Hello.
In the Flash Jetson OS phase, it’s not progressing at all at 99%. Is there a solution?
Product : yahboom Jetson Nono 4G Developer
SDK Manager Ver : 1.9.3.10904 x86_64
OS : Ubuntu 18.04
Target OS : JetPack 4.6.2
13:43:48 DEBUG: Flash Jetson Nano - flash: using adapter to install NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS to /media/yahboom/a50087f6-f427-4cad-8a73-555712873f44/jetson/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS
13:43:48 INFO: Flash Jetson Nano - flash: [host] [ Disk Avail:22.09 GB ]
13:43:48 INFO: Flash Jetson Nano - flash: Installing component ‘Flash Jetson Nano’ (NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP)
13:43:48 INFO: Flash Jetson Nano - flash: change working directory to /media/yahboom/a50087f6-f427-4cad-8a73-555712873f44/jetson/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra
13:43:48 INFO: Flash Jetson Nano - flash: [ Component Install Started ]
13:43:48 INFO: Flash Jetson Nano - flash: current working directory is /media/yahboom/a50087f6-f427-4cad-8a73-555712873f44/jetson/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra
13:43:48 INFO: Flash Jetson Nano - flash: exec_command [host]:
13:43:48 INFO: Flash Jetson Nano - flash: **********************
13:43:48 INFO: Flash Jetson Nano - flash: #!/bin/bash
13:43:48 INFO: Flash Jetson Nano - flash: set -e
13:43:48 INFO: Flash Jetson Nano - flash: unset LC_ALL
13:43:48 INFO: Flash Jetson Nano - flash: echo sudo ./nvsdkmanager_flash.sh
13:43:48 INFO: Flash Jetson Nano - flash: sudo ./nvsdkmanager_flash.sh
13:43:48 INFO: Flash Jetson Nano - flash: sleep 20
13:43:48 INFO: Flash Jetson Nano - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh
13:43:48 INFO: Flash Jetson Nano - flash: Defaulting to autoflash
13:43:48 INFO: Flash Jetson Nano - flash: *** Checking ONLINE mode … OK.
13:43:48 INFO: Flash Jetson Nano - flash: *** Checking target board connection … 1 connections found.
13:43:48 INFO: Flash Jetson Nano - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x21 bootauth=
13:43:48 INFO: Flash Jetson Nano - flash: *** Reading EEPROM … “/media/yahboom/a50087f6-f427-4cad-8a73-555712873f44/jetson/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x21 --applet “/media/yahboom/a50087f6-f427-4cad-8a73-555712873f44/jetson/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin”
13:43:49 INFO: Flash Jetson Nano - flash: Welcome to Tegra Flash
13:43:49 INFO: Flash Jetson Nano - flash: version 1.0.0
13:43:49 INFO: Flash Jetson Nano - flash: Type ? or help for help and q or quit to exit
13:43:49 INFO: Flash Jetson Nano - flash: Use ! to execute system commands
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0013 ] Generating RCM messages
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0276 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /media/yahboom/a50087f6-f427-4cad-8a73-555712873f44/jetson/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0284 ] RCM 0 is saved as rcm_0.rcm
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0641 ] RCM 1 is saved as rcm_1.rcm
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0643 ] List of rcm files are saved in rcm_list.xml
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0918 ]
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.0918 ] Signing RCM messages
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.1419 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.1428 ] Assuming zero filled SBK key
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.2355 ]
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.2355 ] Copying signature to RCM mesages
13:43:49 INFO: Flash Jetson Nano - flash: [ 0.2391 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
