No initial setup possible
Hello All,
after getting somehow stucked with SDK install ( SDKManager Problem ) i try the solution with SD card to let my orin nano dev kit run. I used the description Get Started With Jetson Nano Developer Kit | NVIDIA Developer
After boot i end up in screen:
followed by
How to solve this?
Based on the provided context, it appears that you are experiencing issues with your Jetson Orin Nano Developer Kit, specifically with the SDK installation and booting process. You have tried using an SD card to resolve the issue, but you are still encountering problems.
The error messages you provided, “20251107083046 19201440 509 KB” and “20251107082709 19201440 436 KB”, do not seem to be directly related to the Jetson Orin Nano documentation provided. However, I can offer some general troubleshooting steps and comparisons to help you resolve the issue.
  1. Verify the SD card image: Ensure that you have downloaded the correct JetPack SD card image for your Jetson Orin Nano Developer Kit. The documentation mentions JetPack 5.1.1 and JetPack 5.1.4, so make sure you are using the correct version.
  2. Check the boot order: As mentioned in the documentation, ensure that the UEFI SD Device is set as the top boot option in the Boot Manager. This can be done by pressing the ESCAPE key during boot and navigating to the Boot Manager.
  3. Complete the oem-config: If you haven’t already, complete the oem-config process to ensure that the device is properly configured.
  4. Verify the bootloader version: Run the command sudo nvbootctrl dump-slots-info to check the current bootloader version. The output should show a version less than 35.6.0.
  5. Compare with known issues: The documentation mentions several known issues related to booting and SDK installation. Compare your symptoms with the ones listed in the documentation to see if there are any similarities.
Some specific issues mentioned in the documentation that might be relevant to your problem include:
  • Jetson Orin Nano Developer Kit – Black Screen and Fan Stops After Boot (JetPack 5.1.3): This issue might be related to a problem with the bootloader or the SD card image.
  • Booting issue Jetson Orin Nano boot, jetson: This issue might be related to a problem with the boot order or the UEFI configuration.
  • Optimizing Boot Time on Jetson Orin with Jetpack 6.2: This issue might be related to a problem with the bootloader or the SD card image, and optimizing the boot time might help resolve the issue.
To further troubleshoot the issue, you can try the following:
  • Reflash the SD card: Try reflashing the SD card with the correct JetPack image to ensure that the issue is not related to the SD card.
  • Use a different SD card: Try using a different SD card to rule out any issues with the current SD card.
  • Check the power supply: Ensure that the power supply is stable and sufficient for the device.
  • Check for ESD damage: Ensure that you are using proper anti-static and grounding techniques when working with the device to prevent ESD damage.
If none of these steps resolve the issue, it may be helpful to provide more information about your setup and the exact error messages you are seeing.
It’s strongly recommended to set up a native Ubuntu environment and flash using sdk manager or cli.
We’ve also provided an alternative CLI flashing method in the original topic.
Sorry i cannot find any link inside the “Get started”. Searching gives me another Quick start. Are you refering to that description?
Solved with SDKManager Problem - #8 by DavidDDD
