DP1 is being used as HDMI and its working fine. And we aren’t able to detect other connected device on DP0. Complete dmesg is attached
dmesg.txt (72.5 KB)
Please check if DP0/DP1 are using the same pinmux setting.
Are you using pure nv driver? I saw there is “[ 0.416024] tegradc 15210000.nvdisplay: hdmi: No useable modes found for monitor, falling back to VGA”, but official driver seems not have this debug message.
Does hotplug work? Is tegra able to read display edid?
Have you checked the device tree?
1: I am not sure how to check pinmux settings.
2: I flashed tx2 by using Jetpack, so I suppose it is pure nv driver.
3: Its hotplugged, but we aren’t able to read display edid memory. In the display properties of linux OS we can see all properties of hdmi display attached on DP1.
4:
/proc/device-tree/host1x/dpaux@15040000/status
okay
/proc/device-tree/host1x/dpaux@155c0000/status
disabled
/proc/device-tree/host1x/sor1/status
okay
/proc/device-tree/host1x/sor1/dp-display/status
disabled
/proc/device-tree/host1x/sor/status
disabled
/proc/device-tree/host1x/sor/dp-display/status
disabled
/proc/device-tree/host1x/nvdisplay@15200000/status
disabled
/proc/device-tree/host1x/nvdisplay@15210000/status
okay
/proc/device-tree/host1x/nvdisplay@15220000/status
disabled
If you are using dp-display in sor1 why are you disabling dp-display?
Actually, it is really hard to tell what is wrong with current information.
Please share
- Your board schematics
- Your current device tree
- Your release revision of source code
I don’t see any “No useable modes found for monitor” keywords in our rel-32 driver source… not sure where it came from. Maybe I miss it. Could you help point out where is this line?
Thank you for replying, we haven’t disabled any port.
Current Device Tree:
okay
disabled
okay
disabled
disabled
disabled
disabled
okay
disabled
And I am not sure which code you are asking for.
Schematics for HDMI is attached below
Tx2 hdmi schematic.pdf (903 KB)
Sorry, I thought you are trying to enable dp.
Do you enable hdmi-display under sor1?
Hdmi was enabled by default
What release is it? rel-32.2? rel-32.1?
Os version 16.04
Linux Kernel version 4.4.38-tegra
Jetpack: Tegra linux driver package version R28.2.1
- For the pinmux, please refer to tx2 adaptation guide. Your two pins of DP0/DP1 should match.
- Could you check where does this line “[ 0.416024] tegradc 15210000.nvdisplay: hdmi: No useable modes found for monitor, falling back to VGA” come from?
