I’m trying to flash my TX1 device, and here’s the error I got:
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.0011 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0020 ] RCM 0 is saved as rcm_0.rcm
[ 0.0025 ] RCM 1 is saved as rcm_1.rcm
[ 0.0025 ] List of rcm files are saved in rcm_list.xml
[ 0.0025 ]
[ 0.0025 ] Signing RCM messages
[ 0.0035 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0044 ] Assuming zero filled SBK key
[ 0.0120 ]
[ 0.0120 ] Copying signature to RCM mesages
[ 0.0156 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.2232 ]
[ 0.2233 ] Parsing partition layout
[ 0.2245 ] tegraparser --pt flash.xml.tmp
[ 0.2257 ]
[ 0.2257 ] Creating list of images to be signed
[ 0.2265 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.5696 ]
[ 0.5696 ] Generating signatures
[ 0.5706 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.5741 ] Assuming zero filled SBK key
[ 0.7149 ]
[ 0.7149 ] Generating br-bct
[ 0.7160 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.7168 ] Copying Sdram info from 1 to 2 set
[ 0.8226 ] Copying Sdram info from 2 to 3 set
[ 0.8226 ]
[ 0.8226 ] Updating boot device parameters
[ 0.8238 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.xml.bin
[ 0.8247 ] Warning: No sdram params
[ 0.9178 ]
[ 0.9178 ] Updating bl info
[ 0.9189 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 2.0635 ]
[ 2.0635 ] Updating secondary storage information into bct
[ 2.0646 ] tegraparser --pt flash.xml.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 2.5305 ]
[ 2.5306 ] Updating board information from board config into bct
[ 2.5316 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 2.9445 ]
[ 2.9445 ] Updating Odmdata
[ 2.9457 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata =0x84000
[ 2.9465 ] Warning: No sdram params
[ 3.4998 ]
[ 3.4998 ] Get Signed section bct
[ 3.5009 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 3.5957 ]
[ 3.5958 ] Signing BCT
[ 3.5977 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 3.5986 ] Assuming zero filled SBK key
[ 3.5992 ]
[ 3.5992 ] Updating BCT with signature
[ 3.6002 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 4.1745 ]
[ 4.1746 ] Copying signatures
[ 4.1758 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 4.1770 ] Run tegrabct to update tboot signature in bct
[ 4.3818 ]
[ 4.3818 ] Updating BFS information
[ 4.3831 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.xml.bin
[ 4.5868 ]
[ 4.5869 ] Boot Rom communication
[ 4.5879 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 4.5892 ] BootRom is not running
[ 4.6117 ]
[ 4.6118 ] Sending BCTs
[ 4.6128 ] tegrarcm --download bct P2180_A00_LP4_DSC_204Mhz.bct
[ 4.6136 ] Applet is not running on device. Continue with Bootloader
[ 4.6183 ]
[ 4.6183 ] Sending bootloader and pre-requisite binaries
[ 4.6195 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb 0
[ 4.6205 ] Applet is not running on device. Continue with Bootloader
[ 4.6225 ]
[ 4.6225 ] Retrieving storage infomation
[ 4.6239 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 4.6248 ] Applet is not running on device. Continue with Bootloader
[ 4.6269 ]
[ 4.6279 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 4.6286 ] Cboot is not running on device.
[ 4.6304 ]
Error: Return value 4
Command tegradevflash --oem platformdetails storage storage_info.bin
Failed flashing t210ref.
I only copied part of the log that I think would be useful for debugging. I’m using JetPack L4T 3.1. What is the problem here?
Best regards,
