Hello everyone,
I’m trying to flash a Jetson TX2 with Jetpack and I have the following error :
./tegraflash.py --chip 0x18 --applet "/home/flashing/Workspaces/JetPack/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0015 ] Generating RCM messages
[ 0.0022 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/flashing/Workspaces/JetPack/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0028 ] RCM 0 is saved as rcm_0.rcm
[ 0.0031 ] RCM 1 is saved as rcm_1.rcm
[ 0.0031 ] List of rcm files are saved in rcm_list.xml
[ 0.0031 ]
[ 0.0031 ] Signing RCM messages
[ 0.0039 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0045 ] Assuming zero filled SBK key
[ 0.0073 ]
[ 0.0073 ] Copying signature to RCM mesages
[ 0.0084 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0095 ]
[ 0.0095 ] Boot Rom communication
[ 0.0102 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0109 ] Boot Rom communication failed
[ 3.0093 ]
Error: Return value 3
Command tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
Reading board information failed.
My host is a native 14.04 Ubuntu (not a VM).
I can see “Bus 001 Device 029: ID 0955:7c18 NVidia Corp.” when I run lsusb.
I have enough place on my disk.
I tried to use the command-line like mentioned here : https://devtalk.nvidia.com/default/topic/1001583/jetson-tx2/jetson-tx2-not-recognized-installation-inside-docker-error-8-error-return-value-8-command-tegrarcm_v2-chip-0x18-rcm-rcm_list_signed-xml-skipuid-reading-board-information-failed-/post/5116716/#5116716
I still have the same error.
Any idea how to solve this one ?
Thanks a lot !
