SDKManager Problem
Hi all,
i try to setup my Orin nano Dev Kit the first time and used this description: 🛸 Initial Setup (SDK Manager method) - NVIDIA Jetson AI Lab →SDK Manager method
My Host is a Ubuntu 24.04 and connection is available. Dev Kit detected inside SDK.After starting the download on Host PC i get attached failure message.
How to solve this?
On your host PC is it able to update? Basically:
sudo apt update
sudo apt-get upgrade
Thx for fast reaction but same Failure :-(
Is it correct that the host PC itself is able to update/upgrade?
EDIT: Also, what do you get from “./tools/l4t_flash_prerequisites.sh” (run from “Linux_for_Tegra/”)?
Sorry i do not know what you want me to do. Linux_for_Tegra is emtpy, just a rootfs Folder. Inside the log i found a lot of err.
Starting with
20:38:16.155 - info: Download service pid is: 8780
20:38:16.156 - info: Download manager can use up to 12 download threads per file
20:38:16.157 - error: Cannot get user selected groups
20:38:31.875 - info: Session initial status: install percent: 80. (24 out of 0)
20:38:31.876 - error: There is no group in this section NV_HOST_SECTION
20:38:31.877 - info: initializeGroups ended successfully. Duration: 00:00:01
followed by several errors like:
Ign:12 Index of /gezakovacs/ppa/ubuntu noble InRelease
20:39:12.404 - error:
0% [Waiting for headers]
Err:13 https://packagecloud.io/AllToMP3/alltomp3/ubuntu noble Release
20:39:12.404 - info: Event: undefined - error is:
Here the complete log:
sdkm-2025-11-07-09-02-37.log (78.2 KB)
Please download Sample Root Filesystem and Driver Package (BSP) from Jetson Linux Release 36.4.4 | NVIDIA Developer
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide to flash your device.
Ok, will give this a try. Thank you
Great to find finally someone who can explain in easy words what to do. Woring now you made my day ;-)
