[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5374-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sun Apr 17 02:37:44 PDT 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2033152
[ 0.000000] DMA zone: 7192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 460288 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2001384
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30136(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190624K/8132608K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 188320K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008945] Console: colour dummy device 80x25
[ 0.012429] console [tty0] enabled
[ 0.016117] bootconsole [tegra_comb_uart0] disabled
[ 0.020849] kmemleak: Kernel memory leak detector disabled
[ 0.020885] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.020924] pid_max: default: 32768 minimum: 301
[ 0.022028] Security Framework initialized
[ 0.022588] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022616] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.024147] ftrace: allocating 47098 entries in 184 pages
[ 0.429843] sched-energy: Sched-energy-costs installed from DT
[ 0.429879] ASID allocator initialised with 65536 entries
[ 0.464762] tegra-id: chipid=21917.
[ 0.464790] tegra-id: opt_subrevision=1.
[ 0.464830] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.464905] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.464969] DTB Build time: Apr 17 2022 02:42:31
[ 0.512900] CPU1: Booted secondary processor [4e0f0040]
[ 0.545053] CPU2: Booted secondary processor [4e0f0040]
[ 0.577166] CPU3: Booted secondary processor [4e0f0040]
[ 0.609473] CPU4: Booted secondary processor [4e0f0040]
[ 0.641583] CPU5: Booted secondary processor [4e0f0040]
[ 0.641833] Brought up 6 CPUs
[ 0.641993] SMP: Total of 6 processors activated.
[ 0.642053] CPU features: detected feature: Privileged Access Never
[ 0.642110] CPU features: detected feature: LSE atomic instructions
[ 0.642153] CPU features: detected feature: User Access Override
[ 0.642180] CPU features: detected feature: 32-bit EL0 Support
[ 0.643739] CPU: All CPU(s) started at EL2
[ 0.643805] alternatives: patching kernel code
[ 0.650916] devtmpfs: initialized
[ 0.689289] Initilizing CustomIPI irq domain
[ 0.689506] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.689543] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.698915] pinctrl core: initialized pinctrl subsystem
[ 0.699143] OS set in device tree is not L4T.
[ 0.699393] regulator-dummy: no parameters
[ 0.699615] Initializing plugin-manager
[ 0.699693] Plugin module not found
[ 0.699740] Plugin-manager status disabled
[ 0.700917] NET: Registered protocol family 16
[ 0.707556] pstore: using zlib compression
[ 0.708410] console [pstore-1] enabled
[ 0.708450] pstore: Registered ramoops as persistent store backend
[ 0.708475] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.724825] cpuidle: using governor menu
[ 0.725834] bpmp: waiting for handshake
[ 0.725867] bpmp: handshake completed
[ 0.725907] bpmp: synchronizing channels
[ 0.725935] bpmp: channels synchronized
[ 0.725956] bpmp: mail init ok
[ 0.728322] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.728502] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.728524] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.728569] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.728588] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.728607] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.728628] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.728675] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.728701] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.728721] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.728770] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.731582] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.731634] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.734538] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.735684] tegra_aon_clk_init: ok
[ 0.735717] Registering BPMP clocks…
[ 0.735839] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.736422] Serial: AMBA PL011 UART driver
[ 0.736568] tegra_powergate_init: DONE
[ 0.736659] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.736701] DTB Build time: Apr 17 2022 02:42:31
[ 0.739278] Tegra reboot handler registered.
[ 0.746142] iommu: Adding device 14160000.pcie to group 0
[ 0.746797] iommu: Adding device 141a0000.pcie to group 1
[ 0.747945] iommu: Adding device 2490000.ether_qos to group 2
[ 0.748434] iommu: Adding device 3100000.serial to group 3
[ 0.748863] iommu: Adding device 3110000.serial to group 4
[ 0.749255] iommu: Adding device 3140000.serial to group 5
[ 0.749831] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.750053] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.750097] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.750119] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.750140] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.750202] tegra-pmc: PMC Prod config success
[ 0.750381] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.750425] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.750751] iommu: Adding device 3460000.sdhci to group 6
[ 0.751209] iommu: Adding device 3210000.spi to group 7
[ 0.751588] iommu: Adding device 3230000.spi to group 8
[ 0.751928] iommu: Adding device 3270000.spi to group 9
[ 0.752838] iommu: Adding device 3160000.i2c to group 10
[ 0.753248] iommu: Adding device c240000.i2c to group 11
[ 0.753672] iommu: Adding device 3180000.i2c to group 12
[ 0.754032] iommu: Adding device 3190000.i2c to group 13
[ 0.754509] iommu: Adding device 31b0000.i2c to group 14
[ 0.754883] iommu: Adding device 31c0000.i2c to group 15
[ 0.755279] iommu: Adding device c250000.i2c to group 16
[ 0.755645] iommu: Adding device 31e0000.i2c to group 17
[ 0.756226] iommu: Adding device sound to group 18
[ 0.756710] iommu: Adding device 3510000.hda to group 19
[ 0.757352] iommu: Adding device bc00000.rtcpu to group 20
[ 0.759347] iommu: Adding device 13e10000.host1x to group 21
[ 0.759734] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.760091] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.760456] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.760810] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.761225] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.761571] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.761930] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.762308] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.762796] iommu: Adding device 15340000.vic to group 30
[ 0.763204] iommu: Adding device 15380000.nvjpg to group 31
[ 0.763490] iommu: Adding device 15500000.tsec to group 32
[ 0.763753] iommu: Adding device 15100000.tsecb to group 33
[ 0.764036] iommu: Adding device 15480000.nvdec to group 34
[ 0.764337] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.764606] iommu: Adding device 154c0000.nvenc to group 36
[ 0.764886] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.765351] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.765743] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.766298] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.770519] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.770620] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.771279] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.771357] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.773110] iommu: Adding device 15c10000.vi to group 42
[ 0.773289] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.773676] iommu: Adding device 14800000.isp to group 43
[ 0.774518] iommu: Adding device 16000000.pva0 to group 44
[ 0.775022] iommu: Adding device 16800000.pva1 to group 45
[ 0.775375] iommu: Adding device 15810000.se to group 46
[ 0.775858] iommu: Adding device 15820000.se to group 47
[ 0.776160] iommu: Adding device 15830000.se to group 48
[ 0.776447] iommu: Adding device 15840000.se to group 49
[ 0.776702] iommu: Adding device c1a0000.aon to group 50
[ 0.778226] iommu: Adding device d000000.bpmp to group 51
[ 0.778643] bpmp: ping status is 0
[ 0.778833] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.782315] bpmp d000000.bpmp: probe ok
[ 0.784112] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.784539] iommu: Adding device smmu_test to group 52
[ 0.785571] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c10000
[ 0.785623] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c20000
[ 0.785669] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c30000
[ 0.785716] mc: mapped MMIO address: 0xffffff800b010000 → 0x2c40000
[ 0.785760] mc: mapped MMIO address: 0xffffff800b030000 → 0x2c50000
[ 0.785805] mc: mapped MMIO address: 0xffffff800b050000 → 0x2b80000
[ 0.785849] mc: mapped MMIO address: 0xffffff800b070000 → 0x2b90000
[ 0.785893] mc: mapped MMIO address: 0xffffff800b090000 → 0x2ba0000
[ 0.785935] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x2bb0000
[ 0.785977] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1700000
[ 0.786019] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1710000
[ 0.786060] mc: mapped MMIO address: 0xffffff800b110000 → 0x1720000
[ 0.786102] mc: mapped MMIO address: 0xffffff800b130000 → 0x1730000
[ 0.786144] mc: mapped MMIO address: 0xffffff800b150000 → 0x1740000
[ 0.786186] mc: mapped MMIO address: 0xffffff800b170000 → 0x1750000
[ 0.786228] mc: mapped MMIO address: 0xffffff800b190000 → 0x1760000
[ 0.786295] mc: mapped MMIO address: 0xffffff800b1b0000 → 0x1770000
[ 0.786412] mc-err: mcerr ops are set to t19x
[ 0.791431] iommu: Adding device 2600000.dma to group 53
[ 0.795944] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.797163] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.797229] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.797287] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.797584] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.802645] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.802750] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.802811] GPIO line 266 (w-disable1) hogged as output/high
[ 0.802866] GPIO line 264 (w-disable2) hogged as output/high
[ 0.802920] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.803147] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.804968] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.804995] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.805017] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.806092] iommu: Adding device 3550000.xudc to group 54
[ 0.806800] iommu: Adding device 3610000.xhci to group 55
[ 0.808838] arm64_ras arm64_ras: probed
[ 0.809227] ras_fhi_enable: FHI 469 enabled on CPU0
[ 0.809296] ras_fhi_enable: FHI 470 enabled on CPU1
[ 0.809374] ras_fhi_enable: FHI 471 enabled on CPU2
[ 0.809474] ras_fhi_enable: FHI 472 enabled on CPU3
[ 0.809601] ras_fhi_enable: FHI 473 enabled on CPU4
[ 0.809728] ras_fhi_enable: FHI 474 enabled on CPU5
[ 0.809980] carmel_ras_enable: RAS enabled on cpu0
[ 0.810179] carmel_ras_enable: RAS enabled on cpu1
[ 0.810376] carmel_ras_enable: RAS enabled on cpu2
[ 0.810580] carmel_ras_enable: RAS enabled on cpu3
[ 0.810798] carmel_ras_enable: RAS enabled on cpu4
[ 0.811040] carmel_ras_enable: RAS enabled on cpu5
[ 0.811136] carmel_ras carmel_ras: probed
[ 0.812222] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 0.812708] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.813586] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.814513] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.815374] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.815715] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.816866] vdd-ac-bat: 5000 mV
[ 0.817378] vdd-sdmmc1-sw: 3300 mV
[ 0.817720] vdd-1v8-sd: 1800 mV
[ 0.818016] vdd-3v3-cvb: 3300 mV
[ 0.818287] vdd-1v8-cvb: 1800 mV
[ 0.818628] vdd-epb-1v0: 1000 mV
[ 0.818855] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.819166] avdd-cam-2v8: 2800 mV
[ 0.819472] vdd-fan: 5000 mV
[ 0.819749] vdd-hdmi-5v0: 5000 mV
[ 0.820009] vdd_sys_en: 1200 mV
[ 0.850926] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.854936] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.855243] SCSI subsystem initialized
[ 0.855455] libata version 3.00 loaded.
[ 0.855620] usbcore: registered new interface driver usbfs
[ 0.855701] usbcore: registered new interface driver hub
[ 0.855769] usbcore: registered new device driver usb
[ 0.867091] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.869899] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.878048] vdd-1v0: at 1000 mV
[ 0.886059] vdd-1v8-hs: at 1800 mV
[ 0.894088] vdd-1v8-ls: at 1800 mV
[ 0.902161] vdd-1v8-ao: at 1800 mV
[ 0.910157] vddio-ddr-1v1: at 1100 mV
[ 0.917952] vdd-rtc: at 800 mV
[ 0.918955] spmic-ldo1: at 2375 mV
[ 0.930001] vdd-ao-3v3: at 3300 mV
[ 0.942062] vddio-emmc-3v3: at 3300 mV
[ 0.943204] spmic-ldo4: at 1587 mV
[ 0.954090] vdd-usb-3v3: at 3300 mV
[ 0.966164] vddio-sdmmc1-3v3: at 3300 mV
[ 0.974168] vdd-csi-1v2: at 1200 mV
[ 0.975183] spmic-ldo8: at 1800 mV
[ 0.979288] GPIO line 246 (gpio_default) hogged as output/high
[ 0.980248] GPIO line 247 (gpio_default) hogged as output/high
[ 0.980480] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.980717] max77620 4-003c: max77620 probe successful
[ 0.981515] media: Linux media interface: v0.10
[ 0.981601] Linux video capture interface: v2.00
[ 0.982957] pps_core: LinuxPPS API ver. 1 registered
[ 0.982977] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.983020] PTP clock support registered
[ 0.983234] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.983604] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.983676] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.986245] trusty trusty: trusty version: Built: 02:25:37 Apr 17 2022
[ 0.986354] trusty trusty: selected api version: 3 (requested 3)
[ 0.987441] Advanced Linux Sound Architecture Driver Initialized.
[ 0.988074] Bluetooth: Core ver 2.22
[ 0.988191] NET: Registered protocol family 31
[ 0.988212] Bluetooth: HCI device and connection manager initialized
[ 0.988238] Bluetooth: HCI socket layer initialized
[ 0.988260] Bluetooth: L2CAP socket layer initialized
[ 0.988295] Bluetooth: SCO socket layer initialized
[ 0.990973] camchar: rtcpu character device driver loaded
[ 0.991413] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.991509] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.992208] clocksource: Switched to clocksource arch_sys_counter
[ 1.032413] VFS: Disk quotas dquot_6.6.0
[ 1.032525] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.032866] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.034817] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.034898] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.035158] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.035181] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.035207] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.035233] nvmap_page_pool_init: Total RAM pages: 1986072
[ 1.035252] nvmap_page_pool_init: nvmap page pool size: 248259 pages (969 MB)
[ 1.035531] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.035873] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.036578] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.047570] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.047800] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.047993] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.048171] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.048360] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.049541] la/ptsa driver initialized.
[ 1.049897] NET: Registered protocol family 2
[ 1.050027] IP idents hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.053898] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.054290] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.054919] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.054980] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.055120] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.055584] NET: Registered protocol family 1
[ 1.056173] RPC: Registered named UNIX socket transport module.
[ 1.056285] RPC: Registered udp transport module.
[ 1.056304] RPC: Registered tcp transport module.
[ 1.056322] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.056347] PCI: CLS 0 bytes, default 64
[ 1.056618] Trying to unpack rootfs image as initramfs…
[ 1.279506] Freeing initrd memory: 7068K
[ 1.295360] host1x 13e10000.host1x: initialized
[ 1.296986] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.301344] audit: initializing netlink subsys (disabled)
[ 1.301410] audit: type=2000 audit(0.908:1): initialized
[ 1.301984] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.307688] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.308511] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.308927] 9p: Installing v9fs 9p2000 file system support
[ 1.314188] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.314345] io scheduler noop registered
[ 1.314510] io scheduler cfq registered (default)
[ 1.318084] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.322094] iommu: Adding device 2993000.adsp to group 56
[ 1.332541] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.332737] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.334167] random: fast init done
[ 1.344410] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.344859] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.345390] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.345741] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.346092] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.348713] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.348929] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.351545] tsec 15500000.tsec: initialized
[ 1.353104] tsec 15100000.tsecb: initialized
[ 1.356554] nvdec 15480000.nvdec: initialized
[ 1.358957] nvdec 15140000.nvdec1: initialized
[ 1.364391] falcon 15340000.vic: initialized
[ 1.366175] falcon 15380000.nvjpg: initialized
[ 1.368047] falcon 154c0000.nvenc: initialized
[ 1.370009] falcon 15a80000.nvenc1: initialized
[ 1.372939] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.374828] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.376342] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.377631] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.379015] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.380425] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.381804] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.383133] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.386582] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.391429] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.391771] scare-pigeon 14b00000.isp-thi: initialized
[ 1.397227] pva 16000000.pva0: initialized
[ 1.403101] pva 16800000.pva1: initialized
[ 1.407822] nvdla 15880000.nvdla0: initialized
[ 1.412690] nvdla 158c0000.nvdla1: initialized
[ 1.414067] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.414099] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.414165] tegradccommon 15200000.dc_common: dma mapping done
[ 1.414776] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.414845] generic_infoframe_type: 0x87
[ 1.414936] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.414999] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 1.418821] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.418853] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.418875] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.419150] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.419176] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.422179] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.422209] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.425197] tegradc 15200000.nvdisplay: probed
[ 1.425695] Console: switching to colour frame buffer device 80x30
[ 1.425753] tegradc 15200000.nvdisplay: fb registered
[ 1.425983] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.426359] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.426412] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.426548] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.426602] tegradc 15210000.nvdisplay: Display dc.ffffff800be50000 registered with id=1
[ 1.426819] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.426866] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.436116] tegradc 15210000.nvdisplay: probed
[ 1.436436] tegradc 15210000.nvdisplay: fb registered
[ 1.439997] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.440048] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.440076] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.440102] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.440127] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.440145] Extcon DP: HPD disabled
[ 1.440160] hpd: hpd_switch 0
[ 1.440177] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.440254] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.440276] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.440580] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.440613] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.440892] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.441007] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.441155] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.441176] tegra_cec 3960000.tegra_cec: probed
[ 1.450794] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.451615] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.451645] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.451990] kfuse 3830000.kfuse: initialized
[ 1.457200] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.459739] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.461217] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.462186] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 2.468776] tegra_cec 3960000.tegra_cec: Can’t find physical addresse.
[ 2.468784] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 4.009996] console [ttyTCU0] enabled
[ 4.013804] [drm] Initialized
[ 4.026265] brd: module loaded
[ 4.030553] loop: module loaded
[ 4.030695] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.030930] tegra_profiler: auth: init
[ 4.032617] THERMAL EST: found 3 subdevs
[ 4.035981] THERMAL EST num_resources: 0
[ 4.039739] [THERMAL EST subdev 0]
[ 4.043421] [THERMAL EST subdev 1]
[ 4.046640] [THERMAL EST subdev 2]
[ 4.049799] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.056179] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.065190] THERMAL EST: thz register success.
[ 4.069565] THERMAL EST: end of probe, return err: 0
[ 4.074934] sd: No Scsi addr parsed to reserve index
[ 4.079664] hisi_sas: driver version v1.6
[ 4.092653] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 4.092781] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 4.094579] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 4.106267] 1 ofpart partitions found on MTD device spi6.0
[ 4.111502] Creating 1 MTD partitions on “spi6.0”:
[ 4.116228] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 4.123889] libphy: Fixed MDIO Bus: probed
[ 4.126683] tun: Universal TUN/TAP device driver, 1.6
[ 4.131178] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.137963] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.143339] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.149678] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.156367] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.162026] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.169842] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.175927] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 4.183580] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 4.435369] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.436170] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5a 85 3c
[ 4.436353] Using phyrst_lpmode = 1 from DT
[ 4.436525] libphy: dwc_phy: probed
[ 4.438637] PPP generic driver version 2.4.2
[ 4.439099] PPP BSD Compression module registered
[ 4.439209] PPP Deflate Compression module registered
[ 4.439322] PPP MPPE Compression module registered
[ 4.439418] NET: Registered protocol family 24
[ 4.439543] usbcore: registered new interface driver r8152
[ 4.439677] usbcore: registered new interface driver asix
[ 4.439811] usbcore: registered new interface driver ax88179_178a
[ 4.439962] usbcore: registered new interface driver cdc_ether
[ 4.440106] usbcore: registered new interface driver net1080
[ 4.440281] usbcore: registered new interface driver cdc_subset
[ 4.440483] usbcore: registered new interface driver zaurus
[ 4.440632] usbcore: registered new interface driver cdc_ncm
[ 4.440986] VFIO - User Level meta-driver version: 0.3
[ 4.442086] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.446980] ehci-pci: EHCI PCI platform driver
[ 4.451081] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.457568] ohci-pci: OHCI PCI platform driver
[ 4.461839] ohci-platform: OHCI generic platform driver
[ 4.471686] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.474717] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4d4dc00 id
[ 4.479364] usbcore: registered new interface driver uas
[ 4.484091] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 4.484124] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.484141] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.484869] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.484909] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 4.485183] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.485189] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.485195] usb usb1: Product: xHCI Host Controller
[ 4.485200] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.485205] usb usb1: SerialNumber: 3610000.xhci
[ 4.494143] hub 1-0:1.0: USB hub found
[ 4.494186] hub 1-0:1.0: 4 ports detected
[ 4.494574] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.494587] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.494595] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.494884] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.494890] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.494916] usb usb2: Product: xHCI Host Controller
[ 4.494921] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.494926] usb usb2: SerialNumber: 3610000.xhci
[ 4.499195] hub 2-0:1.0: USB hub found
[ 4.499238] hub 2-0:1.0: 4 ports detected
[ 4.521466] Wake76 for irq=199
[ 4.521469] Wake77 for irq=199
[ 4.521472] Wake78 for irq=199
[ 4.521474] Wake79 for irq=199
[ 4.521476] Wake80 for irq=199
[ 4.521479] Wake81 for irq=199
[ 4.521481] Wake82 for irq=199
[ 4.521518] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 4.521524] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 4.604723] usb usb2: usb_suspend_both: status 0
[ 4.654856] usbcore: registered new interface driver usb-storage
[ 4.660559] usbcore: registered new interface driver usbserial
[ 4.668723] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.672536] tegra-xudc-new 3550000.xudc: device count: 1
[ 4.678681] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 4.682983] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 4.688506] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 4.693286] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 4.700575] mousedev: PS/2 mouse device common for all mice
[ 4.705595] usbcore: registered new interface driver xpad
[ 4.828239] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.843311] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.844596] Wake73 for irq=42
[ 4.845896] rtc rtc1: alarm rtc device
[ 4.845998] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.846179] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.846505] i2c /dev entries driver
[ 4.848979] i2c i2c-2: Added multiplexed i2c bus 9
[ 4.849416] i2c i2c-2: Added multiplexed i2c bus 10
[ 4.849524] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 4.850190] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.857784] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 4.857920] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.858045] usb 1-2: Product: USB2.1 Hub
[ 4.858153] usb 1-2: Manufacturer: Generic
[ 4.859205] hub 1-2:1.0: USB hub found
[ 4.859884] hub 1-2:1.0: 5 ports detected
[ 4.873839] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.874024] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.874286] imx219 9-0010: board setup failed
[ 4.874473] imx219: probe of 9-0010 failed with error -121
[ 4.874939] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.898351] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.898546] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.898830] imx219 10-0010: board setup failed
[ 4.899011] imx219: probe of 10-0010 failed with error -121
[ 4.900113] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 4.906401] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 4.906843] FAN dev name: pwm-fan
[ 4.906965] FAN:gpio request success.
[ 4.909604] FAN: can’t find tach_gpio
[ 4.913428] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.920465] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.926394] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.932791] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.938714] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.945914] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 4.953779] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 4.961224] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 4.969313] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.976868] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.984993] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.991716] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.999237] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.007054] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.015197] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.024074] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 5.030880] device-mapper: uevent: version 1.0.3
[ 5.035489] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.045437] usb 2-3: New USB device found, idVendor=0bda, idProduct=0411
[ 5.050567] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.057930] usb 2-3: Product: USB3.2 Hub
[ 5.061514] usb 2-3: Manufacturer: Generic
[ 5.067496] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 5.068826] hub 2-3:1.0: USB hub found
[ 5.069848] hub 2-3:1.0: 4 ports detected
[ 5.081564] cpuidle: Initializing cpuidle driver
[ 5.086027] sdhci: Secure Digital Host Controller Interface driver
[ 5.091339] sdhci: Copyright(c) Pierre Ossman
[ 5.095785] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.102735] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.111071] CMDQ: cmdq_platfm_init successful
[ 5.117421] tegra-se-nvhost 15810000.se: initialized
[ 5.122264] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.124933] tegra-se-nvhost 15820000.se: initialized
[ 5.130549] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.136083] tegra-se-nvhost 15830000.se: initialized
[ 5.140844] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.147098] tegra-se-nvhost 15840000.se: initialized
[ 5.148238] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 5.159085] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.160242] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.177241] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 5.180027] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.185166] usb 1-3: New USB device found, idVendor=05e3, idProduct=0610
[ 5.185171] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.185174] usb 1-3: Product: USB2.0 Hub
[ 5.199288] hub 1-3:1.0: USB hub found
[ 5.202933] hub 1-3:1.0: 4 ports detected
[ 5.212604] usbcore: registered new interface driver usbhid
[ 5.216996] usbhid: USB HID core driver
[ 5.225073] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 5.229575] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 5.234539] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 5.240105] denver_knobs_init:MTS_VERSION:54811859
[ 5.245173] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 5.251740] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 5.259393] t19x_cache tegra-cache: probed
[ 5.264225] usb 1-2.1: new low-speed USB device number 4 using tegra-xusb
[ 5.265605] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 5.265611] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 5.265994] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 5.266236] PLL_AON clock registered
[ 5.267234] Clocks initialized successfully
[ 5.268227] usb 2-3: usb_suspend_both: status 0
[ 5.268475] usb usb2: usb_suspend_both: status 0
[ 5.268727] nvpmodel: initialized successfully
[ 5.270498] trusty-virtio trusty:virtio: initializing
[ 5.270677] trusty_ipc virtio0: vring0: va¶ ffffffc1f1028000(0) qsz 32 notifyid 1
[ 5.270687] trusty_ipc virtio0: vring1: va¶ ffffffc1f102a000(0) qsz 32 notifyid 2
[ 5.270831] trusty-virtio trusty:virtio: initializing done
[ 5.271045] trusty_ipc virtio0: is online
[ 5.271617] tegra-hda 3510000.hda: Override SDO lines to 4
[ 5.271921] usbcore: registered new interface driver snd-usb-audio
[ 5.277719] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 5.291495] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 5.291656] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 5.292045] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 5.292304] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 5.399090] mmc0: periodic cache flush enabled
[ 5.399227] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.406341] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 5.409702] OPE platform probe
[ 5.409801] OPE platform probe successful
[ 5.418132] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 5.423778] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 5.429856] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 5.439175] usb 1-2.1: New USB device found, idVendor=046d, idProduct=c31c
[ 5.442572] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.449544] usb 1-2.1: Product: USB Keyboard
[ 5.454018] usb 1-2.1: Manufacturer: Logitech
[ 5.460862] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 5.466261] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:046D:C31C.0001/input/input4
[ 5.506430] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.506656] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.506842] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.507030] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.507253] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.507487] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.508763] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.514326] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.520149] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.525520] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.531653] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 5.532808] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3610000.xhci-2.1/input0
[ 5.550261] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 5.556392] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 5.562318] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 5.568355] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 5.574161] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 5.574198] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C31C.0002/input/input5
[ 5.591682] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 5.597723] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 5.603667] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 5.609644] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 5.616228] usb 1-3.2: new full-speed USB device number 5 using tegra-xusb
[ 5.632528] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3610000.xhci-2.1/input1
[ 5.642229] usb 1-3.2: New USB device found, idVendor=0d8c, idProduct=0014
[ 5.642305] u32 classifier
[ 5.642308] Actions configured
[ 5.642378] Initializing XFRM netlink socket
[ 5.642691] NET: Registered protocol family 10
[ 5.643287] NET: Registered protocol family 17
[ 5.643303] NET: Registered protocol family 15
[ 5.643335] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.647846] Bluetooth: RFCOMM socket layer initialized
[ 5.647868] Bluetooth: RFCOMM ver 1.11
[ 5.647874] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.647879] Bluetooth: HIDP socket layer initialized
[ 5.647896] 9pnet: Installing 9P2000 support
[ 5.647936] Key type dns_resolver registered
[ 5.652197] Registered cp15_barrier emulation handler
[ 5.652213] Registered setend emulation handler
[ 5.665327] registered taskstats version 1
[ 5.665756] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 5.666732] OF: PCI: host bridge /pcie@14160000 ranges:
[ 5.666746] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 5.666753] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 5.666757] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 5.751606] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.758780] usb 1-3.2: Product: USB Audio Device
[ 5.763154] usb 1-3.2: Manufacturer: C-Media Electronics Inc.
[ 5.776233] tegra-pcie-dw 14160000.pcie: link is up
[ 5.776555] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.780231] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.785475] input: C-Media Electronics Inc. USB Audio Device as /devices/3610000.xhci/usb1/1-3/1-3.2/1-3.2:1.3/0003:0D8C:0014.0003/input/input6
[ 5.798778] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 5.808134] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 5.819071] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 5.826707] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 5.826844] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.827050] iommu: Adding device 0004:00:00.0 to group 58
[ 5.832652] pci 0004:01:00.0: [1b21:1184] type 01 class 0x060400
[ 5.833363] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.833622] iommu: Adding device 0004:01:00.0 to group 59
[ 5.844459] hid-generic 0003:0D8C:0014.0003: input,hidraw2: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-3610000.xhci-3.2/input3
[ 5.848374] pci 0004:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.848788] pci 0004:02:01.0: [1b21:1184] type 01 class 0x060400
[ 5.849464] pci 0004:02:01.0: PME# supported from D0 D3hot D3cold
[ 5.849698] iommu: Adding device 0004:02:01.0 to group 60
[ 5.849870] pci 0004:02:03.0: [1b21:1184] type 01 class 0x060400
[ 5.850543] pci 0004:02:03.0: PME# supported from D0 D3hot D3cold
[ 5.850776] iommu: Adding device 0004:02:03.0 to group 61
[ 5.850974] pci 0004:02:05.0: [1b21:1184] type 01 class 0x060400
[ 5.851661] pci 0004:02:05.0: PME# supported from D0 D3hot D3cold
[ 5.851899] iommu: Adding device 0004:02:05.0 to group 62
[ 5.852095] pci 0004:02:07.0: [1b21:1184] type 01 class 0x060400
[ 5.852822] pci 0004:02:07.0: PME# supported from D0 D3hot D3cold
[ 5.853055] iommu: Adding device 0004:02:07.0 to group 63
[ 5.853391] pci 0004:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.853441] pci 0004:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.853489] pci 0004:02:05.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.853537] pci 0004:02:07.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.853868] pci_bus 0004:03: busn_res: [bus 03-ff] end is updated to 03
[ 5.854286] pci 0004:04:00.0: [1c00:3470] type 00 class 0x070005
[ 5.854395] pci 0004:04:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 5.854398] pci 0004:04:00.0: reg 0x10: [io size 0x0100]
[ 5.854453] pci 0004:04:00.0: reg 0x14: [mem 0x00000000-0x00007fff pref]
[ 5.854508] pci 0004:04:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[ 5.854526] pci 0004:04:00.0: reg 0x18: [io size 0x0004]
[ 5.854734] pci 0004:04:00.0: reg 0x30: [mem 0x00000000-0x00007fff pref]
[ 5.855148] pci 0004:04:00.0: PME# supported from D0 D3hot D3cold
[ 5.855373] iommu: Adding device 0004:04:00.0 to group 64
[ 5.855682] pci_bus 0004:04: busn_res: [bus 04-ff] end is updated to 04
[ 5.856068] pci 0004:05:00.0: [1b21:0612] type 00 class 0x010601
[ 5.856168] pci 0004:05:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 5.856172] pci 0004:05:00.0: reg 0x10: [io size 0x0008]
[ 5.856244] pci 0004:05:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[ 5.856248] pci 0004:05:00.0: reg 0x14: [io size 0x0004]
[ 5.856299] pci 0004:05:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[ 5.856303] pci 0004:05:00.0: reg 0x18: [io size 0x0008]
[ 5.856354] pci 0004:05:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[ 5.856357] pci 0004:05:00.0: reg 0x1c: [io size 0x0004]
[ 5.856407] pci 0004:05:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[ 5.856410] pci 0004:05:00.0: reg 0x20: [io size 0x0020]
[ 5.856462] pci 0004:05:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[ 5.856513] pci 0004:05:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 5.857072] iommu: Adding device 0004:05:00.0 to group 65
[ 5.868384] pci_bus 0004:05: busn_res: [bus 05-ff] end is updated to 05
[ 5.868683] pci_bus 0004:06: busn_res: [bus 06-ff] end is updated to 06
[ 5.868706] pci_bus 0004:02: busn_res: [bus 02-ff] end is updated to 06
[ 5.869650] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17401fffff]
[ 5.869657] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 5.869682] pci 0004:01:00.0: BAR 14: assigned [mem 0x1740000000-0x17401fffff]
[ 5.869689] pci 0004:01:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 5.869695] pci 0004:02:03.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 5.869699] pci 0004:02:05.0: BAR 14: assigned [mem 0x1740100000-0x17401fffff]
[ 5.869702] pci 0004:02:03.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 5.869705] pci 0004:02:05.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 5.869710] pci 0004:02:01.0: PCI bridge to [bus 03]
[ 5.869799] pci 0004:04:00.0: BAR 1: assigned [mem 0x1740000000-0x1740007fff pref]
[ 5.869824] pci 0004:04:00.0: BAR 6: assigned [mem 0x1740008000-0x174000ffff pref]
[ 5.869827] pci 0004:04:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 5.869851] pci 0004:04:00.0: BAR 2: assigned [io 0x1100-0x1103]
[ 5.869875] pci 0004:02:03.0: PCI bridge to [bus 04]
[ 5.869887] pci 0004:02:03.0: bridge window [io 0x1000-0x1fff]
[ 5.869921] pci 0004:02:03.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 5.869998] pci 0004:05:00.0: BAR 6: assigned [mem 0x1740100000-0x174010ffff pref]
[ 5.870001] pci 0004:05:00.0: BAR 5: assigned [mem 0x1740110000-0x17401101ff]
[ 5.870024] pci 0004:05:00.0: BAR 4: assigned [io 0x2000-0x201f]
[ 5.870047] pci 0004:05:00.0: BAR 0: assigned [io 0x2020-0x2027]
[ 5.870069] pci 0004:05:00.0: BAR 2: assigned [io 0x2028-0x202f]
[ 5.870092] pci 0004:05:00.0: BAR 1: assigned [io 0x2030-0x2033]
[ 5.870114] pci 0004:05:00.0: BAR 3: assigned [io 0x2034-0x2037]
[ 5.870138] pci 0004:02:05.0: PCI bridge to [bus 05]
[ 5.870150] pci 0004:02:05.0: bridge window [io 0x2000-0x2fff]
[ 5.870180] pci 0004:02:05.0: bridge window [mem 0x1740100000-0x17401fffff]
[ 5.870237] pci 0004:02:07.0: PCI bridge to [bus 06]
[ 5.870340] pci 0004:01:00.0: PCI bridge to [bus 02-06]
[ 5.870352] pci 0004:01:00.0: bridge window [io 0x1000-0x2fff]
[ 5.870382] pci 0004:01:00.0: bridge window [mem 0x1740000000-0x17401fffff]
[ 5.870439] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.870443] pci 0004:00:00.0: bridge window [io 0x1000-0x2fff]
[ 5.870449] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17401fffff]
[ 5.870467] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.870515] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.870563] pci 0004:02:01.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.870612] pci 0004:02:03.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.870666] pci 0004:04:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.870714] pci 0004:02:05.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.870769] pci 0004:05:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.870833] pci 0004:02:07.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.871066] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.871069] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 5.871072] pci 0004:02:01.0: Signaling PME through PCIe PME interrupt
[ 5.871075] pci 0004:02:03.0: Signaling PME through PCIe PME interrupt
[ 5.871077] pci 0004:04:00.0: Signaling PME through PCIe PME interrupt
[ 5.871079] pci 0004:02:05.0: Signaling PME through PCIe PME interrupt
[ 5.871082] pci 0004:05:00.0: Signaling PME through PCIe PME interrupt
[ 5.871084] pci 0004:02:07.0: Signaling PME through PCIe PME interrupt
[ 5.871089] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.871265] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 5.875953] serial 0004:04:00.0: enabling device (0000 → 0003)
[ 5.876645] 0004:04:00.0: ttyS0 at I/O 0x10c0 (irq = 33, base_baud = 115200) is a XR16850
[ 5.877022] 0004:04:00.0: ttyS1 at I/O 0x10c8 (irq = 33, base_baud = 115200) is a XR16850
[ 5.877412] 0004:04:00.0: ttyS2 at I/O 0x10d0 (irq = 33, base_baud = 115200) is a XR16850
[ 5.881601] 0004:04:00.0: ttyS3 at I/O 0x10d8 (irq = 33, base_baud = 115200) is a XR16850
[ 5.882019] ahci 0004:05:00.0: version 3.0
[ 5.882047] ahci 0004:05:00.0: enabling device (0000 → 0003)
[ 5.882361] ahci 0004:05:00.0: SSS flag set, parallel bus scan disabled
[ 5.882444] ahci 0004:05:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 5.882451] ahci 0004:05:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 5.883114] scsi host0: ahci
[ 5.883418] scsi host1: ahci
[ 5.883505] ata1: SATA max UDMA/133 abar m512@0x1740110000 port 0x1740110100 irq 560
[ 5.883511] ata2: SATA max UDMA/133 abar m512@0x1740110000 port 0x1740110180 irq 560
[ 5.883890] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 5.884073] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 5.884080] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 5.988484] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 5.988502] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 5.988508] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 5.988512] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 6.096279] tegra-pcie-dw 141a0000.pcie: link is up
[ 6.096520] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.096527] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.096534] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.096538] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 6.096542] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 6.096567] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 6.096729] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.096905] iommu: Adding device 0005:00:00.0 to group 66
[ 6.097287] pci 0005:01:00.0: [1b21:1184] type 01 class 0x060400
[ 6.097927] pci 0005:01:00.0: PME# supported from D0 D3hot D3cold
[ 6.098170] iommu: Adding device 0005:01:00.0 to group 67
[ 6.108389] pci 0005:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.108831] pci 0005:02:01.0: [1b21:1184] type 01 class 0x060400
[ 6.109468] pci 0005:02:01.0: PME# supported from D0 D3hot D3cold
[ 6.109689] iommu: Adding device 0005:02:01.0 to group 68
[ 6.109913] pci 0005:02:03.0: [1b21:1184] type 01 class 0x060400
[ 6.110545] pci 0005:02:03.0: PME# supported from D0 D3hot D3cold
[ 6.110770] iommu: Adding device 0005:02:03.0 to group 69
[ 6.110979] pci 0005:02:05.0: [1b21:1184] type 01 class 0x060400
[ 6.111591] pci 0005:02:05.0: PME# supported from D0 D3hot D3cold
[ 6.111806] iommu: Adding device 0005:02:05.0 to group 70
[ 6.112042] pci 0005:02:07.0: [1b21:1184] type 01 class 0x060400
[ 6.112714] pci 0005:02:07.0: PME# supported from D0 D3hot D3cold
[ 6.112930] iommu: Adding device 0005:02:07.0 to group 71
[ 6.113299] pci 0005:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.113345] pci 0005:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.113390] pci 0005:02:05.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.113434] pci 0005:02:07.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.113820] pci 0005:03:00.0: [8086:15f3] type 00 class 0x020000
[ 6.113932] pci 0005:03:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 6.114071] pci 0005:03:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 6.114208] pci 0005:03:00.0: reg 0x30: [mem 0x00000000-0x000fffff pref]
[ 6.114754] pci 0005:03:00.0: PME# supported from D0 D3hot D3cold
[ 6.115036] iommu: Adding device 0005:03:00.0 to group 72
[ 6.115484] pci_bus 0005:03: busn_res: [bus 03-ff] end is updated to 03
[ 6.115867] pci 0005:04:00.0: [8086:15f3] type 00 class 0x020000
[ 6.115960] pci 0005:04:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 6.116116] pci 0005:04:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 6.116272] pci 0005:04:00.0: reg 0x30: [mem 0x00000000-0x000fffff pref]
[ 6.116815] pci 0005:04:00.0: PME# supported from D0 D3hot D3cold
[ 6.117093] iommu: Adding device 0005:04:00.0 to group 73
[ 6.117582] pci_bus 0005:04: busn_res: [bus 04-ff] end is updated to 04
[ 6.117980] pci 0005:05:00.0: [8086:15fd] type 00 class 0x020000
[ 6.118073] pci 0005:05:00.0: reg 0x10: [mem 0x00000000-0x007fffff]
[ 6.118208] pci 0005:05:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 6.118869] pci 0005:05:00.0: PME# supported from D0 D3hot D3cold
[ 6.119149] iommu: Adding device 0005:05:00.0 to group 74
[ 6.119584] pci_bus 0005:05: busn_res: [bus 05-ff] end is updated to 05
[ 6.119945] pci 0005:06:00.0: [8086:15f3] type 00 class 0x020000
[ 6.120039] pci 0005:06:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 6.120174] pci 0005:06:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 6.120333] pci 0005:06:00.0: reg 0x30: [mem 0x00000000-0x000fffff pref]
[ 6.120877] pci 0005:06:00.0: PME# supported from D0 D3hot D3cold
[ 6.121157] iommu: Adding device 0005:06:00.0 to group 75
[ 6.121606] pci_bus 0005:06: busn_res: [bus 06-ff] end is updated to 06
[ 6.121628] pci_bus 0005:02: busn_res: [bus 02-ff] end is updated to 06
[ 6.122579] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f417fffff]
[ 6.122584] pci 0005:01:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f417fffff]
[ 6.122590] pci 0005:02:05.0: BAR 14: assigned [mem 0x1f40000000-0x1f40bfffff]
[ 6.122594] pci 0005:02:01.0: BAR 14: assigned [mem 0x1f40c00000-0x1f40efffff]
[ 6.122597] pci 0005:02:03.0: BAR 14: assigned [mem 0x1f40f00000-0x1f411fffff]
[ 6.122601] pci 0005:02:07.0: BAR 14: assigned [mem 0x1f41200000-0x1f414fffff]
[ 6.122606] pci 0005:03:00.0: BAR 0: assigned [mem 0x1f40c00000-0x1f40cfffff]
[ 6.122629] pci 0005:03:00.0: BAR 6: assigned [mem 0x1f40d00000-0x1f40dfffff pref]
[ 6.122633] pci 0005:03:00.0: BAR 3: assigned [mem 0x1f40e00000-0x1f40e03fff]
[ 6.122672] pci 0005:02:01.0: PCI bridge to [bus 03]
[ 6.122701] pci 0005:02:01.0: bridge window [mem 0x1f40c00000-0x1f40efffff]
[ 6.122758] pci 0005:04:00.0: BAR 0: assigned [mem 0x1f40f00000-0x1f40ffffff]
[ 6.122780] pci 0005:04:00.0: BAR 6: assigned [mem 0x1f41000000-0x1f410fffff pref]
[ 6.122784] pci 0005:04:00.0: BAR 3: assigned [mem 0x1f41100000-0x1f41103fff]
[ 6.122805] pci 0005:02:03.0: PCI bridge to [bus 04]
[ 6.122833] pci 0005:02:03.0: bridge window [mem 0x1f40f00000-0x1f411fffff]
[ 6.122886] pci 0005:05:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f407fffff]
[ 6.122907] pci 0005:05:00.0: BAR 3: assigned [mem 0x1f40800000-0x1f40803fff]
[ 6.122944] pci 0005:02:05.0: PCI bridge to [bus 05]
[ 6.122972] pci 0005:02:05.0: bridge window [mem 0x1f40000000-0x1f40bfffff]
[ 6.123026] pci 0005:06:00.0: BAR 0: assigned [mem 0x1f41200000-0x1f412fffff]
[ 6.123047] pci 0005:06:00.0: BAR 6: assigned [mem 0x1f41300000-0x1f413fffff pref]
[ 6.123051] pci 0005:06:00.0: BAR 3: assigned [mem 0x1f41400000-0x1f41403fff]
[ 6.123072] pci 0005:02:07.0: PCI bridge to [bus 06]
[ 6.123100] pci 0005:02:07.0: bridge window [mem 0x1f41200000-0x1f414fffff]
[ 6.123152] pci 0005:01:00.0: PCI bridge to [bus 02-06]
[ 6.123179] pci 0005:01:00.0: bridge window [mem 0x1f40000000-0x1f417fffff]
[ 6.123232] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.123253] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f417fffff]
[ 6.123268] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.123313] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.123357] pci 0005:02:01.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.123405] pci 0005:03:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.123449] pci 0005:02:03.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.123496] pci 0005:04:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.123540] pci 0005:02:05.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.123587] pci 0005:05:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.123654] pci 0005:02:07.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.123702] pci 0005:06:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.123884] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.123888] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.123890] pci 0005:02:01.0: Signaling PME through PCIe PME interrupt
[ 6.123892] pci 0005:03:00.0: Signaling PME through PCIe PME interrupt
[ 6.123895] pci 0005:02:03.0: Signaling PME through PCIe PME interrupt
[ 6.123897] pci 0005:04:00.0: Signaling PME through PCIe PME interrupt
[ 6.123899] pci 0005:02:05.0: Signaling PME through PCIe PME interrupt
[ 6.123901] pci 0005:05:00.0: Signaling PME through PCIe PME interrupt
[ 6.123903] pci 0005:02:07.0: Signaling PME through PCIe PME interrupt
[ 6.123906] pci 0005:06:00.0: Signaling PME through PCIe PME interrupt
[ 6.123911] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 6.124082] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 6.136013] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 6.140238] tegra194-isp5 14800000.isp: initialized
[ 6.147050] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 6.149780] tegra194-vi5 15c10000.vi: initialized
[ 6.153855] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 6.153976] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 6.154161] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 6.158329] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 6.158340] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 6.158344] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 6.158395] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 6.158422] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 6.158426] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 6.193418] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 6.193440] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 6.193444] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 6.193812] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 6.193851] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 6.193855] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 6.194252] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 6.194302] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 6.194306] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 6.194536] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 6.195205] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.271449] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 6.271748] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.271919] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 6.272243] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 6.272516] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 6.272628] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 6.272822] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 6.272825] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.273970] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=4c29076f2400b1aca1797dafeba3d8643d889753
[ 6.274360] Wake83 for irq=211
[ 6.274421] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 6.274506] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 6.274613] input: gpio-keys as /devices/gpio-keys/input/input7
[ 6.298565] tegra_rtc c2a0000.rtc: setting system clock to 2022-07-25 08:47:01 UTC (1658738821)
[ 6.299343] mmcblk mmc0:0001: Card claimed for testing.
[ 6.330420] bpmp: mounted debugfs mirror
[ 6.336709] ALSA device list:
[ 6.336714] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 6.336716] #1: jetson-xaviernx-ape
[ 6.336718] #2: C-Media Electronics Inc. USB Audio Device at usb-3610000.xhci-3.2, full speed
[ 6.356262] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6.368086] ata1.00: ATA-9: ZHITAI SC001 Active 512GB SSD, ZT013200, max UDMA/133
[ 6.368092] ata1.00: 1000215216 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 6.368572] ata1.00: configured for UDMA/133
[ 6.369011] scsi 0:0:0:0: Direct-Access ATA ZHITAI SC001 Act 3200 PQ: 0 ANSI: 5
[ 6.432880] sd 0:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
[ 6.433067] sd 0:0:0:0: [sda] Write Protect is off
[ 6.433072] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 6.433145] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 6.435569] sda: sda1
[ 6.436535] sd 0:0:0:0: [sda] Attached SCSI disk
[ 6.746864] ata2: SATA link down (SStatus 0 SControl 300)
[ 7.336929] Freeing unused kernel memory: 8640K
[ 7.377244] Root device found: sda1
[ 7.379164] Found dev node: /dev/sda1
[ 7.412269] usb 1-3.3: new high-speed USB device number 6 using tegra-xusb
[ 7.433882] usb 1-3.3: New USB device found, idVendor=05e3, idProduct=0610
[ 7.434040] usb 1-3.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 7.434158] usb 1-3.3: Product: USB2.0 Hub
[ 7.435169] hub 1-3.3:1.0: USB hub found
[ 7.435580] hub 1-3.3:1.0: 4 ports detected
[ 7.439752] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.442871] Rootfs mounted over sda1
[ 7.460147] Switching from initrd to actual rootfs
[ 7.556828] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.560277] usb 1-3.3: usb_suspend_both: status 0
[ 7.560898] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.568719] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.569738] systemd[1]: Detected architecture arm64.
[ 7.577513] systemd[1]: Set hostname to .
[ 7.654177] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.654501] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 7.768023] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.768250] systemd[1]: Reached target User and Group Name Lookups.
[ 7.768951] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.769436] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.769809] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.772544] systemd[1]: Created slice User and Session Slice.
[ 7.773966] systemd[1]: Created slice System Slice.
[ 7.774613] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.813813] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 7.888959] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 8.207594] systemd-journald[2484]: Received request to flush runtime journal from PID 1
[ 8.989987] random: crng init done
[ 8.990109] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.144840] using random self ethernet address
[ 9.144970] using random host ethernet address
[ 9.502915] cpu-throttle-alert cooling device registered.
[ 9.504177] gpu-throttle-alert cooling device registered.
[ 9.508126] aux-throttle-alert cooling device registered.
[ 9.780881] Mass Storage Function, version: 2009/09/11
[ 9.780892] LUN: removable file: (no medium)
[ 9.788405] using random self ethernet address
[ 9.788635] using random host ethernet address
[ 9.835156] rndis0: HOST MAC da:82:6d:55:ab:b0
[ 9.835431] rndis0: MAC da:82:6d:55:ab:b1
[ 9.836176] usb0: HOST MAC da:82:6d:55:ab:b2
[ 9.837102] usb0: MAC da:82:6d:55:ab:b3
[ 9.837141] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.845526] l4tbr0: port 1(rndis0) entered blocking state
[ 9.845536] l4tbr0: port 1(rndis0) entered disabled state
[ 9.845765] device rndis0 entered promiscuous mode
[ 9.859870] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.875996] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.000185] android_work: did not send uevent (0 0 (null))
[ 10.072761] android_work: sent uevent USB_STATE=CONNECTED
[ 10.127769] android_work: sent uevent USB_STATE=DISCONNECTED
[ 10.140828] ras_fhi_disable: FHI 473 disabled
[ 10.142039] CPU4: shutdown
[ 10.142170] psci: CPU4 killed (polled 0 ms)
[ 10.193065] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 10.200172] net eth0: get_configure_l3v4_filter →
[ 10.201307] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.201408] l4tbr0: port 2(usb0) entered blocking state
[ 10.201416] l4tbr0: port 2(usb0) entered disabled state
[ 10.201576] device usb0 entered promiscuous mode
[ 10.207714] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.208809] ras_fhi_disable: FHI 474 disabled
[ 10.210809] CPU5: shutdown
[ 10.212006] psci: CPU5 killed (polled 0 ms)
[ 10.220673] android_work: sent uevent USB_STATE=CONNECTED
[ 10.224972] configfs-gadget gadget: high-speed config #1: c
[ 10.225003] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 10.225016] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 10.225032] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 10.225123] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 10.225136] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 10.225147] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 10.225172] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 10.225203] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 10.225220] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 10.225225] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 10.225465] android_work: sent uevent USB_STATE=CONFIGURED
[ 10.229345] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 10.229363] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 10.229501] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 10.230471] tegra-xudc-new 3550000.xudc: ep 13 disabled
[ 10.230594] tegra-xudc-new 3550000.xudc: ep 8 disabled
[ 10.237425] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 10.249030] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 10.249047] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 10.455309] zram: Added device: zram0
[ 10.461045] zram: Added device: zram1
[ 10.465177] zram: Added device: zram2
[ 10.469588] zram: Added device: zram3
[ 10.499660] zram0: detected capacity change from 0 to 1018880000
[ 10.558143] Adding 994996k swap on /dev/zram0. Priority:5 extents:1 across:994996k SS
[ 10.580683] zram1: detected capacity change from 0 to 1018880000
[ 10.611334] Adding 994996k swap on /dev/zram1. Priority:5 extents:1 across:994996k SS
[ 10.614074] zram2: detected capacity change from 0 to 1018880000
[ 10.634420] Adding 994996k swap on /dev/zram2. Priority:5 extents:1 across:994996k SS
[ 10.641864] zram3: detected capacity change from 0 to 1018880000
[ 10.669468] Adding 994996k swap on /dev/zram3. Priority:5 extents:1 across:994996k SS
[ 11.115241] Bridge firewalling registered
[ 11.152293] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 11.463979] Netfilter messages via NETLINK v0.30.
[ 11.466128] ctnetlink v0.93: registering with nfnetlink.
[ 11.550643] tegradc 15200000.nvdisplay: blank - powerdown
[ 11.550658] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.648170] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 12.950846] fuse init (API version 7.26)
[ 14.616321] l4tbr0: port 2(usb0) entered blocking state
[ 14.616330] l4tbr0: port 2(usb0) entered forwarding state
[ 14.616420] l4tbr0: port 1(rndis0) entered blocking state
[ 14.616426] l4tbr0: port 1(rndis0) entered forwarding state
[ 14.616504] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 14.616522] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 16.025951] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.025967] Bluetooth: BNEP socket layer initialized
[ 19.837910] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 38.244583] vdd-sdmmc1-sw: disabling
[ 38.244610] vdd-1v8-sd: disabling
[ 38.244632] vdd-1v8-cvb: disabling
[ 38.244640] vdd-epb-1v0: disabling
[ 38.244648] avdd-cam-2v8: disabling
[ 38.244661] vdd-fan: disabling
[ 38.244670] vdd_sys_en: disabling
