Unable to boot Jetson Nano
Unable to boot Jetson Nano board. Getting error message as in attachment.
Troubleshooting Done:
Re-flashed image.
Screen went blank after Nvidia Logo.
What kind of “re-flashed” image did you t ry? Flash with sdkmanager or just flash new sdcard image?
new sdcard image, jetson-nano-jp451-sd-card-image using balenaEtcher-Portable-1.5.116
Please try to use sdkmanager. If issue is still even after flashed with sdkmanger, then please file a request to RMA this device.
Unable to flash with sdk manager.
sdk manger throws error every time i try to flash the image.
4 attempt, returns same error
few of the lines from terminal
22:15:31 INFO: Flash Jetson Nano - flash: [ 0.0173 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
22:15:32 INFO: Flash Jetson Nano - flash: [ 0.0209 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
22:15:32 INFO: Flash Jetson Nano - flash: [ 0.0219 ] RCM version 0X210001
22:15:33 INFO: Flash Jetson Nano - flash: [ 1.0801 ] tegrarcm --oem platformdetails eeprom /home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
22:15:33 INFO: Flash Jetson Nano - flash: [ 1.0829 ] Applet version 00.01.0000
22:15:33 INFO: Flash Jetson Nano - flash: [ 1.1644 ] tegrarcm --reboot recovery
22:15:33 INFO: Flash Jetson Nano - flash: [ 1.1653 ] Applet version 00.01.0000
22:15:35 INFO: Flash Jetson Nano - flash: [ 1.1681 ]
22:15:35 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(400)
22:15:35 INFO: Flash Jetson Nano - flash: copying bctfile(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
22:15:35 INFO: Flash Jetson Nano - flash: copying bootloader(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
22:15:35 INFO: Flash Jetson Nano - flash: copying initrd(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
22:15:35 INFO: Flash Jetson Nano - flash: Making Boot image… done.
22:15:35 INFO: Flash Jetson Nano - flash: Existing sosfile(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
22:15:35 INFO: Flash Jetson Nano - flash: copying bpffile(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
22:15:35 INFO: Flash Jetson Nano - flash: Existing eksfile(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
22:15:35 INFO: Flash Jetson Nano - flash: Copying nv_boot_control.conf to rootfs
22:15:35 INFO: Flash Jetson Nano - flash: populating kernel to rootfs… done.
22:15:35 INFO: Flash Jetson Nano - flash: populating initrd to rootfs… done.
22:15:35 INFO: Flash Jetson Nano - flash: Making system.img…
22:16:11 INFO: Flash Jetson Nano - flash: populating rootfs from /home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
22:16:17 INFO: Flash Jetson Nano - flash: Sync’ing system.img … done.
22:16:37 INFO: Flash Jetson Nano - flash: Converting RAW image to Sparse image… done.
22:16:37 INFO: Flash Jetson Nano - flash: Existing tbcfile(/home/brijith/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
22:16:37 ERROR: Flash Jetson Nano - flash: command terminated with error
There are two ways for you now
  1. If you want to keep debugging, you can dump this log during the flash so that we can see why the flash process fails.
But actually you are only sharing part of log. Please share full flash log with us.
  1. Directly RMA this module and get a new one.
Log exported from sdk manager
SDKM_logs_JetPack_4.6_Linux_for_Jetson_Nano_[developer_kit_version]_2021-08-04_22-17-41.zip (324.1 KB)
Please install this on your host and run sdkmanager again.
sudo apt-get install libxml2-utils
Errors installing the new Jetpack 4.6 Version(JNano 2gb):
  • Host: Ubuntu 18.04.5 LTS
  • Jetson Nano 2gb
  • sdkmanager_1.6.0-8170_amd64.deb
  • jetson-nano-2gb-jp46-sd-card-image.zip
List Errors:
  • error: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS: Board ID(3448) version(400)
  • info: Event: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS - error is: Board ID(3448) version(400)
  • info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS: ERROR xmllint not found! To install - please run: “sudo apt-get install libxml2-utils”
  • info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS: *** ERROR: flashing failed.
  • info: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS: [ Component Install Finished with Error ]
  • error: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh; [error]: Board ID(3448) version(400)
  • info: Event: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS - error code is: 1011
  • error: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS: command terminated with error
  • error: Session first failure occurred while Installing. Root cause component: NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP@JETSON_NANO_TARGETS. Root cause error code: (1011: Failed to execute commands with GenericInstaller)
  • error: Trying to set a custom dimension: SessionInitialStatus - cd12, Download: 0. Install: 80. Visitor is not initialized.
  • error: completeSetup failed. Error:
  • error: install process failure
Solution: “sudo apt-get install libxml2-utils”
It worked here!
Thank’s for your time
