SDK Manager fails to download target components, block flash process
Please, what is the solution for this issue? I tried to reflash my Jetson AGX Xavier again, and I am having the same problem. First SDK does not make any Jetpack version available (I have to do the trick, mentioned in other forum message changing os-release file (VERSION_ID) from 24.04 to 18.04).
Link for the first workaround: SDK Manager no sdks available
Later on, SDK Manager just makes available the Jetpack 5.1.4 for me to update my Jetson AGX Xavier. However, after trying to update the Jetson on Step 3, I get the same problem reported in this issue. Please, how to solve this problem? Attached is my log file. Thanks.
PS.: I am with Jetson AGX Xavier in recovery mode and trying to upload through USB Type C connection.
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_AGX_Xavier_2025-02-16_08-44-56.zip (28.0 KB)
