Installation failed - Jetson Orin Nano (sdkmanager)
JetsonOrin nano with nvme. Jetpack version both dp_6.0 and 5.1.2
ERROR: File System and OS - target_image: : Operation not permitted
ERROR: File System and OS - target_image: command terminated with error
00:37:11 INFO: File System and OS - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.1.2/Jetson_512_b104/T234/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2 to /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
00:47:59 INFO: File System and OS - target_image: verifying checksum of /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
00:48:01 INFO: File System and OS - target_image: download /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2 successfully, checksum is correct
00:48:02 DEBUG: File System and OS - target_image: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS to /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/
00:48:02 INFO: File System and OS - target_image: [host] [ Disk Avail:35.81 GB ]
00:48:02 INFO: File System and OS - target_image: Installing component 'File System and OS' (NV_L4T_FILE_SYSTEM_AND_OS_COMP)
00:48:02 INFO: File System and OS - target_image: NV_L4T_FILE_SYSTEM_AND_OS_COMP include 1 package
00:48:02 INFO: File System and OS - target_image: change working directory to /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/
00:48:02 INFO: File System and OS - target_image: [ Package Install Started ]
00:48:02 INFO: File System and OS - target_image: current working directory is /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
00:48:02 INFO: File System and OS - target_image: exec_command [host]:
00:48:02 INFO: File System and OS - target_image: **********************
00:48:02 INFO: File System and OS - target_image: sudo tar xpf /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
00:48:02 INFO: File System and OS - target_image: cd ..
00:48:02 INFO: File System and OS - target_image: sudo ./tools/l4t_flash_prerequisites.sh
00:48:02 INFO: File System and OS - target_image: sudo ./apply_binaries.sh
00:48:02 INFO: File System and OS - target_image: sudo mkdir -p rootfs/opt/nvidia/deb_repos
00:48:02 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.r.sh
00:51:06 ERROR: File System and OS - target_image: sudo: ./tools/l4t_flash_prerequisites.sh: command not found
00:51:06 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.r.sh; [error]: sudo: ./tools/l4t_flash_prerequisites.sh: command not found
00:51:06 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
00:51:06 INFO: File System and OS - target_image: [host] [ 737.83 MB used. Disk Avail: 35.09 GB ]
00:51:06 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 3m4s ]
00:51:06 ERROR: File System and OS - target_image: command terminated with error
00:51:06 SUMMARY: File System and OS - target_image: First Error: Installation failed.
00:52:20 INFO: File System and OS - target_image: verifying checksum of /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
00:52:23 INFO: File System and OS - target_image: Found file /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2 with correct checksum, skip downloading.
00:52:29 INFO: File System and OS - target_image: verifying checksum of /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
00:52:32 INFO: File System and OS - target_image: Found file /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2 with correct checksum, skip downloading.
00:53:25 DEBUG: File System and OS - target_image: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS to /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/
00:53:25 INFO: File System and OS - target_image: [host] [ Disk Avail:39.09 GB ]
00:53:25 INFO: File System and OS - target_image: Installing component 'File System and OS' (NV_L4T_FILE_SYSTEM_AND_OS_COMP)
00:53:25 INFO: File System and OS - target_image: NV_L4T_FILE_SYSTEM_AND_OS_COMP include 1 package
00:53:25 INFO: File System and OS - target_image: change working directory to /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/
00:53:25 INFO: File System and OS - target_image: [ Package Install Started ]
00:53:25 INFO: File System and OS - target_image: current working directory is /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
00:53:25 INFO: File System and OS - target_image: exec_command [host]:
00:53:25 INFO: File System and OS - target_image: **********************
00:53:25 INFO: File System and OS - target_image: sudo tar xpf /home/r/Downloads/Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
00:53:25 INFO: File System and OS - target_image: cd ..
00:53:25 INFO: File System and OS - target_image: sudo ./tools/l4t_flash_prerequisites.sh
00:53:25 INFO: File System and OS - target_image: sudo ./apply_binaries.sh
00:53:25 INFO: File System and OS - target_image: sudo mkdir -p rootfs/opt/nvidia/deb_repos
00:53:25 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.r.sh
00:56:13 INFO: File System and OS - target_image: Get:1 file:/var/cuda-repo-cross-aarch64-ubuntu2004-11-4-local InRelease [1,575 B]
00:56:13 INFO: File System and OS - target_image: Get:2 file:/var/cuda-repo-cross-aarch64-ubuntu2004-12-2-local InRelease [1,572 B]
00:56:13 INFO: File System and OS - target_image: Get:3 file:/var/cuda-repo-ubuntu2004-11-4-local InRelease [1,575 B]
00:56:13 INFO: File System and OS - target_image: Get:4 file:/var/cuda-repo-ubuntu2004-12-2-local InRelease [1,572 B]
00:56:13 INFO: File System and OS - target_image: Hit:5 http://packages.microsoft.com/repos/code stable InRelease
00:56:13 INFO: File System and OS - target_image: Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
00:56:13 INFO: File System and OS - target_image: Hit:7 http://archive.ubuntu.com/ubuntu focal InRelease
00:56:13 INFO: File System and OS - target_image: Hit:8 http://packages.ros.org/ros/ubuntu focal InRelease
00:56:13 INFO: File System and OS - target_image: Hit:9 http://archive.ubuntu.com/ubuntu focal-updates InRelease
00:56:14 INFO: File System and OS - target_image: Hit:10 http://archive.ubuntu.com/ubuntu focal-backports InRelease
00:56:15 INFO: File System and OS - target_image: Reading package lists...
00:56:16 INFO: File System and OS - target_image: udev is already the newest version (245.4-4ubuntu3.22).
00:56:16 INFO: File System and OS - target_image: uuid-runtime is already the newest version (2.34-0.1ubuntu9.4).
00:56:16 INFO: File System and OS - target_image: qemu-user-static is already the newest version (1:4.2-3ubuntu6.27).
00:56:16 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
00:56:17 INFO: File System and OS - target_image: Reading package lists...
00:56:18 INFO: File System and OS - target_image: Building dependency tree...
00:56:18 INFO: File System and OS - target_image: Reading state information...
00:56:18 INFO: File System and OS - target_image: python-is-python2 is already the newest version (2.7.17-4).
00:56:18 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
0:56:19 INFO: File System and OS - target_image: Reading package lists...
00:56:19 INFO: File System and OS - target_image: Building dependency tree...
00:56:19 INFO: File System and OS - target_image: Reading state information...
00:56:20 INFO: File System and OS - target_image: lz4 is already the newest version (1.9.2-2ubuntu0.20.04.1).
00:56:20 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
00:56:20 INFO: File System and OS - target_image: Using rootfs directory of: /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
00:56:20 INFO: File System and OS - target_image: Installing extlinux.conf into /boot/extlinux in target rootfs
00:56:20 INFO: File System and OS - target_image: /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
00:56:20 INFO: File System and OS - target_image: Root file system directory is /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
00:56:20 INFO: File System and OS - target_image: Copying public debian packages to rootfs
00:56:20 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-apt-source_35.4.1-20230801124926_arm64.deb ...
00:56:20 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-config_35.4.1-20230801124926_arm64.deb ...
00:56:20 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-factory-service_35.4.1-20230801124926_arm64.deb ...
00:56:21 INFO: File System and OS - target_image: Start L4T BSP package installation
00:56:21 INFO: File System and OS - target_image: QEMU binary is not available, looking for QEMU from host system
00:56:21 INFO: File System and OS - target_image: Found /usr/bin/qemu-aarch64-static
00:56:21 INFO: File System and OS - target_image: Installing QEMU binary in rootfs
00:56:21 ERROR: File System and OS - target_image: mknod: /home/r/Downloads/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/dev/random
00:56:21 ERROR: File System and OS - target_image: : Operation not permitted
00:56:21 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.r.sh; [error]: : Operation not permitted
00:56:21 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
00:56:21 INFO: File System and OS - target_image: [host] [ 4.80 GB used. Disk Avail: 34.29 GB ]
00:56:21 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 2m55s ]
00:56:21 ERROR: File System and OS - target_image: command terminated with error
00:56:21 SUMMARY: File System and OS - target_image: First Error: Installation failed.
You are trying to install Jetpack 6.0 so this log is very weird.
Can you try it again but this time in step 2, be careful of the dir path?
I’m sorry I forgot to mention I tried both dp_6.0 and 5.1.2. same error occurs
I am sure there are better methods but how about you delete the nvidia folder first in your home directory.
sudo rm -rf ~/nvidia/
Then also delete the stuff in the ~/Download folder (nvidia related stuff for jetson, you know) (maybe ~/Download/nvidia ?)
Then try again.
Not the best method sorry, but this should work as long as you are following steps properly which isn’t that difficult.
yeah I tried that same prob… In my host machine I have only 56gb (/home) only left, hope this not a problem ?
Also I tried by this bootFromExternalStorage. could not flash…
I think you delete nvidia folder from your ~/Download and ~/nvidia, and even then if you are getting some error, then that is just weird because sdkmanager does everything by itself.
Maybe someone can help you with this, sorry.
You can also delete ~/.nvsdkm.
