Upgrade Jetpack from 6.0 to 6.1 on Orin NX Fails
Following the steps from this article Upgrade Jetpack from Jetson Linux 36.3 to 36.4 fails showing the following error:
nvidia@onx:/etc/apt/sources.list.d$ sudo apt dist-upgrade
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
gdal-data libaec0 libarmadillo10 libarpack2 libavcodec-dev libavformat-dev libavutil-dev libblosc1 libcfitsio9 libcharls2 libdc1394-dev libdeflate-dev libdouble-conversion3 libevent-pthreads-2.1-7 libexif-dev
libfabric1 libfreexl1 libfyba0 libgdal30 libgdcm-dev libgdcm3.0 libgeos-c1v5 libgeos3.10.2 libgeotiff5 libgl2ps1.4 libglew2.2 libgphoto2-dev libhdf4-0-alt libhdf5-103-1 libhdf5-hl-100 libheif1 libhwloc-plugins
libhwloc15 libilmbase-dev libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjsoncpp25 libkmlbase1 libkmldom1 libkmlengine1 liblept5 libminizip1 libmysqlclient21 libnetcdf19 libodbc2 libodbcinst2 libogdi4.1
libopencv-calib3d4.5d libopencv-contrib4.5d libopencv-dnn4.5d libopencv-features2d4.5d libopencv-flann4.5d libopencv-highgui4.5d libopencv-imgcodecs4.5d libopencv-imgproc4.5d libopencv-ml4.5d libopencv-objdetect4.5d
libopencv-photo4.5d libopencv-shape4.5d libopencv-stitching4.5d libopencv-superres4.5d libopencv-video4.5d libopencv-videoio4.5d libopencv-videostab4.5d libopencv-viz4.5d libopenexr-dev libopenmpi3 libpmix2 libpng-dev
libpq5 libproj22 libraw1394-dev librttopo1 libsocket++1 libspatialite7 libsuperlu5 libswresample-dev libswscale-dev libsz2 libtbb-dev libtbb12 libtesseract4 libtiff-dev libtiffxx5 libucx0 liburiparser1 libvtk9.1
libwpe-1.0-1 libwpebackend-fdo-1.0-1 libxerces-c3.2 libxnvctrl0 mysql-common proj-data unixodbc-common
Use ‘sudo apt autoremove’ to remove them.
Get more security updates through Ubuntu Pro with ‘esm-apps’ enabled:
python2.7-minimal libzbar0 libheif1 libiperf0 libjs-jquery-ui libopenexr-dev
libopenexr25 python3-scipy libpostproc55 libswscale-dev libavcodec58 iperf3
libpython2.7 libavutil56 libswscale5 libavutil-dev libswresample3
libavformat58 python2.7 libavformat-dev libavcodec-dev libde265-0
libpython2.7-minimal libpmix2 libpython2.7-stdlib libswresample-dev
libavfilter7
Learn more about Ubuntu Pro at Ubuntu Pro | Ubuntu
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up nvidia-l4t-kernel (5.15.148-tegra-36.4.0-20240912212859) …
Using the existing boot entry ‘primary’
Warning: Cannot get compatible board name.
3767–0001–1–ai_box-
TNSPEC 3767-300-0001-N.2-1-0-ai_box-
COMPATIBLE_SPEC 3767–0001–1–ai_box-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767–0001–1–ai_box-.
Info: The esp is already mounted to /boot/efi.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-kernel (–configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.0-20240912212859); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.15.148-tegra-36.4-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.15.148-tegra-36.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-modules:
nvidia-l4t-kernel-oot-modules depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.0-20240912212859); however:
dpkg: error processing package nvidia-l4t-kernel-oot-modules (–configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.0-20240912212859); however:
dpkg: error processing package nvidia-l4t-display-kernel (–configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-headers:
nvidia-l4t-kernel-oot-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.0-20240912212859); however:
dNo apport report written because MaxReports is reached already
pkg: error processing package nvidia-l4t-kernel-oot-headers (–configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.0-20240912212859); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (–configure):
Processing triggers for nvidia-l4t-initrd (36.4.0-20240912212859) …
Include /etc/nv-update-initrd/list.d/binlist
Include /etc/nv-update-initrd/list.d/modules
nv-update-initrd: Updating /boot/initrd from /etc/nv-update-initrd/list.d for kernel version 5.15.148-tegra…
Add /usr/sbin/nvluks-srv-app
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko
Add /lib/modules/5.15.148-tegra/modules*
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/typec.ko
Updating modprobe.d configuration directories for modprobe…
Add config /etc/modprobe.d/alsa-base.conf
Add config /etc/modprobe.d/bcmdhd.conf
Add config /etc/modprobe.d/blacklist-ath_pci.conf
Add config /etc/modprobe.d/blacklist.conf
Add config /etc/modprobe.d/blacklist-firewire.conf
Add config /etc/modprobe.d/blacklist-framebuffer.conf
Add config /etc/modprobe.d/blacklist-modem.conf
Add config-link /etc/modprobe.d/blacklist-oss.conf
Add config /etc/modprobe.d/blacklist-rare-network.conf
Add config /etc/modprobe.d/denylist-nouveau.conf
Add config /etc/modprobe.d/denylist-oot-modules-audio.conf
Add config /etc/modprobe.d/denylist-ramoops.conf
Add config /etc/modprobe.d/denylist-tegra-safety.conf
Add config /etc/modprobe.d/denylist-tpm-ftpm-tee.conf
Add config /etc/modprobe.d/iwlwifi.conf
Add config /etc/modprobe.d/mdadm.conf
Add config /etc/modprobe.d/nvgpu.conf
Add config /etc/modprobe.d/tegra-udrm.conf
Add config /lib/modprobe.d/aliases.conf
Add config /lib/modprobe.d/fbdev-blacklist.conf
Add config /lib/modprobe.d/systemd.conf
Cleaning up the temporary directory for updating the initrd…
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hi
Could you execute below commands and share result for us to review?
cat /etc/nv_tegra_release
Hi @DavidDDD.
Before i follow the upgrade process this is the results:
> nvidia@onx:~$ cat /etc/nv_tegra_release
> # R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, D        ATE: Mon May  6 17:34:21 UTC 2024
> # KERNEL_VARIANT: oot
> TARGET_USERSPACE_LIB_DIR=nvidia
> TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
After i follow the upgrade process this is the result. But my device is unable to boot after this.
> # R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan  8 01:49:37 UTC 2025
Need more info to review
  • Is your Orin NX using a Orin Nano dev kit or custom carrier board?
  • What is your flashing method? sdk manager or through the command line
@DavidDDD this a custom carrier board, and the flashing is through command line using a custom BSP for the custom carrier board. The storage is an NVM drive.
Hi
We not support upgrade for the custom carrier board because we will install our dev kit package, leading your device cannot boot up.
Please refer to related topics.
Thank you @DavidDDD
