After a dist update on my TX1, I get the following message while booting up.
tegra-xhci tegra-xhci: failed to init firmware from filesystem: tegra21x_xusb_firmware
The only way to access the TX1 is by connecting a keyboard to the micro-usb.
I did however try to flash it, but it keeps getting stuck in the same place during post installation. Here are the last lines of my terminal output.
done.
system.img built successfully.
Existing tbcfile(/home/thomas/jetson/64_TX1/Linux_for_Tegra_64_tx1/bootloader/nvtboot_cpu.bin) reused.
copying cfgfile(/home/thomas/jetson/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cfg/gnu_linux_tegraboot_emmc_full.xml) to flash.xml... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
device size -------------- 31276924928
bootpart size ------------ 8388608
userpart size ------------ 31268536320
Erase Block Size --------- 2097152
sector size -------------- 4096
Partition Config file ---- flash.xml
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(23 partitions) ***
[ BCT] BH 0 8191 4.0MiB
[ NVC] BH 8192 16383 4.0MiB nvtboot.bin
[ PPT] UH 0 4095 2.0MiB
[ GP1] UH 4096 8191 2.0MiB
[ APP] UH 8192 29368319 14336.0MiB system.img
[ TBC] UV 29368320 29372415 2.0MiB nvtboot_cpu.bin
[ EBT] UV 29372416 29380607 4.0MiB u-boot-dtb.bin
[ BPF] UV 29380608 29384703 2.0MiB bpmp.bin
[ WB0] UV 29384704 29396991 6.0MiB warmboot.bin
[ RP1] UV 29396992 29405183 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ TOS] UV 29405184 29417471 6.0MiB tos.img
[ EKS] UV 29417472 29421567 2.0MiB
[ FX] UV 29421568 29425663 2.0MiB
[ SOS] UV 29425664 29466623 20.0MiB
[ EXI] UV 29466624 29597695 64.0MiB
[ LNX] UV 29597696 29728767 64.0MiB
[ DTB] UV 29728768 29736959 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ NXT] UV 29736960 29741055 2.0MiB
[ MXB] UV 29741056 29753343 6.0MiB
[ MXP] UV 29753344 29765631 6.0MiB
[ USP] UV 29765632 29769727 2.0MiB
[ UDA] UV 29769728 61067263 15282.0MiB
[ GPT] UH 61067264 61071359 2.0MiB
copying flasher(/home/thomas/jetson/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/thomas/jetson/64_TX1/Linux_for_Tegra_64_tx1/bootloader/tegraflash.py) reused.
*** Flashing target device started. ***
./tegraflash.py --bl cboot.bin --bct P2180_A00_LP4_DSC_204Mhz.cfg --odmdata 0x84000 --bldtb tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p2597-devkit.xml --cmd "flash;reboot" --cfg flash.xml --chip 0x21
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.0203 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0244 ] RCM 0 is saved as rcm_0.rcm
[ 0.0437 ] RCM 1 is saved as rcm_1.rcm
[ 0.0437 ] List of rcm files are saved in rcm_list.xml
[ 0.0437 ]
[ 0.0437 ] Signing RCM messages
[ 0.0709 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0749 ] Assuming zero filled SBK key
[ 0.0920 ]
[ 0.0920 ] Copying signature to RCM mesages
[ 0.0939 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.0973 ]
[ 0.0976 ] Parsing partition layout
[ 0.1243 ] tegraparser --pt flash.xml
[ 0.1299 ]
[ 0.1303 ] Creating list of images to be signed
[ 0.1399 ] tegrahost --chip 0x21 --partitionlayout flash.bin --list images_list.xml
[ 0.2239 ]
[ 0.2239 ] Generating signatures
[ 0.2288 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2325 ] Assuming zero filled SBK key
[ 0.2816 ]
[ 0.3116 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.3145 ] Copying Sdram info from 1 to 2 set
[ 0.3435 ] Copying Sdram info from 2 to 3 set
[ 0.3435 ]
[ 0.3436 ] Updating boot device parameters
[ 0.3486 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.bin
[ 0.3520 ] Warning: No sdram params
[ 0.3526 ]
[ 0.3526 ] Updating bl info
[ 0.3546 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.bin --updatesig images_list_signed.xml
[ 0.3596 ]
[ 0.3596 ] Updating secondary storage information into bct
[ 0.3616 ] tegraparser --pt flash.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.3676 ]
[ 0.3677 ] Updating board information from board config into bct
[ 0.3695 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.3725 ]
[ 0.3726 ] Updating Odmdata
[ 0.3744 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata = 0x84000
[ 0.3764 ] Warning: No sdram params
[ 0.3869 ]
[ 0.3869 ] Get Signed section bct
[ 0.3887 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.3909 ]
[ 0.3909 ] Signing BCT
[ 0.3934 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.3965 ] Assuming zero filled SBK key
[ 0.3975 ]
[ 0.3976 ] Updating BCT with signature
[ 0.4002 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.4056 ]
[ 0.4056 ] Copying signatures
[ 0.4077 ] tegrahost --chip 0x21 --partitionlayout flash.bin --updatesig images_list_signed.xml
[ 0.4102 ] Run tegrabct to update tboot signature in bct
[ 0.4173 ]
[ 0.4173 ] Updating BFS information
[ 0.4194 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.bin
[ 0.4217 ]
[ 0.4217 ] Boot Rom communication
[ 0.4237 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.4259 ] BR_CID: 0x32101001640ca5870400000016038100
[ 0.6871 ] RCM version 0X210001
At this point nothing else happens.
Any ideas?
