) entered blocking state
[ 10.709679] l4tbr0: port 1(rndis0) entered disabled state
[ 10.709845] device rndis0 entered promiscuous mode
[ 10.717584] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 10.733411] l4tbr0: port 2(usb0) entered blocking state
[ 10.733418] l4tbr0: port 2(usb0) entered disabled state
[ 10.734262] device usb0 entered promiscuous mode
[ 10.746874] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.746882] l4tbr0: port 2(usb0) entered blocking state
[ 10.746884] l4tbr0: port 2(usb0) entered forwarding state
[ 10.861231] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 10.889282] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 10.889819] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 10.890645] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 10.890685] tegra-xusb 3530000.xhci: irq 71, io mem 0x03530000
[ 10.890817] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.891354] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.891358] usb usb1: Product: xHCI Host Controller
[ 10.891362] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 10.891365] usb usb1: SerialNumber: 3530000.xhci
[ 10.892483] hub 1-0:1.0: USB hub found
[ 10.892509] hub 1-0:1.0: 4 ports detected
[ 10.892837] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 10.892845] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 10.892974] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 10.892977] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.892980] usb usb2: Product: xHCI Host Controller
[ 10.892982] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 10.892984] usb usb2: SerialNumber: 3530000.xhci
[ 10.893437] hub 2-0:1.0: USB hub found
[ 10.893501] hub 2-0:1.0: 3 ports detected
[ 10.895030] Wake76 for irq=199
[ 10.895032] Wake77 for irq=199
[ 10.895033] Wake78 for irq=199
[ 10.895034] Wake79 for irq=199
[ 10.895034] Wake80 for irq=199
[ 10.895035] Wake81 for irq=199
[ 10.895036] Wake82 for irq=199
[ 10.993422] usb usb1: usb_suspend_both: status 0
[ 10.997457] usb usb2: usb_suspend_both: status 0
[ 11.625236] l4tbr0: port 2(usb0) entered disabled state
[ 12.969275] tegra-xusb 3530000.xhci: entering ELPG
[ 12.972363] tegra-xusb 3530000.xhci: entering ELPG done
[ 15.110303] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 15.114795] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.990447] nvgpu: 17000000.gp10b railgate_enable_store:343 [INFO] railgate is disabled.
[ 16.337886] CPU1: shutdown
[ 16.340641] psci: CPU1 killed.
[ 16.409926] CPU2: shutdown
[ 16.413698] psci: CPU2 killed.
[ 18.091768] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 18.093315] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.455392] Netfilter messages via NETLINK v0.30.
[ 26.481239] device eth0 entered promiscuous mode
[ 26.481771] device l4tbr0 entered promiscuous mode
[ 27.428864] tegradc 15210000.nvdisplay: blank - powerdown
[ 27.480606] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 27.480608] Extcon AUX1(HDMI) disable
[ 27.502451] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 27.502531] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 27.502989] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 27.503119] tegradc 15210000.nvdisplay: unblank
[ 27.503672] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 27.503748] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd[ 27.503821] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd[ 27.505009] Parent Clock set for DC plld2[ 27.508635] tegradc 15210000.nvdisplay: hdmi: tmds rate:78750K prod-setting:prod_c_hdmi_54m_111m[ 27.509837] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.[ 27.509843] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.[ 27.513319] extcon-disp-state external-connection:disp-state: cable 47 state 1[ 27.513321] Extcon AUX1(HDMI) enable[ 27.513368] tegradc 15210000.nvdisplay: unblank[ 28.209267] fuse init (API version 7.26)[ 28.978197] tegradc 15210000.nvdisplay: unblank[ 321.138113] Bluetooth: BNEP (Ethernet Emulation) ver 1.3[ 321.138126] Bluetooth: BNEP socket layer initialized[ 321.614255] tegradc 15210000.nvdisplay: blank - powerdown[ 321.664240] extcon-disp-state external-connection:disp-state: cable 47 state 0[ 321.664242] Extcon AUX1(HDMI) disable[ 321.683444] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd[ 321.683520] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd[ 321.683960] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd[ 321.684976] tegradc 15210000.nvdisplay: unblank[ 321.688940] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd[ 321.689022] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd[ 321.689094] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd[ 321.693287] Parent Clock set for DC plld2[ 321.700691] tegradc 15210000.nvdisplay: hdmi: tmds rate:65000K prod-setting:prod_c_hdmi_54m_111m[ 321.702203] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.[ 321.702210] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.[ 321.705775] extcon-disp-state external-connection:disp-state: cable 47 state 1[ 321.705778] Extcon AUX1(HDMI) enable[ 321.705870] tegradc 15210000.nvdisplay: unblank
