When I tried with SDK manager, 1. my Dev kit got detected, 2. On step-3 IN flash jetson OS it get stopped at 99% I waited around 30 min but it not get moved further.
I again took out the memory card and flash the img file using balena. And I connected my kit to monitor using HDMI but there is no response.
My PC is Linux based , so after connecting jetson nano kit with my CPU, using lsusb command, I find the kit get connected it shows NVIDIA Corp…
What is the mistake done here. and how to rectify it. Because before SDK manager → flash Jetson os, I flashed my memory cars 2 times and insert in SOM It worked fine. How to make the kit to work fine as before.
Yes it is still a issue. I am not having any other jetson nano devices.
I tried with other cable (jetson nano Dev kit to my CPU). It is detecting properly.
