I tried to rescue my Jetson Nano B01 by reflashing the bootloader. But I failed. Here is the debug information.
My Jetson Nano cannot boot up and output the following debug error.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1f0626
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.281] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.302] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI ...
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.523] Bootloader DTB Load Address: 0x83000000
[0000.528] BoardID = 3448, SKU = 0x0
[0000.531] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.535] Nano-SD: checking PT table on QSPI ...
[0000.540] Loading NvTbootKernelDTB
[0000.606] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.679] Kernel DTB Load Address: 0x83100000
[0000.683] BoardID = 3448, SKU = 0x0
[0000.686] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.690] Nano-SD: checking PT table on QSPI ...
[0000.696] Loading cboot binary
[0000.812] Verifying EBT in OdmNonSecureSBK mode
[0000.854] Bootloader is corrupted!
[0000.857] Error in NvTbootLoadBinary: 0x14 !
[0000.861] BoardID = 3448, SKU = 0x0
[0000.864] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.868] Nano-SD: checking PT table on QSPI ...
[0000.873] PT: Partition RBL NOT found !
[0000.876] Warning: Find Partition via PT Failed
[0000.880] Error is 1
I reckon this could be because of the corrupted bootloader and then try to reflash the bootloader using the SDKManager.
However, I get the following error message and cannot complete the bootloader flashing
23:32:00 DEBUG: Flash Jetson Nano - flash: using adapter to install NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS to /home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS
23:32:00 INFO: Flash Jetson Nano - flash: change working directory to /home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra
23:32:00 INFO: Flash Jetson Nano - flash: sudo ./nvsdkmanager_flash.sh
23:32:00 INFO: Flash Jetson Nano - flash: *** Checking ONLINE mode ... OK.
23:32:00 INFO: Flash Jetson Nano - flash: *** Checking target board connection ... 1 connections found.
23:32:00 INFO: Flash Jetson Nano - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x21 bootauth=
23:32:00 INFO: Flash Jetson Nano - flash: *** Reading EEPROM ... "/home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x21 --applet "/home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin"
23:32:00 INFO: Flash Jetson Nano - flash: [ 0.0036 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
23:32:00 INFO: Flash Jetson Nano - flash: [ 0.0217 ] Assuming zero filled SBK key
23:32:00 INFO: Flash Jetson Nano - flash: [ 0.0391 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
23:32:00 INFO: Flash Jetson Nano - flash: [ 0.0568 ] RCM version 0X210001
23:32:01 INFO: Flash Jetson Nano - flash: [ 0.1075 ] Boot Rom communication completed
23:32:01 INFO: Flash Jetson Nano - flash: [ 1.1309 ] Applet version 00.01.0000
23:32:01 INFO: Flash Jetson Nano - flash: [ 1.1657 ] Saved platform info in /home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
23:32:01 INFO: Flash Jetson Nano - flash: [ 1.2857 ] Applet version 00.01.0000
23:32:03 INFO: Flash Jetson Nano - flash: [ 3.3534 ] RCM 0 is saved as rcm_0.rcm
23:32:03 INFO: Flash Jetson Nano - flash: [ 3.3700 ] Assuming zero filled SBK key
23:32:03 INFO: Flash Jetson Nano - flash: [ 3.3768 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
23:32:03 INFO: Flash Jetson Nano - flash: [ 3.3800 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
23:32:03 INFO: Flash Jetson Nano - flash: Command tegrarcm --oem platformdetails eeprom /home/crypto/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
23:32:03 ERROR: Flash Jetson Nano - flash: command terminated with error
23:32:03 SUMMARY: Flash Jetson Nano - flash: First Error: Installation failed.
Any suggestions?
