Flashing Jetson Nano still stuck at 99%
I’m trying to incorporate my Jetson nano (P3448) from board (P3541) [though I’m not using the development board] into a kubernetes cluster based on the turingpi motherboard. I’ve managed to get two Jetson TX2 NX boards up and running, but with the nano I’m stuck. I tried reformatting by download the image and flashing the SD card. That worked up to the point I tried to update it when running, and after that got a consistent error. Various online posts suggested using the nvidia SDK manager - flashing that way got stuck at 99%. One of the posts here suggested I might be using the wrong board configuration, so I repeatedly tried the base board, the development board and the 2G development board. Same result.
A post with a very similar title to this one, closed several years ago, suggested directly using the flash.sh function in the SDK tools directory. I tried that, with pretty much every variation on the theme. The results, every time, is the same:
/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra$ sudo ./flash.sh $‘jetson-nano-qspi’ mmcblk0p1
L4T BSP Information:
R32 , REVISION: 7.3
Target Board Information:
Name: jetson-nano-qspi, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet “/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0007 ] Generating RCM messages
[ 0.0024 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0028 ] RCM 0 is saved as rcm_0.rcm
[ 0.0032 ] RCM 1 is saved as rcm_1.rcm
[ 0.0032 ] List of rcm files are saved in rcm_list.xml
[ 0.0032 ]
[ 0.0032 ] Signing RCM messages
[ 0.0047 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0051 ] Assuming zero filled SBK key
[ 0.0104 ]
[ 0.0104 ] Copying signature to RCM mesages
[ 0.0119 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0127 ]
[ 0.0127 ] Boot Rom communication
[ 0.0143 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0148 ] RCM version 0X210001
According to the prior post, this process should take maybe 10 minutes, longer on a slow host (which this is not). Nothing else happened after 2 hours. Bad board?
Hi @dr.slater1
Could please tests with the following command:
sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
I took it from How to build NVIDIA Jetson Nano kernel - RidgeRun Developer Connection
I am assuming that you are using a computer with native Ubuntu 18.04 OS and I see that you are using JetPack 4.6.3. So, could you please use the command above mentioned and tell us the results?
Hope this helps!
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
I am having the exact same issues as you, only difference is that I am running the 4.5.1 Jetpack and I am using a developer kit.
