Hi I am try to flash jetpack4.6.6 to jetson tx1 ,but it stuck at 99% more then one hour. Please help me.
This is logs:
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0089 ] Generating RCM messages
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0116 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX1_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0129 ] RCM 0 is saved as rcm_0.rcm
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0210 ] RCM 1 is saved as rcm_1.rcm
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0212 ] List of rcm files are saved in rcm_list.xml
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0213 ] Signing RCM messages
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0245 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0258 ] Assuming zero filled SBK key
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0343 ]
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0344 ] Copying signature to RCM mesages
11:00:38 INFO: Flash Jetson TX1 - flash: [ 0.0372 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
Are you on VM or Ubuntu host machine?
i use vm by esxi
Sorry, VM is not supported, you have to use the native ubuntu PC.
