SDK Manager Flash Jetson OS Skipped
I’m trying to reflash my Jetson Nano with JetPack 4.5.1 from the NVIDIA SDK Manager, but I’m getting a warning that the Flash Jetson OS from the Target Components is being skipped.
I am using a Jetson Nano production module (eMMC, no SD card).
During the beginning of installation, everything seems to proceed without issue, but eventually the target hardware automatically disconnects and causes installation to fail (temporarily). These are the steps I took:
  1. The Jetson Nano is put into Forced Recovery Mode by connecting the appropriate pins and confirmed on the host PC with lsusb showing the Nvidia Corp. device
  2. The Jetson Nano production module is detected automatically by the SDK Manager
  3. The Jetson Nano is selected in the Hardware Configuration options (Host is not selected)
  4. JetPack 4.5.1 (rev 1) is selected from in the JetPack version options
  5. The download destination folder on Host is set, and downloads start
  6. Downloads begin for all components except for Flash Jetson OS (“Flash Pending…”)
  7. Downloads complete for SDK components; Jetson OS image says “Creating OS Image”, then “OS image ready”; Flash Jetson OS still says “Flash Pending”
  8. When SDK Manager flash window appears (“SDK Manager is about to flash your Jetson Nano module”), Manual Setup is selected
Here is where the errors begin:
9. When the Jetson Nano (still connected to the host computer and still in Forced Recovery mode with joined pins) boots up on its own monitor to begin the System Configuration Wizard, the SDK Manager pops a warning window titled “Installation Failed, Could not detect target hardware”, and the status of all SDK Components and Flash Jetson OS is “Error”
10. On the Jetson Nano, I complete the System Configuration Wizard to set the username and password, then select the “Retry Failed Items” (logs were exported here, called FAILED in attachments below)
11. Immediately, the status of all SDK Components becomes “Install Pending”, the status of Flash Jetson OS becomes “Flash Jetson OS Skipped”, and the SDK Manager popup window titled “SDK Manager is about to install SDK components on your Jetson Nano module” appears and accepts the username and password set in the System Configuration Wizard.
12. Installation completes on the SDK Manager, and eventually displays the green “Installation Completed Successfully” above the yellow “Flash Jetson OS skipped” (logs were exported here, called FINISHED in attachments below)
Exiting the SDK Manager and logging into the Jetson Nano, I checked the tegra release version with the command cat /etc/nv_tegra_release and the JetPack version with sudo apt-cache show nvidia-jetpack.
Tegra version, post-install:
# R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t210ref, EABI: aarch64, DATE: Fri Feb 19 16:45:52 UTC 2021
JetPack Version, post-install:
Package: nvidia-jetpack
Version: 4.5.1-b17
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.5.1-b17), nvidia-opencv (= 4.5.1-b17), nvidia-cudnn8 (= 4.5.1-b17), nvidia-tensorrt (= 4.5.1-b17), nvidia-visionworks (= 4.5.1-b17), nvidia-container (= 4.5.1-b17), nvidia-vpi (= 4.5.1-b17), nvidia-l4t-jetson-multimedia-api (>> 32.5-0), nvidia-l4t-jetson-multimedia-api (<< 32.6-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.5.1-b17_arm64.deb
SHA256: 13c10e9a53ec51c261ce188d626966dfca27f26b2ed94ba700147c1ba3e35399
SHA1: 81047a7779241bbf16763dbd1c4c12cf8c9d0496
MD5sum: 54916439514f39af5234b3a43e329910
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.5-b129
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.5-b129), nvidia-opencv (= 4.5-b129), nvidia-cudnn8 (= 4.5-b129), nvidia-tensorrt (= 4.5-b129), nvidia-visionworks (= 4.5-b129), nvidia-container (= 4.5-b129), nvidia-vpi (= 4.5-b129), nvidia-l4t-jetson-multimedia-api (>> 32.5-0), nvidia-l4t-jetson-multimedia-api (<< 32.6-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.5-b129_arm64.deb
SHA256: 9ee354a66d932a3fbb244c926f333143a845c627c6981d108e01df2958ac462c
SHA1: 0e07f27c6fb9e34a70c69ae1150d1e578e938089
MD5sum: a551bbc8ff653c8983ce1804082bbcab
Ultimately, I’m not sure what effect the interrupt and the “Flash Jetson OS Skipped” had on the installation. The same error appears each time I try to re-flash 4.5.1, but never appears when flashing other versions of JetPack (ex. 4.6.1). Is this something that can be corrected, or is it a non-issue?
SDKM_logs_JetPack_4.5.1_(rev.1)_Linux_for_Jetson_Nano_2022-07-07_17-03-58_FAILED.zip (257.8 KB)
SDKM_logs_JetPack_4.5.1_(rev.1)_Linux_for_Jetson_Nano_2022-07-07_17-35-52_FINISHED.zip (398.6 KB)
Hi
Check logs, the SDKM can’t detect Jetson Nano, so flash and sdk components are skip.
17:18:25.198 - error: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: *** Checking target board connection ... *** Error: No Jetson device found.
17:18:25.198 - info: Event: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO - error is: *** Checking target board connection ... *** Error: No Jetson device found.
17:18:25.198 - info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: Connect 1 Jetson in RCM mode and rerun ./nvautoflash.sh --no-systemimg
17:18:25.204 - info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: [ Component Install Finished with Error ]
17:18:25.204 - info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: [host] [ 12.00 KB used. Disk Avail: 39.67 GB ]
17:18:25.204 - info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 1s ]
17:18:25.205 - info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO:
17:18:25.205 - error: command error code: 11
17:18:25.205 - info: Event: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO - error code is: 1011
17:18:25.205 - error: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: command terminated with error
17:18:25.205 - info: Event: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO - error is: command terminated with error
17:18:25.209 - warn: Found known error: *** Checking target board connection ... *** Error: No Jetson device found.
17:18:25.210 - info: Event: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO - install ended - failure
17:18:25.210 - info: Summary: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO: No board connected. Please make sure the target hardware is connected and turned on, choose OK and RETRY.
What target hardware are you select?
If you are using eMMC module, please select “Jetson Nano (P3448-0002 module)” like below:
