Hi all.
Is there anyone who succeed installing jetpack at jetson nano B01 using SDK manager?
It stops at “Flash Jetson OS” step when flashing 99%
I am not using Vertual machine but Double OS with windows.
This is the terminal message.
17:56:51 INFO: Popping up the guide dialog for user…
17:56:51 INFO: TensorRT on Target: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/uff-converter-tf_7.1.3-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: VisionWorks on Target: verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.501_arm64.deb
17:56:51 INFO: VisionWorks on Target: verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4.501_arm64.deb
17:56:51 INFO: cuDNN on Target: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: VisionWorks on Target: verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2.501_arm64.deb
17:56:51 INFO: VisionWorks on Target: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4.501_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.2.89-1_arm64.deb
17:56:51 INFO: VisionWorks on Target: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2.501_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): Found file /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.2.89-1_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cudnn_8.0.0.180-1+cuda10.2_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-tensorrt_7.1.3.0-1+cuda10.2_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): Found file /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cudnn_8.0.0.180-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-visionworks_1.6.0.501_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): Found file /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-visionworks_1.6.0.501_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.9.0_beta.1_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.9.0_beta.1_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.0.1-1_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.1.0-1_arm64.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.2.0-1_all.deb
17:56:51 INFO: NVIDIA Container Runtime with Docker integration (Beta): Found file /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.1.0-1_arm64.deb with correct checksum, skip downloading.
17:56:51 INFO: Multimedia API: verifying checksum of /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213809_arm64.deb
17:56:52 INFO: cuDNN on Target: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libcudnn8-dev_8.0.0.180-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
17:56:52 INFO: Multimedia API: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213809_arm64.deb with correct checksum, skip downloading.
17:56:52 INFO: TensorRT on Target: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_7.1.3-1+cuda10.2_all.deb with correct checksum, skip downloading.
17:56:53 INFO: CUDA Toolkit for L4T: Found file /home/bpl/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb with correct checksum, skip downloading.
17:57:29 INFO: Start to check if only one device connected…
17:57:29 DEBUG: running command < true >
17:57:29 INFO: command finished successfully
17:57:29 DEBUG: running command < [lsusb | grep -c "0955:"
-ne 1 ] >
17:57:29 DEBUG: command terminated with error
17:57:29 INFO: Only one NVIDIA device detected, as expected.
17:57:29 INFO: Start to check if in device recovery mode…
17:57:29 DEBUG: Flash Jetson Nano (Devkit): using adapter to install NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP@JETSON_NANO_DEVKIT to /home/bpl/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT
17:57:29 INFO: Flash Jetson Nano (Devkit): [host] [ Disk Avail:50.45 GB ]
17:57:29 INFO: Flash Jetson Nano (Devkit): exec_command: /tmp/tmp_NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP.sh
17:57:29 INFO: Flash Jetson Nano (Devkit): [host] [sudo] password for bpl:
17:57:30 INFO: Flash Jetson Nano (Devkit): ###############################################################################
17:57:30 INFO: Flash Jetson Nano (Devkit): ./tegraflash.py --chip 0x21 --applet “/home/bpl/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
17:57:30 INFO: Flash Jetson Nano (Devkit): [ 0.0020 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/bpl/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
17:57:30 INFO: Flash Jetson Nano (Devkit): [ 0.0044 ] Assuming zero filled SBK key
17:57:30 INFO: Flash Jetson Nano (Devkit): [ 0.0092 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
17:57:30 INFO: Flash Jetson Nano (Devkit): [ 0.0115 ] RCM version 0X210001
Can I ask you a help?
Best regards.
