I have a 1404 VM running on my Ubuntu 1604 host. I have installed JetPack and I linked through the usb port. It shows up fine on the 1404 guest vm:
ubuntu@crusty:~$ lsusb
Bus 001 Device 004: ID 0955:7721 NVidia Corp.
But my installation gets stuck. I won’t show the whole log, but here’s the ending part:
copying flasher(/home/ubuntu/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/ubuntu/64_TX1/Linux_for_Tegra_64_tx1/bootloader/tegraflash.py) reused.
*** Flashing target device started. ***
./tegraflash.py --bl cboot.bin --bct P2180_A00_LP4_DSC_204Mhz.cfg --odmdata 0x84000 --bldtb tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p2597-devkit.xml --cmd "flash;reboot" --cfg flash.xml --chip 0x21
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.0165 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0186 ] RCM 0 is saved as rcm_0.rcm
[ 0.0396 ] RCM 1 is saved as rcm_1.rcm
[ 0.0396 ] List of rcm files are saved in rcm_list.xml
[ 0.0396 ]
[ 0.0397 ] Signing RCM messages
[ 0.0490 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0512 ] Assuming zero filled SBK key
[ 0.0788 ]
[ 0.0788 ] Copying signature to RCM mesages
[ 0.0804 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.0868 ]
[ 0.0868 ] Parsing partition layout
[ 0.1049 ] tegraparser --pt flash.xml
[ 0.1188 ]
[ 0.1188 ] Creating list of images to be signed
[ 0.1220 ] tegrahost --chip 0x21 --partitionlayout flash.bin --list images_list.xml
[ 0.1628 ]
[ 0.1628 ] Generating signatures
[ 0.1644 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1660 ] Assuming zero filled SBK key
[ 0.2188 ]
[ 0.2308 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.2324 ] Copying Sdram info from 1 to 2 set
[ 0.2480 ] Copying Sdram info from 2 to 3 set
[ 0.2553 ]
[ 0.2553 ] Updating boot device parameters
[ 0.2566 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.bin
[ 0.2580 ] Warning: No sdram params
[ 0.2668 ]
[ 0.2668 ] Updating bl info
[ 0.2680 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.bin --updatesig images_list_signed.xml
[ 0.2748 ]
[ 0.2748 ] Updating secondary storage information into bct
[ 0.2759 ] tegraparser --pt flash.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.2828 ]
[ 0.2828 ] Updating board information from board config into bct
[ 0.2839 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.2908 ]
[ 0.2908 ] Updating Odmdata
[ 0.2918 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata = 0x84000
[ 0.2931 ] Warning: No sdram params
[ 0.3028 ]
[ 0.3028 ] Get Signed section bct
[ 0.3039 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.3091 ]
[ 0.3091 ] Signing BCT
[ 0.3101 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.3113 ] Assuming zero filled SBK key
[ 0.3188 ]
[ 0.3188 ] Updating BCT with signature
[ 0.3198 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.3268 ]
[ 0.3268 ] Copying signatures
[ 0.3277 ] tegrahost --chip 0x21 --partitionlayout flash.bin --updatesig images_list_signed.xml
[ 0.3288 ] Run tegrabct to update tboot signature in bct
[ 0.3428 ]
[ 0.3428 ] Updating BFS information
[ 0.3439 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.bin
[ 0.3495 ]
[ 0.3495 ] Boot Rom communication
[ 0.3504 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.3515 ] BR_CID: 0x3210100164122583100000000efb0300
I’ve tried it a few times and it gets stuck always at this point. Any ideas what could be going wrong here? This is very frustrating situation. I would rather spend my time developing software instead of spending days trying to flash this. Thank you.
